On Jun 10, 11:50*pm, sisu1a wrote:
Hi Chris. I've made only one modifcation to my Speed Astir. *It's *a 'Mandl Extractor' vent to let air out. *Subjectively, I know I'm a lot cooler in the cockpit. *I haven't done this yet, but here's what I'm going to do to verify my subjective observation. *I have set up a water manometer that indicates the difference between cabin pressure and the static system. *I'll fly with my Extractor in place, but with the inside opening taped over. *After noting the manometer at 2 or 3 airspeeds/alititudes, I'll climb back up and repeat, after ripping the tape off the extractor. *I don't expect spectacular numbers, but if it just confirms a small drop in cabin pressure relative to the static system, I'll continue to use it. *If it indicates my 'subjective' observations are wishful thinking, I'll... still use it because I THINK it works (even if I'm wrong!) I also made a Mandle Exctractor, (as well as a Butler Extractor, which is what I actually use on my SZD-59 although the Mandle I made works just fine too... both really provide a night and day difference compared to no exhaust exit, but have made no real measurements as to actual performance...) and if Fuzz doesn't feel like molding up some, I would be happy to. In the process of researching different aspects on the subject, I made some discoveries and added some refinements as well to the inlet of this outlet, to efficiently accommodate a honeycomb grill of strategic proportions rather than putting a mere piece of mesh there to 'keep out the critters' as DG/LS put it but did not change the Mandle designed portion of it and of course it could be easily made as a normal one by removing the bell-mouth inlet and honeycomb flange... Tomorrow when I have more time I will post my synopsis on the subject... -Paul Please do, I am interested in making a replacement hatch for my Grob also, but have no experience molding fiberglass. Todd |
Trying again: Collings Foundation B-17 at Newcastle Airport inDelaware - B-17 cockpit.jpg - B-17 cockpit.jpg (1/5) | Jim Breckenridge | Aviation Photos | 1 | August 30th 08 07:36 PM |
Trying again: Collings Foundation B-17 at Newcastle Airport in Delaware - B-17 cockpit.jpg - B-17 cockpit.jpg (0/5) | Go-dot | Aviation Photos | 0 | August 28th 08 11:39 PM |
Wings of Freedom B-17 Wilmington, DE - B-17 cockpit.jpg - B-17 cockpit.jpg (0/5) | Go-dot | Aviation Photos | 0 | August 28th 08 09:37 PM |
Trailer ventilation | Simon Waddell | Soaring | 8 | May 2nd 06 02:36 PM |
ASW-27B ballast tank ventilation | Andy Blackburn | Soaring | 3 | October 24th 04 05:31 PM |
