Corky,
Liars? Well, I'll reserve judgment. A little weak in the details and presentation? Absolutely. I have pretty intimate knowledge of the LS1 and LS6. So let's just start looking at their information, shall we? Can you show me what their rated, maximum hp for their CONVERSION is? How about the CONTINUOUS rated hp for their CONVERSION? I can't find it. They list a maximum hp rating of 350 for the LS1, which isn't their rating it's GM's rating. And that's not a continuous rating. But we'll just let that slide for a moment, let's get to fuel consumption. They show a BSFC of .454 or .507 at 3200 rpm. Interesting, not, that they don't show a MAP they got that at, since that with RPM would tell us what HP the engine was making? Never mind that, let's go back to GM. At 3200 rpm GM showed the LS1 making 200 hp. That means that at 200 hp, the engine is burning between 10 and 11 gph. WoW!! All those electronic bells and whistles sure did improve efficiency over the old dinosaurs, didn't it? Speaking of which.............. They really don't say much about those bells and whistles, do they?? All they say is that the engine uses "multi-port injection" and "computerized electronic 8 coils" ignition. Curious, that's what GM uses on them. Except to make them really run right, in cruise, they have to operate in closed loop mode. To do that, they need a lead free fuel. 100LL will make the O2 sensors last about, oh, 3-4 hours, if you're lucky. What happens if the O2 sensor fails? The ECM goes into open loop mode and you get BSFC of around ..500 or so. But speaking of fuel................. Yep, it's getting less rare to have auto fuel on the airport, but I still wouldn't say that's a common thing to have, would you? And even if it was, 91 octane? Some places, premium IS 91 octane. KS, it's not. 99% of the premium grade is 89 octane and that's with 10% ethanol. So, you land, have to hunt down auto gas, and then have to hunt down 91 octane auto gas, get it back to the airport to fuel up. Yep, that's going to be cost and time effective. NOT. Oh, the LS1/LS6 will run on 89 octane, by having the ECM pull the timing back which gives you less power and a higher BSFC....... Somewhere it was said they have 600 hours on this conversion and yet from their site "I have approximately 56 hours on the finished product, including a very enjoyable trip to Airventure 2000." Not a long term study. As far as price goes, the best price I've found on an LS6 is about $8,500, with shipping. They're really not a very good engine to rebuild due to their method of construction, but if you want to you probably can, for around $7,500. Of course there's that gear reduction and the normal aircraft accessories that need to be overhauled as well. He lists the overhaul cost of the LS6 at $13,000 CDN, that's about $9,875 on today's market US$. He is NOT going to overhaul the conversion package of an LS6 for $10K. Not going to happen. I found this web site to be interesting. The guy looks like he did a good job on the conversion for his purposes. I also can't see one item on it that makes any better than the Franklin. He has the overhaul cost at $40,000. For a Franklin? Lot's of guys were working on the Franklin's in Cozy's because they were 3-4 thousand CHEAPER than a 360 Lycoming. I'm elbow deep into a Northstar right now for a completely (ground-based) different purpose. The electronics and systems on this are daunting with untold failure modes. If these folks want to be pioneers, good on them. I'll pioneer my system on the ground, thanks anyway. John Stricker PS: How many hours of vibration analysis on that prop/PSRU system do you suppose they had before they took the old girl for a spin? "Corky Scott" wrote in message ... That's the correct definition of anectdotal BOb, it would appear to be a mistaken application though. These guys aren't casually observing their conversion, they created it, developed it, trouble shot it and flew it with their own bodies inside the airplane on which they installed it. And they flew it for 600 hours so far. It looks like they were as scientific about it as they could be, with direct comparisons, in all modes, to the Franklin powered model. I don't understand why you consider them liars. Do you have evidence that the photos and text is faked? It obviously really irks you when someone actually successfully flies behind an auto conversion, almost as much as when someone just talks naively about it. Corky Scott |
John Stricker wrote:
Corky, Somewhere it was said they have 600 hours on this conversion and yet from their site "I have approximately 56 hours on the finished product, including a very enjoyable trip to Airventure 2000." Not a long term study. He has more than 600 hours on the first SeaBee that was converted and 56 hours on the second one ...... I leave the rest of the error to be corrected by the reader... Rob ..ps I have seen this aircraft 3 times as he comes to the RAA events to talk about the plane. |
Rob,
I found on a different page where he says he had 650+ hours on the LS6 now. His two pages contradict each other, but that's understandable, things happen. My point on this is that if HE wants to experiment and play with it, that's great. It might even be something I might want to try some time. But in the long haul, figuring time, $$, and all factors, an auto conversion should be looked at as just that, something to experiment and play with and not something that's going to save you a ton of money. As to "rest of the error.." your point is??? John Stricker "Robert Schieck" wrote in message ... John Stricker wrote: Corky, Somewhere it was said they have 600 hours on this conversion and yet from their site "I have approximately 56 hours on the finished product, including a very enjoyable trip to Airventure 2000." Not a long term study. He has more than 600 hours on the first SeaBee that was converted and 56 hours on the second one ...... I leave the rest of the error to be corrected by the reader... Rob .ps I have seen this aircraft 3 times as he comes to the RAA events to talk about the plane. |
Rob, I found on a different page where he says he had 650+ hours on the LS6 now. His two pages contradict each other, but that's understandable, things happen. My point on this is that if HE wants to experiment and play with it, that's great. It might even be something I might want to try some time. But in the long haul, figuring time, $$, and all factors, an auto conversion should be looked at as just that, something to experiment and play with and not something that's going to save you a ton of money. As to "rest of the error.." your point is??? as you said: Speaking of which.............. They really don't say much about those bells and whistles, do they?? All they say is that the engine uses "multi-port injection" and "computerized electronic 8 coils" ignition. Curious, that's what GM uses on them. Except to make them really run right, in cruise, they have to operate in closed loop mode. To do that, they need a lead free fuel. 100LL will make the O2 sensors last about, oh, 3-4 hours, if you're lucky. What happens if the O2 sensor fails? The ECM goes into open loop mode and you get BSFC of around ..500 or so. from the web site: Engine Control System The system I chose is a standard G.M. system. The unit is programmed with the export code for leaded fuel and uses no oxygen sensors. This was to enable me to run 100 octane Low Lead fuel as well as premium unleaded fuel. It also meets the KISS criteria. The emission and VAT codes are suppressed. The computer is stock G.M. After much research and correspondence, the wiring harness was purchased from an after market supplier. This portion of the project was as time consuming as designing the reduction drive. Before undertaking a project like this, it is imperative to purchase the factory (not after market) manuals for the engine and read them thoroughly. You have to decide what is acceptable practice, how you want you're engine management system to work, and have the harness manufactured accordingly. I am not sure how much more detail you want or expected and the issue of the O2 sensor was addressed. disappointed, time to go to private lists where signal to noise ratio is better. Rob |
Why are you disappointed, because someone asks questions?? You disappoint
easily then. Having no O2 sensors requires the computer to go into open loop mode. That's not as efficient in cruise. Simple fact. It's now a simple, MAP system. Later he says that he's getting 8.5 IMP/hour at 3200 rpm. We have no way of knowing what HP that's making there, but if it's max at that rpm according to dyno charts that's a BSFC of .318. Guess what? That aint happening. That's better than a very efficient diesel can do. The conversions use of no O2 sensors simply backs up my point that they won't work with 100LL for very long. The published HP figures are GM's own, the developers don't make any claims for any other HP and don't really know what HP the conversion makes. Best guess is they're using a 400 hp auto engine to do slightly better than a 200 hp aviation engine. That being the case, are the Ford and Chevy V6 conversions that came from the factory at about 200 hp really only 100 hp aircraft engines? The fact that these guys made a system that appears to work well for them is commendable. It takes a lot of patience to do that. He's also not putting it in an experimental airframe either, also commendable. You guys fly what you want. Matters not to me. I regret ever having come out of lurk mode and ever bothering to check in on the group. John Stricker "Robert Schieck" wrote in message ... John Stricker wrote: Rob, I found on a different page where he says he had 650+ hours on the LS6 now. His two pages contradict each other, but that's understandable, things happen. My point on this is that if HE wants to experiment and play with it, that's great. It might even be something I might want to try some time. But in the long haul, figuring time, $$, and all factors, an auto conversion should be looked at as just that, something to experiment and play with and not something that's going to save you a ton of money. As to "rest of the error.." your point is??? as you said: Speaking of which.............. They really don't say much about those bells and whistles, do they?? All they say is that the engine uses "multi-port injection" and "computerized electronic 8 coils" ignition. Curious, that's what GM uses on them. Except to make them really run right, in cruise, they have to operate in closed loop mode. To do that, they need a lead free fuel. 100LL will make the O2 sensors last about, oh, 3-4 hours, if you're lucky. What happens if the O2 sensor fails? The ECM goes into open loop mode and you get BSFC of around .500 or so. from the web site: Engine Control System The system I chose is a standard G.M. system. The unit is programmed with the export code for leaded fuel and uses no oxygen sensors. This was to enable me to run 100 octane Low Lead fuel as well as premium unleaded fuel. It also meets the KISS criteria. The emission and VAT codes are suppressed. The computer is stock G.M. After much research and correspondence, the wiring harness was purchased from an after market supplier. This portion of the project was as time consuming as designing the reduction drive. Before undertaking a project like this, it is imperative to purchase the factory (not after market) manuals for the engine and read them thoroughly. You have to decide what is acceptable practice, how you want you're engine management system to work, and have the harness manufactured accordingly. I am not sure how much more detail you want or expected and the issue of the O2 sensor was addressed. disappointed, time to go to private lists where signal to noise ratio is better. Rob |
![]() "John Stricker" wrote in message I regret ever having come out of lurk mode and ever bothering to check in on the group. John Stricker Why? You haven't been flamed, or anything. -- Jim in NC |
You have changed the topic...
We are discussing your misquoting his web site to prove your point. You asked for another error and I delivered another one. You may want to read the post from me titled : V-8 powered Seabee - a response from Brian Robinson it is a response from the SeaBee Conversation Designer to your first message. He did wish you luck on your northstar conversion as he ruled it out for the SeaBee as begin too complicated. And, in case you don't read it, there are now 3 converted SeaBees flying with more than 1100 trouble free hours between them, with 874 hours on the highest time one. In addition he has just delivered his first conversion to a Murphy Super Rebel customer. Personally, I think you should be so lucky to have as much success with your Northstar project . However if the Northstar's electronics and system become to daunting, you could always purchase a LS-1/6 conversion from Brian as he seems to have the electronics and the systems all worked out. . Rob John Stricker wrote: Why are you disappointed, because someone asks questions?? You disappoint easily then. Having no O2 sensors requires the computer to go into open loop mode. That's not as efficient in cruise. Simple fact. It's now a simple, MAP system. Later he says that he's getting 8.5 IMP/hour at 3200 rpm. We have no way of knowing what HP that's making there, but if it's max at that rpm according to dyno charts that's a BSFC of .318. Guess what? That aint happening. That's better than a very efficient diesel can do. The conversions use of no O2 sensors simply backs up my point that they won't work with 100LL for very long. The published HP figures are GM's own, the developers don't make any claims for any other HP and don't really know what HP the conversion makes. Best guess is they're using a 400 hp auto engine to do slightly better than a 200 hp aviation engine. That being the case, are the Ford and Chevy V6 conversions that came from the factory at about 200 hp really only 100 hp aircraft engines? The fact that these guys made a system that appears to work well for them is commendable. It takes a lot of patience to do that. He's also not putting it in an experimental airframe either, also commendable. You guys fly what you want. Matters not to me. I regret ever having come out of lurk mode and ever bothering to check in on the group. John Stricker "Robert Schieck" wrote in message ... John Stricker wrote: Rob, I found on a different page where he says he had 650+ hours on the LS6 now. His two pages contradict each other, but that's understandable, things happen. My point on this is that if HE wants to experiment and play with it, that's great. It might even be something I might want to try some time. But in the long haul, figuring time, $$, and all factors, an auto conversion should be looked at as just that, something to experiment and play with and not something that's going to save you a ton of money. As to "rest of the error.." your point is??? as you said: Speaking of which.............. They really don't say much about those bells and whistles, do they?? All they say is that the engine uses "multi-port injection" and "computerized electronic 8 coils" ignition. Curious, that's what GM uses on them. Except to make them really run right, in cruise, they have to operate in closed loop mode. To do that, they need a lead free fuel. 100LL will make the O2 sensors last about, oh, 3-4 hours, if you're lucky. What happens if the O2 sensor fails? The ECM goes into open loop mode and you get BSFC of around .500 or so. from the web site: Engine Control System The system I chose is a standard G.M. system. The unit is programmed with the export code for leaded fuel and uses no oxygen sensors. This was to enable me to run 100 octane Low Lead fuel as well as premium unleaded fuel. It also meets the KISS criteria. The emission and VAT codes are suppressed. The computer is stock G.M. After much research and correspondence, the wiring harness was purchased from an after market supplier. This portion of the project was as time consuming as designing the reduction drive. Before undertaking a project like this, it is imperative to purchase the factory (not after market) manuals for the engine and read them thoroughly. You have to decide what is acceptable practice, how you want you're engine management system to work, and have the harness manufactured accordingly. I am not sure how much more detail you want or expected and the issue of the O2 sensor was addressed. disappointed, time to go to private lists where signal to noise ratio is better. Rob |
I did read your other post and emailed Brian myself complimenting him on the
job they do and asked some more questions. 1100 trouble free hours? You don't know that. All you know is there are three conversions that have accumulated 1100 hours on the hobbs. Take that and compare it to the how many MILLIONS of hours of Lycoming and Continental time and it will put things in perspective. What did I misquote? He has different numbers in different parts of his website. Even with his email you published, he STILL doesn't give a power rating, does he? I didn't see the second set of numbers. That's not a misquote. I also didn't see that he eliminated the O2 sensors. My point remains unchanged, without the O2 sensors he's running in open loop and not running the way the engine was designed to run. I don't need to worry about luck with my Northstar because it's not flying anywhere. It's staying firmly attached to the ground, as long as the suspension holds up. Tickled me, though, that they thought the Northstar was too complicated when it has DOHC and direct lifter on valve actuation and virtually the same electronics as the LS6. But the car itself, when finished, will run faster than a SeaBee. Where did I say it was too daunting? Nice little attempted backhand slam, didn't work though. Besides, do you really think the guys will help me convert the 4T80E to a six speed with a paddle shift (which is what I'm working on right now)? Oh, that's right, airplanes don't need that. 8-) John Stricker "Robert Schieck" wrote in message ... You have changed the topic... We are discussing your misquoting his web site to prove your point. You asked for another error and I delivered another one. You may want to read the post from me titled : V-8 powered Seabee - a response from Brian Robinson it is a response from the SeaBee Conversation Designer to your first message. He did wish you luck on your northstar conversion as he ruled it out for the SeaBee as begin too complicated. And, in case you don't read it, there are now 3 converted SeaBees flying with more than 1100 trouble free hours between them, with 874 hours on the highest time one. In addition he has just delivered his first conversion to a Murphy Super Rebel customer. Personally, I think you should be so lucky to have as much success with your Northstar project . However if the Northstar's electronics and system become to daunting, you could always purchase a LS-1/6 conversion from Brian as he seems to have the electronics and the systems all worked out. . Rob John Stricker wrote: Why are you disappointed, because someone asks questions?? You disappoint easily then. Having no O2 sensors requires the computer to go into open loop mode. That's not as efficient in cruise. Simple fact. It's now a simple, MAP system. Later he says that he's getting 8.5 IMP/hour at 3200 rpm. We have no way of knowing what HP that's making there, but if it's max at that rpm according to dyno charts that's a BSFC of .318. Guess what? That aint happening. That's better than a very efficient diesel can do. The conversions use of no O2 sensors simply backs up my point that they won't work with 100LL for very long. The published HP figures are GM's own, the developers don't make any claims for any other HP and don't really know what HP the conversion makes. Best guess is they're using a 400 hp auto engine to do slightly better than a 200 hp aviation engine. That being the case, are the Ford and Chevy V6 conversions that came from the factory at about 200 hp really only 100 hp aircraft engines? The fact that these guys made a system that appears to work well for them is commendable. It takes a lot of patience to do that. He's also not putting it in an experimental airframe either, also commendable. You guys fly what you want. Matters not to me. I regret ever having come out of lurk mode and ever bothering to check in on the group. John Stricker "Robert Schieck" wrote in message ... John Stricker wrote: Rob, I found on a different page where he says he had 650+ hours on the LS6 now. His two pages contradict each other, but that's understandable, things happen. My point on this is that if HE wants to experiment and play with it, that's great. It might even be something I might want to try some time. But in the long haul, figuring time, $$, and all factors, an auto conversion should be looked at as just that, something to experiment and play with and not something that's going to save you a ton of money. As to "rest of the error.." your point is??? as you said: Speaking of which.............. They really don't say much about those bells and whistles, do they?? All they say is that the engine uses "multi-port injection" and "computerized electronic 8 coils" ignition. Curious, that's what GM uses on them. Except to make them really run right, in cruise, they have to operate in closed loop mode. To do that, they need a lead free fuel. 100LL will make the O2 sensors last about, oh, 3-4 hours, if you're lucky. What happens if the O2 sensor fails? The ECM goes into open loop mode and you get BSFC of around .500 or so. from the web site: Engine Control System The system I chose is a standard G.M. system. The unit is programmed with the export code for leaded fuel and uses no oxygen sensors. This was to enable me to run 100 octane Low Lead fuel as well as premium unleaded fuel. It also meets the KISS criteria. The emission and VAT codes are suppressed. The computer is stock G.M. After much research and correspondence, the wiring harness was purchased from an after market supplier. This portion of the project was as time consuming as designing the reduction drive. Before undertaking a project like this, it is imperative to purchase the factory (not after market) manuals for the engine and read them thoroughly. You have to decide what is acceptable practice, how you want you're engine management system to work, and have the harness manufactured accordingly. I am not sure how much more detail you want or expected and the issue of the O2 sensor was addressed. disappointed, time to go to private lists where signal to noise ratio is better. Rob |
I had a VW powered aircraft one time that I had over 500 hours on.
In that 500 hours I had two complete failures. One I was close enough to land on an airport, the other one did not turn out so well. Point is that saying how many hours an engine has on it does not tell the whole story, we need to know the maintenance history along with the the hours flown. Jerry Robert Schieck wrote: John Stricker wrote: Corky, Somewhere it was said they have 600 hours on this conversion and yet from their site "I have approximately 56 hours on the finished product, including a very enjoyable trip to Airventure 2000." Not a long term study. He has more than 600 hours on the first SeaBee that was converted and 56 hours on the second one ...... I leave the rest of the error to be corrected by the reader... Rob .ps I have seen this aircraft 3 times as he comes to the RAA events to talk about the plane. |
![]() Jerry Springer wrote: I had a VW powered aircraft one time that I had over 500 hours on. In that 500 hours I had two complete failures. One I was close enough to land on an airport, the other one did not turn out so well. Point is that saying how many hours an engine has on it does not tell the whole story, we need to know the maintenance history along with the the hours flown. Jerry +++++++++++++++++++++++++++++++++++++++++++ Jerry, You're beating a very, very dead horse. The RAH auto conversion wannabees are incurably gullible and will not be deterred by honest info, perspective or reality. Legitimate auto conversion guys are knee deep in alligators... walking their talk and have no time for the fuzzy and inane horse**** that drives the RAH noisemakers. The RAH group is nothing but a vocal minority that fraudulently passes itself off as the real deal. It's laughable. All hat and no cattle, comes to mind. Time and time again this proves the case. The best they do is present URL's of someone elses claim to fame. It's entertaining to observe a bunch of clueless, immature twits do what they do best... hoot, holler, name call and shoot themselves in the foot at every turn.... with absolutely no awareness to that very fact. Barnyard BOb -- once again predictable |
human powered flight | patrick timony | Home Built | 10 | September 16th 03 03:38 AM |
Illusive elastic powered Ornithopter | Mike Hindle | Home Built | 6 | September 15th 03 03:32 PM |
Pre-Rotator Powered by Compressed Air? | nuke | Home Built | 8 | July 30th 03 12:36 PM |
Powered Parachute Plans | MJC | Home Built | 4 | July 15th 03 07:29 PM |
Powered Parachute Plans- correction | Cy Galley | Home Built | 0 | July 11th 03 03:43 AM |
