Claton,
These engines were used in light homebuilts before the 1300cc and up engines were available. I am talking light weight single seaters. i.e., Tipsey Nipper. I built a 1200 cc VW which I think is a 36 horsepower. I happened to have two of these in my backyard so I just wanted to see if one could be converted after an A&P advised me to use one on my small Supercat airplane. I don't remember the year of the engine. It has oversized jugs making it a 1385cc. Jugs went from 77 to 83mm. Stock crank is 61mm opposed to a 69mm for a 1600cc. It is installed on the Supercat homebuilt but has not been flown. Test runs indicated 3250 rpms using a 54X24 wideblade Tennesee prop, which is too big for the engine. Old modifications back in the 60s for a 1200cc engine included installing Corvair cylinders which increased the displacement some more. (lot of machine work) Great Plains Aircraft does not carry a full line of replacement parts for a 36 horse engine. Cylinders, pistons, rods, and heads from a 1600 won't fit. Not very many of the parts are interchangable. Crank and rod bearings will fit. Cam will fit. Flywheel endpiece is different. A 1600cc flywheel won't seal at the case because the rear of the crank is different. Heads are different - smaller valves - single port. Rods are shorter therefore the case is narrower. I liked to have never found four rebuilt rods for my rebuild. No cam bearings are used in the 36 horse engine. The only place I know to get a rebuild kit is J. C Whitney. It cost more than a 1600 kit. The larger jugs came from Larry's Offroad Supply. He just happened to have a set. I would use a 1600 if I were to do it over. But I sucessfully converted the engine. I did use a Great Plains hub. See some pics at http://www.geocities.com/tomlc1/Volks.html and at http://www.geocities.com/tomlc1/volks2.html Tom Cummings "Claton Cadmus" wrote in message om... (Corky Scott) wrote in message ... Claton, are you just stepping into this world for the first time without knowing what history has gone by about this engine as used for an aircraft engine? Thanks, Corky Scott Yes, if I knew the history of the engine as it pertains to homebuilt aircraft I wouldn't need to ask the question. I do know that the horespower rating on an engine is not at important as it's torque. Do you have anything constructive to add? Claton |
Claton, First buy a copy of "Hot VW's " magazine at the drug store.
Next look for a rebuildable "core" dualport engine built after '68 expect to pay $100.00..... you can build one up for about 500- 800 bucks, (there's a little machine work to do if you want to use big bore cylinders.) Expect 55 honest horsepower if you build an 1835 version. The VW aftermarket parts sources are enormous! Have fun! .........Marvin www.flysquirrel.net |
Objective Engine Discussion | Rick Maddy | Home Built | 26 | October 14th 03 04:46 AM |
Ford V-6 engine work | Corky Scott | Home Built | 19 | August 21st 03 12:04 PM |
1710 allison v-12 engine WWII p 38 engine | Holger Stephan | Home Built | 9 | August 21st 03 08:53 AM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
Gasflow of VW engine | Veeduber | Home Built | 4 | July 14th 03 08:06 AM |
