Flaps_50! wrote:
On Sep 3, 6:37Â*am, BeechSundowner wrote: On Sep 2, 2:24Â*am, "Flaps_50!" wrote: You really don't (or won't) get it? ------------- § 91.303 Â* Aerobatic flight. No person may operate an aircraft in aerobatic flight— (a) Over any congested area of a city, town, or settlement; (b) Over an open air assembly of persons; (c) Within the lateral boundaries of the surface areas of Class B, Class C, Class D, or Class E airspace designated for an airport; (d) Within 4 nautical miles of the center line of any Federal airway; For the purposes of this section, aerobatic flight means an intentional maneuver involving an abrupt change in an aircraft's attitude, an abnormal attitude, or abnormal acceleration, not necessary for normal flight." --------- What does "for normal flight" mean? Cheers- Hide quoted text - - Show quoted text - No you don't get it. Â*I was not within A, B, C or D as described that you allude to above. Â*I was in a designated practice area. I wasn't performing normal flight. Â*I was performing an emergency procedure. Â*What part do YOU not get. I don't think you read it carefully. The regs don't say within ABCD airspace, but within _lateral_ limits of those airspaces. Since you communicated with ATC I assume you were below one of those airspaces and therefore within its lateral limits (not vertical). Also how far away was the nearest highway? Cheers Designated practice areas are not within any limits of those airspaces nor are they near any airway. There is a reason for that. One can communicate with ATC in any type of airspace. Your objections are nonsense. -- Jim Pennino Remove .spam.sux to reply. |
On Sep 3, 5:15*pm, wrote:
Flaps_50! wrote: On Sep 3, 6:37*am, BeechSundowner wrote: On Sep 2, 2:24*am, "Flaps_50!" wrote: You really don't (or won't) get it? ------------- § 91.303 * Aerobatic flight. No person may operate an aircraft in aerobatic flight— (a) Over any congested area of a city, town, or settlement; (b) Over an open air assembly of persons; (c) Within the lateral boundaries of the surface areas of Class B, Class C, Class D, or Class E airspace designated for an airport; (d) Within 4 nautical miles of the center line of any Federal airway; For the purposes of this section, aerobatic flight means an intentional maneuver involving an abrupt change in an aircraft's attitude, an abnormal attitude, or abnormal acceleration, not necessary for normal flight." --------- What does "for normal flight" mean? Cheers- Hide quoted text - - Show quoted text - No you don't get it. *I was not within A, B, C or D as described that you allude to above. *I was in a designated practice area. I wasn't performing normal flight. *I was performing an emergency procedure. *What part do YOU not get. I don't think you read it carefully. The regs don't say within ABCD airspace, but within _lateral_ limits of those airspaces. Since you communicated with ATC I assume you were below one of those airspaces and therefore within its lateral limits (not vertical). *Also how far away was the nearest highway? Cheers Designated practice areas are not within any limits of those airspaces nor are they near any airway. I disagree, practice areas are often below designated airspace. It's the lateral limits that can be a gotcha for aerobatics. Cheers |
Flaps_50! wrote:
On Sep 3, 5:15Â*pm, wrote: Flaps_50! wrote: On Sep 3, 6:37Â*am, BeechSundowner wrote: On Sep 2, 2:24Â*am, "Flaps_50!" wrote: You really don't (or won't) get it? ------------- § 91.303 Â* Aerobatic flight. No person may operate an aircraft in aerobatic flight— (a) Over any congested area of a city, town, or settlement; (b) Over an open air assembly of persons; (c) Within the lateral boundaries of the surface areas of Class B, Class C, Class D, or Class E airspace designated for an airport; (d) Within 4 nautical miles of the center line of any Federal airway; For the purposes of this section, aerobatic flight means an intentional maneuver involving an abrupt change in an aircraft's attitude, an abnormal attitude, or abnormal acceleration, not necessary for normal flight." --------- What does "for normal flight" mean? Cheers- Hide quoted text - - Show quoted text - No you don't get it. Â*I was not within A, B, C or D as described that you allude to above. Â*I was in a designated practice area. I wasn't performing normal flight. Â*I was performing an emergency procedure. Â*What part do YOU not get. I don't think you read it carefully. The regs don't say within ABCD airspace, but within _lateral_ limits of those airspaces. Since you communicated with ATC I assume you were below one of those airspaces and therefore within its lateral limits (not vertical). Â*Also how far away was the nearest highway? Cheers Designated practice areas are not within any limits of those airspaces nor are they near any airway. I disagree, practice areas are often below designated airspace. It's the lateral limits that can be a gotcha for aerobatics. Cheers Technically, EVERYTHING is below class A. -- Jim Pennino Remove .spam.sux to reply. |
On Sep 4, 2:30*am, wrote:
Flaps_50! wrote: On Sep 3, 5:15*pm, wrote: Flaps_50! wrote: On Sep 3, 6:37*am, BeechSundowner wrote: On Sep 2, 2:24*am, "Flaps_50!" wrote: You really don't (or won't) get it? ------------- § 91.303 * Aerobatic flight. No person may operate an aircraft in aerobatic flight— (a) Over any congested area of a city, town, or settlement; (b) Over an open air assembly of persons; (c) Within the lateral boundaries of the surface areas of Class B, Class C, Class D, or Class E airspace designated for an airport; (d) Within 4 nautical miles of the center line of any Federal airway; For the purposes of this section, aerobatic flight means an intentional maneuver involving an abrupt change in an aircraft's attitude, an abnormal attitude, or abnormal acceleration, not necessary for normal flight." --------- What does "for normal flight" mean? Cheers- Hide quoted text - - Show quoted text - No you don't get it. *I was not within A, B, C or D as described that you allude to above. *I was in a designated practice area. I wasn't performing normal flight. *I was performing an emergency procedure. *What part do YOU not get. I don't think you read it carefully. The regs don't say within ABCD airspace, but within _lateral_ limits of those airspaces. Since you communicated with ATC I assume you were below one of those airspaces and therefore within its lateral limits (not vertical). *Also how far away was the nearest highway? Cheers Designated practice areas are not within any limits of those airspaces nor are they near any airway. I disagree, practice areas are often below designated airspace. It's the lateral limits that can be a gotcha for aerobatics. Cheers Technically, EVERYTHING is below class A. Yes, but the FAR doesn't include class A :-) Cheers |
Flaps_50! wrote: On Sep 3, 6:37*am, BeechSundowner wrote: On Sep 2, 2:24*am, "Flaps_50!" wrote: You really don't (or won't) get it? ------------- § 91.303 * Aerobatic flight. No person may operate an aircraft in aerobatic flight— (a) Over any congested area of a city, town, or settlement; (b) Over an open air assembly of persons; (c) Within the lateral boundaries of the surface areas of Class B, Class C, Class D, or Class E airspace designated for an airport; (d) Within 4 nautical miles of the center line of any Federal airway; For the purposes of this section, aerobatic flight means an intentional maneuver involving an abrupt change in an aircraft's attitude, an abnormal attitude, or abnormal acceleration, not necessary for normal flight." --------- What does "for normal flight" mean? Cheers- Hide quoted text - - Show quoted text - No you don't get it. *I was not within A, B, C or D as described that you allude to above. *I was in a designated practice area. I wasn't performing normal flight. *I was performing an emergency procedure. *What part do YOU not get. I don't think you read it carefully. The regs don't say within ABCD airspace, but within _lateral_ limits of those airspaces. Since you communicated with ATC I assume you were below one of those airspaces and therefore within its lateral limits (not vertical). *Also how far away was the nearest highway? Cheers Designated practice areas are not within any limits of those airspaces nor are they near any airway. There is a reason for that. One can communicate with ATC in any type of airspace. Your objections are nonsense. How do you know where he was? My point is that its the _lateral_ limits of airspace that can be a no-no for aerobatics. In places, practice areas may be below other airspace... Cheers |
On Sep 3, 6:47*am, "Flaps_50!" wrote:
How do you know where he was? I TOLD YOU. I was in a designated practice area. What part of that do you not understand outside of ASSuming? Look up KJAN and 10 miles NE of the outershelf of Charlie is the designated practice area. My point is that its the _lateral_ limits of airspace that can be a no-no for aerobatics. In places, practice areas may be below other airspace... Your point was irrelevant to my situation for two reasons. One is above. Second was that I was not conducting aerobatics. What part of that do you NOT understand? |
"Flaps_50!" wrote
How do you know where he was? My point is that its the _lateral_ limits of airspace that can be a no-no for aerobatics. In places, practice areas may be below other airspace... You demonstrate that you don't fully understand the pertinent FAR which I post below. The operable phrase is "of the SURFACE AREA", not the entire airspace. "SURFACE AREA"s are normally a 5 mile radius around the airport for which the airspace is designated. In reading the regulation, I find no prohibition against conducting aerobatics underneith the outer rings of a Class B,C,airspace, although, since the outer ring of Class C airspace can be as low as 1200'AGL, considering 91.303(e), aerobatics might not be allowed. Bob Moore Flying since 1958 CFIing since 1970 Section 91.303: Aerobatic flight. No person may operate an aircraft in aerobatic flight— (a) Over any congested area of a city, town, or settlement; (b) Over an open air assembly of persons; (c) Within the lateral boundaries of the surface areas of Class B, Class C, Class D, or Class E airspace designated for an airport; (d) Within 4 nautical miles of the center line of any Federal airway; (e) Below an altitude of 1,500 feet above the surface; or (f) When flight visibility is less than 3 statute miles. For the purposes of this section, aerobatic flight means an intentional maneuver involving an abrupt change in an aircraft's attitude, an abnormal attitude, or abnormal acceleration, not necessary for normal flight. |
On Sep 4, 1:31*am, Robert Moore wrote:
"Flaps_50!" wrote How do you know where he was? My point is that its the _lateral_ limits of airspace that can be a no-no for aerobatics. In places, practice areas may be below other airspace... You demonstrate that you don't fully understand the pertinent FAR which I post below. The operable phrase is "of the SURFACE AREA", not the entire airspace. "SURFACE AREA"s are normally a 5 mile radius around the airport for which the airspace is designated. In reading the regulation, I find no prohibition against conducting aerobatics underneith the outer rings of a Class B,C,airspace, although, since the outer ring of Class C airspace can be as low as 1200'AGL, considering 91.303(e), aerobatics might not be allowed. Bob Moore Flying since 1958 CFIing since 1970 Section 91.303: Aerobatic flight. No person may operate an aircraft in aerobatic flight— (a) Over any congested area of a city, town, or settlement; (b) Over an open air assembly of persons; (c) Within the lateral boundaries of the surface areas of Class B, Class C, Class D, or Class E airspace designated for an airport; (d) Within 4 nautical miles of the center line of any Federal airway; (e) Below an altitude of 1,500 feet above the surface; or (f) When flight visibility is less than 3 statute miles. For the purposes of this section, aerobatic flight means an intentional maneuver involving an abrupt change in an aircraft's attitude, an abnormal attitude, or abnormal acceleration, not necessary for normal flight. Nope. The FAR is quite clear. It says noting about surface area around an airport. Just the _lateral limits_ of B,C,D,E airspace. Read it again. Cheers |
In article
, "Flaps_50!" wrote: On Sep 4, 1:31*am, Robert Moore wrote: "Flaps_50!" wrote How do you know where he was? My point is that its the _lateral_ limits of airspace that can be a no-no for aerobatics. In places, practice areas may be below other airspace... You demonstrate that you don't fully understand the pertinent FAR which I post below. The operable phrase is "of the SURFACE AREA", not the entire airspace. "SURFACE AREA"s are normally a 5 mile radius around the airport for which the airspace is designated. In reading the regulation, I find no prohibition against conducting aerobatics underneith the outer rings of a Class B,C,airspace, although, since the outer ring of Class C airspace can be as low as 1200'AGL, considering 91.303(e), aerobatics might not be allowed. Bob Moore Flying since 1958 CFIing since 1970 Section 91.303: Aerobatic flight. No person may operate an aircraft in aerobatic flight‹ (a) Over any congested area of a city, town, or settlement; (b) Over an open air assembly of persons; (c) Within the lateral boundaries of the surface areas of Class B, Class C, Class D, or Class E airspace designated for an airport; (d) Within 4 nautical miles of the center line of any Federal airway; (e) Below an altitude of 1,500 feet above the surface; or (f) When flight visibility is less than 3 statute miles. For the purposes of this section, aerobatic flight means an intentional maneuver involving an abrupt change in an aircraft's attitude, an abnormal attitude, or abnormal acceleration, not necessary for normal flight. Nope. The FAR is quite clear. It says noting about surface area around an airport. Just the _lateral limits_ of B,C,D,E airspace. Read it again. Huh? This is the text of 91.303(c), emphasis added: "Within the lateral boundaries of the SURFACE AREAS of Class B, Class C, Class D, or Class E airspace designated for an airport;" Seems pretty clear to me that it's talking about, well, the SURFACE AREAS, since it uses those exact words. That is the only section of 91.303 which makes reference to those airspace types. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
"Flaps_50!" wrote How do you know where he was? My point is that its the _lateral_ limits of airspace that can be a no-no for aerobatics. In places, practice areas may be below other airspace... You demonstrate that you don't fully understand the pertinent FAR which I post below. The operable phrase is "of the SURFACE AREA", not the entire airspace. "SURFACE AREA"s are normally a 5 mile radius around the airport for which the airspace is designated. In reading the regulation, I find no prohibition against conducting aerobatics underneith the outer rings of a Class B,C,airspace, although, since the outer ring of Class C airspace can be as low as 1200'AGL, considering 91.303(e), aerobatics might not be allowed. Bob Moore Flying since 1958 CFIing since 1970 Section 91.303: Aerobatic flight. No person may operate an aircraft in aerobatic flight— (a) Over any congested area of a city, town, or settlement; (b) Over an open air assembly of persons; (c) Within the lateral boundaries of the surface areas of Class B, Class C, Class D, or Class E airspace designated for an airport; (d) Within 4 nautical miles of the center line of any Federal airway; (e) Below an altitude of 1,500 feet above the surface; or (f) When flight visibility is less than 3 statute miles. For the purposes of this section, aerobatic flight means an intentional maneuver involving an abrupt change in an aircraft's attitude, an abnormal attitude, or abnormal acceleration, not necessary for normal flight. Thanks for making this interpretation clear to me. I read it simply as the surface lateral limit of BCDE and that does not, to me, mean within 5 miles of an airport. If in common US parlance, it is as you say then shouldn't the FAR be rewritten to make your interpretation clear? I can see the merit in your definition as C can be huge and would prevent most aerobatic practice outside special use areas given by a waiver from the director. From a legal and practical POV I can see the merit in requiring an application for an aerobatic area as the risks wold be minimised as ATC would not route planes at the bottom edge of those air spaces near the aerobatic area. Cheers |
Light gun work with ATC COMS - Video | [email protected] | Instrument Flight Rules | 25 | July 19th 09 12:07 AM |
Light gun work with ATC COMS - Video | [email protected] | Piloting | 5 | July 15th 09 03:20 AM |
Pop up IFR clearance with ATC COMS - Video | [email protected] | Piloting | 0 | November 15th 08 05:05 PM |
Pop up IFR clearance with ATC COMS - Video | A Lieberma[_2_] | Owning | 0 | November 15th 08 05:04 PM |
Pop up IFR clearance with ATC COMS - Video | [email protected] | Instrument Flight Rules | 0 | November 15th 08 05:04 PM |
