one man assembly
Old June 11th 09, 04:06 AM posted to rec.aviation.soaring
Frank[_12_]
Default one man assembly
On Jun 7, 6:29*pm, wrote:
Which one-man assembly dolly is the preferred for 15m?? * What dolly
works best if *two(older) people are assembling/disassembling and on a
hard surface? *Jim
My single-rig system consists of a second wing stand and a 8" diameter
by 36" long roll of carpet scrap. Works great on any surface, can't
fall down, and its a LOT cheaper/smaller/lighter than a $1000 assembly
dolly
TA
Old June 11th 09, 04:10 AM posted to rec.aviation.soaring
Tuno
I'd like to see some photos of that!
Old June 11th 09, 04:31 AM posted to rec.aviation.soaring
"Tuno" wrote in message ...
One man assembly systems aren't that hard to build. They make a great winter project.
http://www.soaridaho.com/Schreder/Co...rier/LWT-3.htm
With this unite I can assemble my HP-14 in less time by myself the I can with a team of three.
I notice that the above link references Udo Rumpf's unit. The associated link doesn't work because Udo removed the page when he halted production.
Old June 11th 09, 01:00 PM posted to rec.aviation.soaring
Peter Scholz
dolly
TA
Can you explain how this works?
Thanks,
Peter
Old June 11th 09, 03:57 PM posted to rec.aviation.soaring
Mike the Strike
I've used the Cobra and also used to own a Udo rigger. These both
work fine, but in rough field conditions the three-wheel design of the
Wing Rigger is superior. I also found the Udo's swivelling foot would
hit rocks and tip the thing over. What really annoyed me is that I
rapped my knuckles every time I used the manual height crank. I don't
have to use the height adjustment often, but when I do, the gas spring
is a doddle. It's also interesting to note that the IMI rigger ( a new
offering from Wings & Wheels) uses a gas spring for height adjustment.
My final advice is to try one first if you can.
If the carpet trick isn't a hoax, I'd like to see photos!
Mike
Old June 15th 09, 02:45 PM posted to rec.aviation.soaring
Andy[_1_]
I imagine the usage is similar to the blanket technique described by
KS a while ago, i.e. the wing tip is on the ground on the carpet and
the fuselage is rolled so the spar box lines up with the raised wing
spar. Then slide the wing on the carpet to insert the spar.
I'd hate to see the inventive caveman's effort go to waste and prefer
to use wheels.
Andy
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6974931.jpg [email protected] Aviation Photos 0 April 11th 07 02:45 AM
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6973027.jpg [email protected] Aviation Photos 0 April 11th 07 02:45 AM
Saturn IB S-IB Stage Assembly at Michoud Assembly Facility (MAF) 6973448.jpg [email protected] Aviation Photos 0 April 11th 07 02:43 AM
Saturn IB S-IB Stage Assembly at Michoud Assembly Facility 6973447.jpg [email protected] Aviation Photos 0 April 11th 07 02:43 AM
Saturn IB S-IB Stage Assembly at Michoud Assembly Facility 6522687.jpg [email protected] Aviation Photos 0 April 11th 07 02:43 AM
