Cross Country Sailplanes: In the Flatland
Old August 10th 09, 05:30 AM posted to rec.aviation.soaring
Chris Prince
Default Cross Country Sailplanes: In the Flatland
[Snip]
Std Jantar 2 sits tall on the gear and is pretty honest about 1/40,
better than the DG100/101. DG has a bit nicer handling with
parallelogram stick, but loses on performance. Very strong though.
Payload should be okay. Have you seen Adam's Jantar?
PIK-20B if you want a bit more performance and landing flaps. They
may be hard to rig after the temp exceeds 70F or so.
EDS with composite tank won't add much weight to either and will
lighten your wallet a bit.
Frank Whiteley
Thanks for your thoughts, Frank! (I'm not quite understanding the "EDS
with composite tank" part of this though.)
Chris.
Cross Country again! Michelle Piloting 10 August 6th 06 06:45 PM
Cross country in the 1-34 mat Redsell Soaring 3 October 22nd 04 04:56 PM
51.2 Hours Cross Country PIC, NW_PILOT Piloting 6 July 3rd 04 03:02 AM
US cross country flight S Narayan Piloting 0 January 7th 04 02:58 PM
A 4,200 NM cross-country Phil Verghese Piloting 0 September 1st 03 10:03 PM
