On pre-flight inspections
Old July 27th 09, 05:41 AM posted to rec.aviation.piloting
D Ramapriya
Default On pre-flight inspections
Has any of you has ever discovered something during the pre-flight
inspection that necessitated a significant deferrment of your flight
plan or a cancelation altogether? Just curious, that's all.
Thanks,
Ramapriya
Old July 27th 09, 05:52 AM posted to rec.aviation.piloting
Blanche
Thanks,
Ramapriya
Of course -- that's why pre-flight inspections exist!
John E. Carty
"D Ramapriya" wrote in message
Thanks,
Ramapriya
Leaking brake caliper along with one of the brake linings worn completely
down to the back plate :-)
Old July 27th 09, 06:14 AM posted to rec.aviation.piloting
Stealth Pilot[_2_]
On Sun, 26 Jul 2009 21:41:07 -0700 (PDT), D Ramapriya
Thanks,
Ramapriya
yes. carb heat came out way too far in the hand. the butterfly
actuator arm had fatigue failed of the end of the pivot shaft.
(poor design that had lasted 23 years in service)
dont stop doing them. years of successful action does not predict the
onset of a fatigue problem.
Stealth Pilot
Old July 27th 09, 06:46 AM posted to rec.aviation.piloting
Dudley Henriques[_2_]
Thanks,
Ramapriya
Yes; a stuffed bear in the carb intake duct. Removed bear, made
flight.
DH
Old July 27th 09, 06:59 AM posted to rec.aviation.piloting
D Ramapriya
On Jul 27, 9:14*am, Stealth Pilot
If something lasted 23 years of continuous service, poor design it
certainly can't be, what?
Stealth Pilot
Yep, that's the nature of the fatigue beast. I've known it in my own
industry (construction) for yonks.
Ramapriya
Old July 27th 09, 07:03 AM posted to rec.aviation.piloting
D Ramapriya
Thanks,
Ramapriya
flight.
DH
Probably sucked in during post-landing taxi to the apron from the
previous flight?
Ramapriya
Old July 27th 09, 07:36 AM posted to rec.aviation.piloting
Thanks,
Ramapriya
flight.
DH
previous flight?
Ramapriya
Nope. Saw the child who did it, although didn't actually see him do
it. He was being carried by his father on the line at one of our show
sites in 1971. Have used the incident in a hundred safety lectures on
pre-flights. I had preflighted the airplane for my next display and
had run across the ramp to grab a coke from a snack wagon. Saw the man
and his kid before I left. Came back and re-preflighted the airplane
again because it was out of my direct sight since I had done the last
one.
Caught the bear in the carb tunnel on the second preflight.
Rule number ONE for display pilots, and for all pilots for that matter
as far as I'm concerned anyway! ANYTIME the airplane is out of your
sight for ANY reason after you have done a preflight inspection, do it
again!
Dudley Henriques
Old July 27th 09, 08:04 AM posted to rec.aviation.piloting
Ron Garret
In article
Depends on what counts as "significant deferrment" and what counts as
"pre-flight". I've been delayed by an hour or so a couple of times, and
had to cancel once because of a rough engine during the run-up (turned
out to be lead fouling on the plugs, but we didn't find that out until
the following day). The delays were caused by a sheared bolt on a wheel
faring, and prop nick that had to be filed down. Those are the ones I
can remember offhand.
rg
Old July 27th 09, 08:13 AM posted to rec.aviation.piloting
D Ramapriya
previous flight?
Ramapriya
one.
again!
Dudley Henriques
Nice story
If only the two pilots on that fateful Aeroperu 603 had done one, 70
souls + an entire company + a nice 757 would all still have been alive
and functional.
Ramapriya
annual inspections [email protected] Soaring 1 October 20th 07 01:08 AM
100 Hour Inspections Judah Piloting 26 December 1st 06 02:30 PM
Homebuilt Inspections john smith Home Built 8 December 25th 04 02:20 PM
Time Measurement for Inspections O. Sami Saydjari Owning 15 April 7th 04 05:26 AM
Pre-buy inspections Paul Folbrecht Owning 12 March 1st 04 12:27 AM
