Airbus Story (FWIW)
Old June 26th 09, 03:18 AM posted to rec.aviation.piloting
James Robinson
Default Airbus Story (FWIW)
Brian Whatcott wrote:
Sounds plausible to me. A direct path from unexpected rain at high
altitude (warm massive updraft in cu-nim?) to ice to frozen pitots to
loss of rudder limiting.
This meteorologist suggests that it would be highly unlikely for the Air
France flight to have encountered rain or even supercooled water. He also
suggests that the cause, if any, would be from descending air warming
rather than an updraft:
http://www.weathergraphics.com/tim/af447/
Then all it takes is injudicious heavy rudder in heavy turbulence
and you are in deep do-do....
Why would they be using rudder at cruising speed? Further, according to
the discussion in some of the other groups, the rudder limiter is still
effective in alternate law. It supposedly clamps the limit at where it was
when the shift was made from normal to alternate law.
Old June 26th 09, 12:24 PM posted to rec.aviation.piloting
Brian Whatcott
I read this over carefully, a few days ago. It seems like a respectable
evaluation. And yes, it is highly unlikely situations which we are
addressing. Both the eye-witness testimony of a person observing
considerable precipitation at altitude, and the obvious meteorological
observation that the higher the air, the colder, and the dryer (in
absolute terms). If you accept this, then you have to accept that the
water can only have come from below, via meso scale uplift (as the
report puts it). That's not to say the uplift was not pulling water up
higher than the fatal flight, then dropping it. These buildups are
invariably turbulent.
Brian W
Old June 29th 09, 01:50 AM posted to rec.aviation.piloting
spanky
Why would they be using rudder at cruising speed? *Further, according to
....look at the first line in the ACARS messages: RUD TRV LIM FAULT...
in other words, the rudder travel limiter not doing what it was
supposed to do, i.e., limit the rudder travel. This was followed in
fairly short order by a TCAS fault, an autothrottle disconnect, a/p
disconnect and institution of alternate flight law algorithms. Look
at the failure point of the 447 vertical stab and compare that with
the failure point of the AA 300 that went down in 2001 on departure
from JFK. Despite having a rudder travel limiter in place and
working, the 2001 incident proved rather markedly that it is entirely
possible, even at climb speeds, to overstress the vertical attach
points of the structure. ...at cruise, in what may have been beyond
extreme turbulence, that possibility may indeed be a probability in
this case. We'll never know until the FDRs and CVRs are found and
the data downloaded, but on that subject I have no faith that they
will be found and, given Airbus's shenanigans with black boxes from
earlier incidents, I have no faith that the company wants them to be
found.
Old June 29th 09, 03:36 AM posted to rec.aviation.piloting
James Robinson
to the discussion in some of the other groups, the rudder limiter is
still effective in alternate law. It supposedly clamps the limit at
where it was when the shift was made from normal to alternate law.
My understanding from the pros in other groups, is that message simply
says that the autolimiter disconnected, and as mentioned, the limits are
clamped at what they were prior to the disconnect. It is supposedly
part of the change from normal to alternate law.
This was followed in fairly short order by a TCAS fault, an
autothrottle disconnect, a/p disconnect and institution of alternate
Look at the failure point of the 447 vertical
stab and compare that with the failure point of the AA 300 that went
down in 2001 on departure from JFK.
They are different. Not at all the same type of attachment or type of
failure.
Despite having a rudder travel limiter in place and working,
The A300 was not a FBW aircraft.
the 2001 incident proved rather markedly that it is entirely possible,
even at climb speeds, to overstress the vertical attach points of the
structure. ...at cruise, in what may have been beyond extreme
turbulence, that possibility may indeed be a probability in this case.
Why would an experienced pilot be using the rudder at all at cruising
speed and at that altitude?
We'll never know until the FDRs and CVRs are found and the data
downloaded, but on that subject I have no faith that they will be
found and, given Airbus's shenanigans with black boxes from earlier
incidents, I have no faith that the company wants them to be found.
So they will just hope no other aircraft decide to disappear while in
cruise flight? Or do you think they already know what went wrong, and are
correcting it behind the curtain?
Old June 29th 09, 12:52 PM posted to rec.aviation.piloting
Richard[_11_]
supposed to do, i.e., limit the rudder travel. *
clamped at what they were prior to the disconnect. *It is supposedly
flight law algorithms. *
down in 2001 on departure from JFK. *
They are different. *Not at all the same type of attachment or type of
failure.
structure. *...at cruise, in what may have been beyond extreme
Look at the behaviour of US Scare and Boeing with the 737 rudder
reversal problem.
"Problem? There is no problem" Meanwhile, back at Area 51, er,
Seattle, all manner of work towards a solution is being performed.
Old June 29th 09, 01:23 PM posted to rec.aviation.piloting
James Robinson
reversal problem.
They had access to the FDR information, and I don't think US Airways was
complicit in blaming pilot error. That was only Boeing, and yes, they
were ass covering.
In the case of AF447, the last thing the would want is for another aircraft
to self-destruct, given the design is the basis for the potential US tanker
program, and the 350. Without the FDRs, can they be sure they have
actually solved the problem? Do they know enough to identify the cause
with certainty, and know what needs to be done to correct things?
Old June 29th 09, 08:02 PM posted to rec.aviation.piloting
spanky
....and if the pitot tubes were providing low airspeed data (which the
OP mentioned in his post, saying "the Captains, First Officers, and
standby airspeed indicators rolled back to 60kts...") prior to the
rudder travel limiter disengage, those travel limits would be far less
stringent than if the ADC "knew" the aircraft was travelling at cruise
speed.
failure.
Wrong. Both failure modes are nearly identical in apparent result
(side loads beyond design limits) and the attach fittings (composites
with steel/titanium attach points) are nearly identical as well. look
at the photographs of both verticals. there is no crushing on the
lower leading or lower trailing edges of the AF447 component that
would indicate the failure took place fore and/or aft; on the other
hand, the AF447 vertical shows skin tears along its lower edge that
would indicate that the failure mode was due to sideloads exceeding
design limits.
So what. The A300-600 has a rudder travel limiter, and its
effectiveness has been the subject of numerous NTSB Safety
Recommendations, to whit:
"A review of the flight data for rudder position showed that, even
after accounting for the slow response rate of the RTL, the rudder
still appeared to exceed the estimated position at which it should
have been limited by the RTL. This exceedance was as high as 4° near
the end of the upset. The A300-600 RTL is designed and constructed so
that it limits the rudder by reducing the allowable displacement of
the rudder pedals. Testing of the RTL determined that if a pilot
applies a sufficiently large pedal force when the pedal is at its
travel limit, this will further slow or stop the movement and,
consequently, the effectiveness of the RTL. As demonstrated by this
event, such slowing or stopping of the RTL by application of large
pedal forces could result in the rudder position substantially
exceeding the designed travel limit. The Safety Board is concerned
that such an increase in available rudder beyond the designed RTL
restrictions could permit excessive rudder movements and possibly
result in high loads on the vertical stabilizer."
Because the first word governing an experienced crew's reaction to an
emergency is "Aviate."
That means (especially in light of a highly experienced crew reacting
to an A/P disconnect as well as multiple warnings) put your feet on
the pedals and your hands on the yoke and fly the thing until you, and
the rest of the crew, can sort it all out. CRM 101.
i have no opinion one way or another. all i know is that there was a
fly-by accident at a press event years ago involving (if i recall
correctly) an A320 where, despite a TOGA command, the aircraft did not
respond and sank into the trees at the end of the runway. when the
"black boxes" were made available to the NTSB and public the serial
numbers (as well as the paint) on what were purported to be the boxes
from the accident aircraft were not the same as those that had been
installed on the accident aircraft.
Old July 1st 09, 02:03 PM posted to rec.aviation.piloting
David W
speed.
Is the pitot-static systems linked as in GA aircraft? If so, then a
clogged pitot would read low airspeed or am I in the dark here?
PWH and the Pricelessware Con Game - Exposed
http://tinyurl.com/knogy8
Old July 2nd 09, 05:20 AM posted to rec.aviation.piloting
D Ramapriya
standby airspeed indicators rolled back to 60kts...") *prior to the
speed.
If you meant to ask whether the 3-odd pitot systems, the answer I
think is a No, else you'd have both pilots' ASIs reporting the same
speed all the time, which isn't the case. Pilots can in fact even
choose which pitot system the Autopilot can take inputs from.
I seem to remember that one of the criticisms of the PF's actions in
the Birgen Air crash was that he didn't opt to link the AP to the
functional pitot system (FO's) although he knew right during the
takeoff roll that his own pitot had gone kaput.
Ramapriya
Old July 2nd 09, 03:18 PM posted to rec.aviation.piloting
James Robinson
simply says that the autolimiter disconnected, and as mentioned, the
limits are clamped at what they were prior to the disconnect. *It is
supposedly part of the change from normal to alternate law.
speed.
Three separate systems all roll back to the same speed identical
simultaneously? That is beyond wild speculation. As soon as one didn't
match the others, the system would cut out.
alternate flight law algorithms. *
went down in 2001 on departure from JFK. *
of failure.
design limits.
Wrong. The AA failure was in the attachment lugs, and the rudder was
completely missing. In the photos of the AF VS, you can see the lugs are
intact, and that the failure was in the surrounding structure, plus most
of the rudder is still attached. Further, the attachment arrangement
between the 310 and the 330 was redesigned.
My point is that the two aircraft are entirely different, as are the
controls limiting rudder travel. You might as well be trying to compare
a Boeing and an Airbus because they both have two wings and a tail.
points of the structure. *...at cruise, in what may have been
beyond extreme turbulence, that possibility may indeed be a
Which means they wouldn't consider using the rudder at high speed and
altitude. There is practically no situation I can think of where an
experienced crew would consider using the rudder. The rudder simply isn't
used to "aviate" at altitude. Using it would be an indication of
inexperience.
are correcting it behind the curtain?
You certainly do have an opinion, or you wouldn't have been posting this
stream of misinformation.
BEA is now saying that AF447 entered the water in one piece, in a
horizontal attitude, but with a high vertical force. That pretty well
describes a flat spin. That would not have happened if the VS separated
at high altitude.
http://tinyurl.com/mb4mmt
(en Francais)
And I see a number of US media sources can't translate French
aeronautical terms correctly, as they are saying the aircraft went
straight down, almost vertically.
Il paraît avoir heurté la surface de l'eau en ligne de vol
Means that the aircraft struck the surface in a horizontal attitude.
avec une forte accélération verticale"
Means with high vertical acceleration, meaning it was in an aerodynamic
stall.
FWIW - One magazine's top ten harrowing airports Paul T. Aviation Photos 2 April 13th 08 06:59 PM
FWIW, Moller Again ? Al G[_2_] Piloting 62 July 12th 07 06:59 PM
FWIW, Moller Again ? Al G[_2_] Home Built 65 July 12th 07 06:59 PM
airbus - Latest Plane From Airbus.jpg [email protected] Aviation Photos 14 June 26th 07 09:41 AM
Soviet Ekranoplan redux, FWIW Ogden Johnson III Naval Aviation 0 March 23rd 04 08:44 PM
