On pre-flight inspections
Old July 30th 09, 01:32 AM posted to rec.aviation.piloting
Brian Whatcott
Default Anonymous Posts/Sneers from Miss "Franklin".
Franklin wrote:
xxxxx's self-admitted failures are easy to read. See, he is not
complaining about my pointing out his failures.
Why do you?
Franklin
Dear Anonymous poster signing as "Franklin": DO be a good girl and run
home, won't you? This is where the big boys write.....
Brian W
Old July 31st 09, 09:26 AM posted to rec.aviation.piloting
Franklin[_11_]
Default On pre-flight inspections
Stealth Pilot wrote:
On Mon, 27 Jul 2009 18:14:03 -0400, Franklin "Franklin
On Mon, 27 Jul 2009 14:30:57 -0500, Maxwell wrote:
Badly frayed cable on the horizontal stabilizer. AI caught it while
fueling the aircraft. Showed it to the pilot who decided it would
make back home, about 30 miles. AI actually begged his pax to stay
behind. At about 200' on take off the cable failed. Aircraft did a
complete loop impacting the ground at about a 60 degree angle.
Nothing left of the aircraft more than knee high. Engine buried
about 2'. Pilot died instantly, but the pax with all broken bones,
struggled for help for almost 5 minutes before expiring.
The guilt you should feel for not stopping both of them. What a cad
you are.
Franklin
franklin you should be ashamed of yourself.
you have no details of the incident other than what maxwell posted so
you are not in a position to judge him.
you have no idea what condition the cable actually was.
if the aircraft was refuelling it made the last flight ok and there is
nothing to say that the pilot may have been correct.
in this world you are free to make your own choices ...and wear the
consequences.
when was the last time you flew an aircraft?
tragic as it was maxwell isnt to blame.
Stealth pilot
Both "Maxwell" and "Franklin " are both socks by the
same puppeteer. His socks are insulting one another.
I posted something similar to the following to Ramapriya:
-------------- START -------
Please excuse my namesake's behavior. Unfortunately he's a sock who is
antagonising you in the hope that you will retaliate against me. That
sock has a long history and lots of names. He spends his day setting up
elaborate trolls with carefully disguised identities.
(1) In alt.comp.freeware he's well-known as "Bear Bottoms", "Ari", David
W" and literally dozens of other names.
(2) In the aviation groups he's known as Maxwell, Payton Byrd and many
other names which posters here know better than I do.
(3) He hangs out on 1960s/1970s music groups like the Beatles, Zeppelin,
Doors, Genesis, Jethro Tull, and so on.
(4) Unsurprisingly, a k00k like him hangs out on the 2600 and hacking
groups.
Although retired, he still fantasizes about being a pilot or special forces
operative which is why you see a lot of him. The only thing he can fly is
a toy airplane.
His attempts to be irritating:
http://groups.google.ru/group/alt.comp.freeware/msg/a46d34973796b1f6
http://groups.google.ru/group/alt.comp.freeware/msg/672961a0af8ac7d6
http://groups.google.ru/group/alt.comp.freeware/msg/5ae56dab596230fa
http://groups.google.ru/group/alt.comp.freeware/msg/fd54722dd2020e57
http://groups.google.ru/group/alt.comp.freeware/msg/e522b0bedbe2bb0a
-------------- END -------
Old July 31st 09, 06:36 PM posted to rec.aviation.piloting
Maxwell[_2_]
"Franklin" wrote in message
groups.
forces
a toy airplane.
The rest may be true, but I'm Maxwell, and I haven't seen anyone use my name
in several months.
Old July 28th 09, 02:47 AM posted to rec.aviation.piloting
BT
"parking" brake on a Cessna 172 came out in my hand
"bad mag check", as in the engine would not even run on one mag.. it was
totally dead, that has happened more than once on various aircraft.
"a funny noise" in the full deflection of the elevator, found a screw that
was too long had been used to anchor an inspection panel and the lengthy end
was rubbing on the trim spring
just to name a few
"D Ramapriya" wrote in message
Has any of you has ever discovered something during the pre-flight
inspection that necessitated a significant deferrment of your flight
plan or a cancelation altogether? Just curious, that's all.
Thanks,
Ramapriya
Old July 28th 09, 03:25 AM posted to rec.aviation.piloting
Dave[_22_]
Thanks,
Ramapriya
Did the usual walk-around and found nothing amiss. Then fired up the
engine only to see the tach come up, then drop back to zero (engine
running).
It was more than just a bad tach - the engine was toast (making lots
of metal). Not really unexpected, as it was suspect when we bought the
plane
about a year earlier (and figured into the purchase price). Replaced
it with a reman - which has proven to be a good decision.
Dave
Old July 28th 09, 04:24 AM posted to rec.aviation.piloting
BeechSundowner
Thanks,
Ramapriya
Rubbing noise when checking aileron = interconnect spring came off -
canceled flight
Bad mag during runup couldn't clear - canceled flight
Old July 28th 09, 06:20 PM posted to rec.aviation.piloting
Ross
Thanks,
Ramapriya
Yes.
Regards, Ross
C-172F 180HP
Sold
KSWI
Old July 29th 09, 05:40 PM posted to rec.aviation.piloting
Franklin[_7_]
Thanks,
Ramapriya
Yes.
Ross
Excellent post. I see you have figured out that D. Rampawhatever is a
troll. Good catch.
Franklin
Old July 30th 09, 04:37 AM posted to rec.aviation.piloting
Alan Gerber
Landing light inop before night X-C, scrubbed flight.
Failed attitude indicator, scrubbed flight.
Aircraft overdue for annual inspection, scrubbed flight.
Carcass of bird found on leading edge of wing. Had dispatcher remove it,
conducted flight as scheduled.
.... Alan
Alan Gerber
PP-ASEL
gerber AT panix DOT com
Old August 3rd 09, 06:50 PM posted to rec.aviation.piloting
Gene Seibel
Thanks,
Ramapriya
Yeah, mechanic told me the airplane would be ready Saturday morning.
Preflight revealed that airplane was still in pieces on his shop
floor.
Then there was the time a snow plow had clipped a tie down and pulled
a strut out of the wing.
Gene Seibel
Tales of flight - http://pad39a.com/gene/tales.html
Because we fly, we envy no one.
annual inspections [email protected] Soaring 1 October 20th 07 01:08 AM
100 Hour Inspections Judah Piloting 26 December 1st 06 02:30 PM
Homebuilt Inspections john smith Home Built 8 December 25th 04 02:20 PM
Time Measurement for Inspections O. Sami Saydjari Owning 15 April 7th 04 05:26 AM
Pre-buy inspections Paul Folbrecht Owning 12 March 1st 04 12:27 AM
