VW Heads -- Part 2
Old August 6th 09, 06:40 AM posted to rec.aviation.homebuilt
Veeduber[_2_]
Default VW Heads -- Part 2
CC'ing Your Heads... seems to generate more messages than any of the
other head-related chores. Which is only fair since cc'ing your heads
is one of the most important tasks in building a reliable engine.
Some argue that cc'ing isn't necessary with stock heads since the spec
for stock chambers is good enough. This is called Good Enough
Engineering. The truth is, the stock spec can vary by as much as 4cc
across four chambers and that's really terrible. With nothing more
than a 50cc syringe you can adjust the chamber volume to within 1cc
across four chambers.
The very first thing you want to do is to mark your heads and the
combustion chambers. Use a broad-tipped Magic Marker and keep it
simple, such as A and B for the heads and 1 and 2 for the chambers.
What Solution Should I Use?
Water. About a gallon of it. Add two drops of liquid detergent to
defeat the waters surface tension. Then add food coloring... which
will help you read the fluid level.
Drying the Chambers
After each measurement you must empty the fluid from the chamber.
Just pouring out the solution won't do... the chambers must be
PERFECTLY dry. That means blowing them out with compressed air,
either canned or pumped. But even that won't get all the fluid out of
the spark plug. So do this: After pouring out the fluid and wiping
the chamber with a cloth or paper towel, give it a shot of 70% alcohol
THEN blow them dry.
The Syringe is Too Small...
....meaning your chambers are larger than 50cc. So put a couple of
marbles in it.
Seriously. Suck up a full syringe of solution then pull the plunger
out of the syringe while keeping your thumb over the outlet. Using
your thumb, allow about half of the fluid to escape back into the
bucket or whatever. Do this carefully, so that the fluid comes into
alignment with one of the marks. Then drop a marble into the syringe
and record its volume. That is, see how much the fluid rises. The
volume of the marble will be equal to the difference between your
first reading and the second. Now do it again for a SECOND marble.
Chamber volume can vary by quite a bit. Your first effort is to
determine their approximate volume so you'll know how many marbles
you're going to need.
Using a burette and a jig to hold the head(s) level will make the work
a lot easier.
Your accuracy will improve if you cc each chamber a multiple number of
times for each step. For a stock head that means cc'ing each chamber
about a dozen times. If you must open up the chambers it will mean a
lot of grinding and measuring, but it's bench-work -- you can make
yourself a little work station and take all the time you need to get
it right.
The Compression Ratio equation will tell you how many cc's the
chambers should be to give the desired CR. The odds are, you'll have
to open them up by quite a bit to match the equation. And that means
you'll need to measure their cc's a multiple number of times.
Something to remember is that in many cases you only have to work on
THREE chambers, not four. That is, the largest chamber may not need
any work at all. All you have to do is open up the other three so
they match the volume of the largest chamber.
Some people worry about not having any experience cc'ing heads but if
you think about it, if you measure each chamber a multiple number of
times, by the time you get done you will have gained plenty of
experience.
-R.S.Hoover
Old August 6th 09, 02:50 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Wed, 5 Aug 2009 21:40:48 -0700 (PDT), Veeduber
-R.S.Hoover
magic stuff bob
dont think we're not reading
Stealth Pilot
Old August 6th 09, 07:17 PM posted to rec.aviation.homebuilt
RST Engineering - JIm
"Veeduber" wrote in message
Couldn't you just drop BBs into the largest chambers to bring them down to
the smallest?
Old August 6th 09, 09:21 PM posted to rec.aviation.homebuilt
Bob
the smallest?
Dear Jim,
I don't understand.
The initial goal is to determine the volume of the LARGEST cylinder.
The marble trick allows us to measure a volume that is GREATER than
the 50cc volume of our syringe.
For example, let's assume our marbles are equal to 20cc. We dry the
marbles, place them in the chamber to be measured, install the cover
plate then fill the chamber with fluid. If it takes 37cc of fluid to
fill the chamber then its actual volume will be 57cc. I don't see any
benefit from using BB's. In fact, I can imagine several situations
where the BB's would be a real PTA to work with.
But I'm always willing to learn, especially from someone with your
credentials.
-R.S.Hoover
Old August 7th 09, 06:26 AM posted to rec.aviation.homebuilt
jerry wass
Drying the Chambers
THEN blow them dry.
marbles in it.
a lot easier.
it right.
experience.
-R.S.Hoover
At the risk of repeating myself--A veterinary supply has all sizes of
hypodeemic nurdles, syringes, etc. Atwoods farm stores here in the
Southwest--most feed & seed stores catering to large animals. Jerry
Old August 7th 09, 07:22 AM posted to rec.aviation.homebuilt
Bob
On Aug 6, 9:26*pm, Jerry Wass wrote:
At the risk of repeating myself-.....
Dear Jerry,
Good. KEEP repeating yourself. The internet is not static, the
audience changes from minute to minute.
The message for VW engines is fairly simple but it NEEDS to be
repeated. Guys who already have the information may complain but the
guys who don't won't.
When you're talking about VW engines you're really talking about their
heads. Everything else is fairly sturdy; the kind of stuff that
breaks LAST. But it's the valves that break first. If you're flying
behind a VW you quickly learn what's sturdy and what's not. The
heads... the exhaust valves... are the weak link, be it Volkswagen or
Pratt-Whitney.
A VW engine attached to a fuselage with a couple of wings-worth of
lift and some scooter wheels on the bottom will allow you to get in
those ten hours a month that makes the difference between a pilot and
someone who drives an airplane. Doesn't matter if the thing is a
Teenie Two or a VP1, it's still a flying machine, more than able to
keep your skills well honed.
A leak-down test will tell you WHEN. Having built your own engine
tells you HOW. Pull the heads, toss the exhaust valves, re-lap the
intakes, button it back up, you're looking at a couple of evenings
work. Leak-down not only tells you when, it allows you to SCHEDULE
the when.
Better still, buy yourself a pair of NEW heads and machine them so
they are IDENTICAL to the set that's flying the bird now. When the
leak-down test tells you when, all you gotta do is pull the old heads,
replace them with the new heads, and keep on flying. You've got at
least five or six months in which to tear down the old heads and
return them to service.
-R.S.Hoover
Old August 7th 09, 08:10 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
Bob wrote:
On Aug 6, 9:26 pm, Jerry Wass wrote:
If you're flying
behind a VW
Old August 7th 09, 08:09 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
Jerry Wass wrote:
-R.S.Hoover
Mine come from the local Tractor Supply.
Old August 12th 09, 01:57 AM posted to rec.aviation.homebuilt
Dan D[_2_]
....and for heavens sake...Don't loose your marbles!
Good stuff Bob!
VW Heads -- Part 1 Veeduber[_2_] Home Built 0 August 5th 09 12:51 AM
More New Heads [email protected] Home Built 6 January 27th 09 06:55 PM
CC'ing Your Heads [email protected] Home Built 6 January 22nd 09 03:03 AM
New Heads [email protected] Home Built 2 January 20th 09 08:03 PM
SCAM - Heads up DaveSpringford Soaring 0 December 5th 03 12:13 AM
