Mike Spera wrote:
/snip/ 2 things that I cannot find: the part number of the oil temp sending unit and a supplier. This part does not appear either in the engine parts list or the airplane parts list. Engine is a 150hp E-3D. Any info would be appreciated. Thanks, Mike Mike, My Feb. 1995 Cherokee parts catalog shows the sending unit on Figure 68, "Electrical System Installation", item #63: "Gauge-Engine Unit, Oil Temperature" Depending on your Serial # ( 20550, or 20550 ), it shows Piper part # 462-046, or 550-487 (mfg's part #'s 1514976, or 362-EW). Bear in mind all of those #'s have probably been superceded by now, but perhaps a Piper dealer or Lycoming distributor can take you from there. Happy Flying! Scott Skylane |
![]() Scott, That's the gauge you are looking at, not the sending unit. I don't need the gauge. Thanks, Mike Mike, My Feb. 1995 Cherokee parts catalog shows the sending unit on Figure 68, "Electrical System Installation", item #63: "Gauge-Engine Unit, Oil Temperature" Depending on your Serial # ( 20550, or 20550 ), it shows Piper part # 462-046, or 550-487 (mfg's part #'s 1514976, or 362-EW). Bear in mind all of those #'s have probably been superceded by now, but perhaps a Piper dealer or Lycoming distributor can take you from there. Happy Flying! Scott Skylane |
Mike Spera wrote:
Scott, That's the gauge you are looking at, not the sending unit. I don't need the gauge. Thanks, Mike Mike, My Feb. 1995 Cherokee parts catalog shows the sending unit on Figure 68, "Electrical System Installation", item #63: "Gauge-Engine Unit, Oil Temperature" Depending on your Serial # ( 20550, or 20550 ), it shows Piper part # 462-046, or 550-487 (mfg's part #'s 1514976, or 362-EW). Bear in mind all of those #'s have probably been superceded by now, but perhaps a Piper dealer or Lycoming distributor can take you from there. Happy Flying! Scott Skylane Mike, I believe the part #'s I gave you are the correct ones. If you have access to the drawing, you will see it clearly indicates the sending unit, which screws in to the accessory case. Notice they call it "Gauge, *Engine Unit*, Oil Temp". The actual gauge, that you see in the cockpit, is listed in Figure 16 & 17, "Instrument Panel Installation", under items # 28 & 35, respectively: "Instrument - Oil Temperature", again, depending on serial no. Happy Flying! Scott Skylane |
![]() "Scott Braddock" wrote in message Mike, I believe the part #'s I gave you are the correct ones. Happy Flying! Scott Skylane This Piper Forum post agrees with those numbers: http://forums.piperowner.org/read/4/5724/5725/quote=1 |
O.K., I'll chase those numbers down.
Thanks, Mike "Scott Braddock" wrote in message mmunications... Mike Spera wrote: Scott, That's the gauge you are looking at, not the sending unit. I don't need the gauge. Thanks, Mike Mike, My Feb. 1995 Cherokee parts catalog shows the sending unit on Figure 68, "Electrical System Installation", item #63: "Gauge-Engine Unit, Oil Temperature" Depending on your Serial # ( 20550, or 20550 ), it shows Piper part # 462-046, or 550-487 (mfg's part #'s 1514976, or 362-EW). Bear in mind all of those #'s have probably been superceded by now, but perhaps a Piper dealer or Lycoming distributor can take you from there. Happy Flying! Scott Skylane Mike, I believe the part #'s I gave you are the correct ones. If you have access to the drawing, you will see it clearly indicates the sending unit, which screws in to the accessory case. Notice they call it "Gauge, *Engine Unit*, Oil Temp". The actual gauge, that you see in the cockpit, is listed in Figure 16 & 17, "Instrument Panel Installation", under items # 28 & 35, respectively: "Instrument - Oil Temperature", again, depending on serial no. Happy Flying! Scott Skylane |
Cherokee 140 Oil Temp Creeping Up | Mike Spera | Owning | 9 | June 12th 09 09:02 PM |
Cherokee fuel sending units | Mike Spera | Owning | 6 | June 26th 06 11:07 PM |
Fuel Sending Unit? | Bill Adams | Home Built | 0 | April 12th 05 02:46 PM |
Cherokee fuel tank sender unit "float" -- anybody know where to get these??? | Chuck | Owning | 5 | January 27th 05 03:18 PM |
Oil Temperature sending unit | Corky Scott | Home Built | 2 | October 19th 04 12:58 AM |
