Vne, Va and lift?
Old September 12th 09, 12:45 PM posted to rec.aviation.piloting
Stealth Pilot[_3_]
Default Vne, Va and lift?
On Fri, 11 Sep 2009 01:50:08 -0700 (PDT), "Flaps_50!"
On Sep 7, 4:10*am, a wrote:
On Sep 5, 10:20*pm, "Flaps_50!" wrote:
Ever watch that video of the Air Tanker C-130 snap it's wings after
dropping retardant on a fire? Imagine pulling out of a dive (while
banking) in a valley and then within a second losing 10,000 lbs of
cargo... when the weight is reduced, load factor goes up for a given
value of lift. In the case of the C-130 there may have been other
factors such as metal fatigue but the increased load was the primary
cause.
I watched the video -- seems to me what happened is aoa was
appropriate for the load, when the load was lost the sudden excess
lift over weight acted pretty much the same *as if the pilot suddenly
yanked the yoke fully aft, but will let others more skilled make their
points.
this diagnosis didnt make sense to me. how could an aircraft that has
just shed it's load fail? with the shedding of the load the airframe
gets relatively stronger.
the locheed reports indicate that the aircraft had an undetected crack
in the root of the mainspar that had grown to such an extent that the
structure was compromised. the events that you see on the video are
coincidental and not the cause of the crash.
the crack grew to the point that it broke up in flight. that was the
cause.
Stealth Pilot
Old September 12th 09, 02:25 PM posted to rec.aviation.piloting
Morgans[_2_]
Default Vne, Val and lift?
cause.
It shed its load of water, by dropping it on a fire. If you keep your
control surfaces in the same position, you will suddenly pull more G's when
the plane is much, much lighter. Those G's were more than a plane with an
already compromised wing could stand, so it broke up.
Does that make more sense?
Jim in NC
Old September 12th 09, 04:44 PM posted to rec.aviation.piloting
Stealth Pilot[_3_]
On Sat, 12 Sep 2009 09:25:22 -0400, "Morgans"
cause.
yes but I'm still not convinced.
Old September 12th 09, 04:58 PM posted to rec.aviation.piloting
Mike Ash
cause.
Not really. You're pulling more gees because you're lighter. The wings
are exerting the same force as before, thus the spar is under the same
load as before.
The reason you have G limits as well as loading limits is because of
fixed-weight components in the structure. For example, it's my
understanding that the engine attachments in light singles are a major
factor in having G limits instead of just loading limits. Your wings
don't care if you're pulling 3 Gs at max gross or 6 Gs at half max
gross, but in the 6 G case your engine mounts have to bear twice the
load.
In a case like this, where it's the wings that failed, it can't be due
to attachments holding fixed-weight items. My totally uninformed guess,
since there was a crack, is that suddenly shedding this load caused the
wings to flex DOWN, and this flexing was the final straw that caused the
crack to fail catastrophically.
Mike Ash
Radio Free Earth
Broadcasting from our climate-controlled studios deep inside the Moon
Old September 12th 09, 05:16 PM posted to rec.aviation.piloting
a[_3_]
cause.
It shed its load of water, by dropping it on a fire. *If you keep your
the plane is much, much lighter. *Those G's were more than a plane with an
load as before.
load.
Mike Ash
Radio Free Earth
Broadcasting from our climate-controlled studios deep inside the Moon- Hide quoted text -
- Show quoted text -
I am not an aeronautical engineer, but I think this 'model' makes
sense. The C130 was in coordinated flight with a heavy load of water.
that means it had to be trimmed for a lot of nose up to carry that
load. Now, drop the load. the airplane will pitch nose up because of
the trim setting, but its momentum will want it to continue straight
ahead. The wings now have a much greater angle of attack, much more
lift than was needed before. If you were flying straight and level
then yanked back on the yoke which I think is pretty much the same
thing aerodynamically, you might expect the wings to fail upward.
That's my take on explaining what I've seen in the video. Give me
enough speed and enough elevator authority and I might be able to fail
the wings of any airplane.
Old September 12th 09, 07:42 PM posted to rec.aviation.piloting
Mike Ash
In article
Makes sense to me. Seems like there are several potential explanations:
sudden flexing of the wings like I said, sudden pitch up like you said,
or simply CG changes causing increased load on the wing. Lots of ways
for this failure to occur given a weakened wing, but the idea of the
wings failing under constant load with more Gs due to less weight
doesn't seem to make sense.
Mike Ash
Radio Free Earth
Old September 12th 09, 10:02 PM posted to rec.aviation.piloting
a[_3_]
On Sep 12, 2:42*pm, Mike Ash wrote:
In article
load. *Now, drop the load. the airplane will pitch nose up because of
lift than was needed before. *If you were flying straight and level
Mike Ash
Radio Free Earth
Mike, if you look closely at the video I think you'll see the change
of pitch occur when the water is dropped. Of course if the airplane
stayed straight and level the reduced weight would reduce the wing
loading, but my theory is related to the dynamics, not the steady
state. We have all been taught to be gentle with the contols, this is
an argument that we have to be gentle with pseudo control changes too.
It would be like flying into a sharp edged updraft -- that can take
one's wings off too.
There are lots of theories here, but my bias is showing!
Old September 13th 09, 04:01 AM posted to rec.aviation.piloting
Morgans[_2_]
It does seem counter-intuitive. I had problems with the concept when it
came to explaining max maneuvering speed.
I had it explained to me, something like this: You are cruising along at
low weight, and hit a strong upward air column, suddenly. With a light wing
loading, the strength of the updraft will make the machine move upward
rapidly, which will cause a G to register on your G meter.
Now, you take the same plane, loaded to max weight and going the same speed
as before. You hit the same updraft, but the plane has a higher wing
loading, and higher mass, but the same wing area, so it will accelerate
upwards more slowly. That will register a lower G on your meter. Same
force applied to the higher mass is equal to less acceleration, as shown in
F=MA.
In thinking about max maneuvering speed, the more gradually you move into an
updraft, the less force will suddenly be applied, and I think another factor
comes into play in this. The same wing with a higher wing loading will not
be as efficient at creating more lift. It will slip, or "mush" through the
air more at higher wing loading.
I believe the same factor took place in the fire fighting airplane that
pulled the wing off. With the lighter load, the wing slipped less, and
created more lift at the lighter weight. It changed direction much more
quickly, which converts to higher G's, which broke it's wing.
I don't know. I hope to always (usually?) explain things in the least
technical way possible. That is the teacher side of me trying to make
things make sense to people who are not experts in the subject that I am
attempting to explain. It makes sense to me, but maybe I'm all wet.
Something must make it true, because that is what people say who know how to
make fancy math work as related to aeroplanes.
Jim in NC
Old September 13th 09, 04:05 AM posted to rec.aviation.piloting
Morgans[_2_]
What causes something to break more easily; a steady pull, or a sharp
impact (or pull)?
A steady bend is the result of more weight carried by the airplane. A
sudden G load causes the wing to flex rapidly.
At least that's my story, and I'm stickin' to it! g
Jim in NC
How much lift do you need? Dan Luke Piloting 3 April 16th 07 02:46 PM
Come lift a cup with Joe Rasymas! Fred Soaring 5 October 24th 06 08:42 PM
Theories of lift Avril Poisson General Aviation 3 April 28th 06 07:20 AM
what the heck is lift? buttman Piloting 72 September 16th 05 11:50 PM
thermal lift ekantian Soaring 0 October 5th 04 02:55 PM
