Cessna 150/150 Tow hook
Old July 14th 09, 06:00 PM posted to rec.aviation.soaring
Ed Byars
Default Cessna 150/150 Tow hook
Is there an STC for installing a Schweizer hook on a 150/150? I could just
follow 43.13-2B Chap.8 and get a field approval but I'm trying to minimize
the Fed involvement. Ideas?
Thanks,
Ed Byars
Old July 14th 09, 06:09 PM posted to rec.aviation.soaring
Mike Bamberg
On Jul 14, 10:00*am, "Ed Byars" wrote:
Is there an STC for installing a Schweizer hook on a 150/150? *I could just
Thanks,
Ed Byars
Check with Burt Compton.
I think he's flown several 150/150s as tow planes.
Mike
Old July 14th 09, 07:30 PM posted to rec.aviation.soaring
Tony Condon[_2_]
Burt has a Cessna 150 with 180HP. I'm pretty sure that a towhook was a
factory option from Cessna, but I can't remember or find any
documentation that supports that in a quick google search. I'm sure Burt
would be able to help you out.
www.flygliders.com will get you started to contact him if he doesnt check
in here.
-Tony Condon
Cherokee II N373Y
Old July 14th 09, 09:45 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
just follow 43.13-2B Chap.8 and get a field approval but I'm trying to
minimize the Fed involvement. Ideas?
Thanks,
Ed Byars
Look in the IPC (Illustrated Parts Catalog). I believe it is shown there
(I know it is on the 172 and 182). If it is shown there, there is no need
for any FAA involvement, as it is approved by Cessna. I know the 150 is
approved for towing (have seen the structural substantiation report).
And with it in the IPC, it needs, at the very most, an airframe mechanic
signature for the installation. It might even be an owner/operator
installable part, as it is less complicated than changing oil or a tire.
Steve Leonard
James Hamilton[_2_]
Burt
check
in here.
-Tony Condon
Cherokee II N373Y
Also, you might check with Jeff Campbell at a soaring operation in
Telluride, CO. He had a Cessna 150/180 at Parowan in 2005 and towed for
the contest there. Sorry I don't have an email address for Jeff or the
name of the soaring operation.
Jimmy Hamilton
JLH
Old July 14th 09, 11:14 PM posted to rec.aviation.soaring
vaughn[_2_]
"Steve Leonard" wrote in message
The IPC is he http://www.micro-tools.net/pdf/Cessna/150_pm_70-77.pdf
The tow hook is on Figure 50.
Vaughn
Tow Hook on Cessna 180 - Update Stuart Grant Soaring 13 April 10th 20 10:48 AM
CG Hook for 1-26? [email protected] Soaring 1 October 29th 06 01:21 AM
CG Hook for SGS 2-33 Rusty Soaring 0 November 23rd 05 12:15 PM
Tow Hook 337 for a 150-150 1JH Soaring 3 July 19th 05 06:35 PM
Tow Hook on Cessna 180? Stuart Grant Soaring 3 October 2nd 03 12:50 AM
