Question about blipmaps
Old August 24th 09, 07:22 PM posted to rec.aviation.soaring
Spam
Default Question about blipmaps
Alright here's a question about top of useable lift for the blipmaps.
If the thermal tops are 7,000
and the cloudbases are 5,000
and the top of useable lift is 4,000
Does this mean that when you get to 4,000 you will have risen to the
top and can only circle around in zero sink there?
Old August 24th 09, 08:45 PM posted to rec.aviation.soaring
Tony Condon
by top of useable lift do you mean the hcrit parameter?
if so then that is supposedly approximately the alititude where you will
no longer be able to climb. be careful though, the NAM and RUC forecasts
(at least around here) are often a bit optimistic on the temperature and
dew points, which skews the forecast vs. reality. remember that the
forecast temperature, dew point, sun heating, and everything else has to
line up in order for the lift forecast to be valid as well.
-Tony Condon
Cherokee II N373Y
Old August 24th 09, 08:50 PM posted to rec.aviation.soaring
[email protected][_2_]
Cherokee II N373Y
My experience is that the "top of useable lift" is conservative; I
find the NAM "Height of the Boundary Layer" to more accurately predict
how high the "best" thermals will go. This from extensive soaring in
Arizona and Illinois. YMMV, of course ;^)
Kirk
66
Old August 25th 09, 01:47 AM posted to rec.aviation.soaring
BT
remember that "thermal tops" is where the thermal either hits an inversion
layer or "the lifted air mass" has cooled to the actual temperature. The
difference between "expected lapse rate temperature" and "actual measured
temperature" becomes zero
for gliders to effectively be able to climb, they need a "thermal index" or
difference in temperatures between actual and expected lapse rate of
about -3. Considering the std lapse rate of about 2.5C per 1000ft, that
works out.
There may still be some lift at 4000ft, most gliders have a "sink rate" of
about 1.2 to 1.7knts (120fpm) and if the lifting air mass has slowed or
reached about the same... then yes.. you may have reached "zero sink".
The other posted responses cover what they use in the forecast to best
determine the "lift band"
BT
"Spam" wrote in message
BLIPMAPS and GPS_LOG Henryk Birecki Soaring 0 June 7th 07 10:19 PM
Blipmaps Tom Ruble Soaring 4 May 27th 04 02:48 AM
ETA BLIPMAPs DrJack Soaring 0 March 1st 04 03:18 AM
Dr Jack's BLIPMAPS Jim Soaring 7 December 2nd 03 08:44 PM
Contribute to BLIPMAPS (was Biting the (weather) hand that feeds) Mark James Boyd Soaring 0 August 12th 03 09:40 PM
