On Aug 6, 10:17*am, "RST Engineering - JIm" wrote:
Couldn't you just drop BBs into the largest chambers to bring them down to the smallest? ------------------------------------------------------------------------------------------------ Dear Jim, I don't understand. The initial goal is to determine the volume of the LARGEST cylinder. The marble trick allows us to measure a volume that is GREATER than the 50cc volume of our syringe. For example, let's assume our marbles are equal to 20cc. We dry the marbles, place them in the chamber to be measured, install the cover plate then fill the chamber with fluid. If it takes 37cc of fluid to fill the chamber then its actual volume will be 57cc. I don't see any benefit from using BB's. In fact, I can imagine several situations where the BB's would be a real PTA to work with. But I'm always willing to learn, especially from someone with your credentials. -R.S.Hoover |
VW Heads -- Part 1 | Veeduber[_2_] | Home Built | 0 | August 4th 09 11:51 PM |
More New Heads | [email protected] | Home Built | 6 | January 27th 09 05:55 PM |
CC'ing Your Heads | [email protected] | Home Built | 6 | January 22nd 09 02:03 AM |
New Heads | [email protected] | Home Built | 2 | January 20th 09 07:03 PM |
SCAM - Heads up | DaveSpringford | Soaring | 0 | December 4th 03 11:13 PM |
