#21
I presume one reason high-bypass turbofans (A10) are preferred vice
turboprops is that in the balance the fans are a more economical choice. No props to get nicked, no gearbox to worry about, over-all less maintenance and less cost. And quieter - the Beech 1900s flying overhead here really howl when trying to make an ETA. Less noise is good when prowling around. But what is really good is a supersonic approach when dealing with a known show target- surprise! Walt BJ |
Abe wrote:
Helo engines are usually referred to as "turboshaft", which aside from sounding suspiciously like a porn film, is possibly just another name for a turboprop. A turboprop engine is configured so the output shaft will mount a propeller. It has thrust bearings and is geared to drive a propeller directly. A turboshaft delivers its output to a shaft which may be connected to nearly anything except directly to a propeller. Rick |
"Charles Gray" wrote in message ... On Tue, 6 Jan 2004 22:21:45 -0000, Abe wrote: On a modern battlefield, I wouldn't give the A-10 much of a life span. It might armoured like a tank, but it's sitting duck. How would the A-10 survive in a theatre full of modern vehicle-mounted SAMs, I wonder? Not well-- if you sent it in alone. However, with SEAD it would do pretty well-- A-10's in the first gulf war took plenty of fire from shoulder fired SAMs' as well as cannon fire and came back in a landable condition-- imagine an F-22 or F-35 doing the same. Also, unlike the faster, more "sexy" aircraft, slow CAS can loiter in the area, prepared to shoot up the odd target. But doesn't it sort of defeat the very idea of "survivable combat aircraft" when you need a SEAD package et al to keep it alive? Sure, passive protection will increase your survival chances in case of hit but does it really help if you're so slow that you get hit much more often? It should also be noted that During Desert Storm, A-10's did very well: Actually, A-10 operations to some well-defended areas were restricted after some were shot down. Against something like Crotale or SA-15, I'd rate A-10's survival odds as very low. Or gun systems like Marksman, Tunguska...those have _very high_ hit probabilities. A turboprop CAS plane would be even more vulnerable. Of course, if you're content about bombing some hapless natives, then maybe you don't have to worry about such threats and slow attack planes are viable. |
"Abe" wrote in message ... In article , says... "Abe" wrote in message ... In article dGKKb.8616$6l1.5192@okepread03, says... Would a helicopter count as a turboprop? Turbo-blade? :-) Helo engines are usually referred to as "turboshaft", which aside from sounding suspiciously like a porn film, is possibly just another name for a turboprop. I wonder what the V-22 engines are. Turboprop when facing forward, turboshaft when facing upward? ![]() Isn't the presence of a transmission in the latter what helps delineate it from the former? Turboprops have transmissions also, I'm sure. At least, you'd need to put some gearing between engine and props. Some gearing yes; but I don't think they have anything as complex as the transmissions employed on helos. Just a guess, though. Brooks |
Abe wrote:
I'm a bit hazy on the difference here. Are you saying a turboprop has no reduction gearing between engine and propellor? No, a turboprop engine has reduction gearing between the power turbine and the propeller shaft. The output shaft on a turboprop engine is the propeller shaft, it is reduced in speed to that required by the propeller and incorporates a thrust bearing to transfer thrust to the engine mounts. If it does have gearing, then I'm not sure of the clear-cut difference between that and a more complex transmission. Could you elaborate? If by "more complex transmission" you mean that of a turboshaft then you are still a bit confused. The "transmission" or reduction gear can and often is very simple and less complicated than that of a turboprop engine. Some turboshaft engines do not even have a reduction gear or transmission, the power turbine is designed to turn at the required speed for the application. Look at it as a turboprop is only made to turn a propeller. A turboshaft can turn everything else Rick |
#28
"Kevin Brooks" wrote:
"Abe" wrote in message .. . In article , says... "Abe" wrote in message ... In article dGKKb.8616$6l1.5192@okepread03, says... Would a helicopter count as a turboprop? Turbo-blade? :-) Helo engines are usually referred to as "turboshaft", which aside from sounding suspiciously like a porn film, is possibly just another name for a turboprop. I wonder what the V-22 engines are. Turboprop when facing forward, turboshaft when facing upward? ![]() Isn't the presence of a transmission in the latter what helps delineate it from the former? Turboprops have transmissions also, I'm sure. At least, you'd need to put some gearing between engine and props. Some gearing yes; but I don't think they have anything as complex as the transmissions employed on helos. Just a guess, though. Brooks Yes, that's roughly correct AFIK. I know turboprops but not Helicopters and I'd think that helicopters would require much more complicated transmissions. Turboprops aren't very complicated, just quite rugged, about 10 to 1 or so reduction planetary gear-train with a 'torsion bar' type of driveshaft to measure torque and some method of preventing the prop from driving the engine ( -- -Gord. |
#29
Rick wrote:
Abe wrote: Helo engines are usually referred to as "turboshaft", which aside from sounding suspiciously like a porn film, is possibly just another name for a turboprop. A turboprop engine is configured so the output shaft will mount a propeller. It has thrust bearings and is geared to drive a propeller directly. A turboshaft delivers its output to a shaft which may be connected to nearly anything except directly to a propeller. Rick What aircraft would use that setup Rick? I can't imagine how you could drive a prop directly from a turbine engine with no reduction gearing? (or did I misread you?) -- -Gord. |
#30
"Gord Beaman" wrote in message ... "Kevin Brooks" wrote: "Abe" wrote in message .. . In article , says... "Abe" wrote in message ... In article dGKKb.8616$6l1.5192@okepread03, says... Would a helicopter count as a turboprop? Turbo-blade? :-) Helo engines are usually referred to as "turboshaft", which aside from sounding suspiciously like a porn film, is possibly just another name for a turboprop. I wonder what the V-22 engines are. Turboprop when facing forward, turboshaft when facing upward? ![]() Isn't the presence of a transmission in the latter what helps delineate it from the former? Turboprops have transmissions also, I'm sure. At least, you'd need to put some gearing between engine and props. Some gearing yes; but I don't think they have anything as complex as the transmissions employed on helos. Just a guess, though. Brooks Yes, that's roughly correct AFIK. I know turboprops but not Helicopters and I'd think that helicopters would require much more complicated transmissions. Turboprops aren't very complicated, just quite rugged, about 10 to 1 or so reduction planetary gear-train with a 'torsion bar' type of driveshaft to measure torque and some method of preventing the prop from driving the engine ( Thanks. I don't know squat about turboprops, but I do know that helo transmissions are typically pretty complex and are a rather common source of maintenance trouble, not to mention being one of the more vulnerable spots in terms of combat damage. Brooks -- -Gord. |
| Thread Tools | |
| Display Modes | |
