#31
![]() Black holes are where God is dividing by zero. Sorry to be useless, but LOL ![]() |
#32
On Sep 8, 5:28*pm, EventHorizon wrote:
I thought you might all find this story interesting. Me, I'm 53 and have been flying since 1988 with about 1000 hrs. My partner is a CFI and we've been in a Cherokee 140 partnership for about 12 years. We have a 1974 Cherokee Cruiser, which we normally keep well maintained (!). About a week ago my partner and I decided to fly after work. We are still breaking in a new cylinder so we thought we'd fly local here in Southern California. I flew left seat and we took off from Camarillo and flew around Malibu, then I flew over to Santa Paula for a landing. We had agreed we wanted to fly about 1.5 hrs, so as I was landing at Santa Paula I was at about 45 minutes. After I landed I asked my partner if he wanted to switch sides, but he said no, he'd fly from the right side. We taxied back and he took off. At about 1500'agl he tapped me on the shoulder (I was looking outside for traffic). He said "we have a problem". There had been no apparent change in the flight so I thought he might be joking. He pointed down at the throttle and he was moving it full to idle and back, but it had no effect! We were still at full throttle and obviously we had a broken cable or something similar. So your mind goes rapidly over the situation. How bad is this? What are the challenges? What are the options? We had a brief discussion and I mentioned that although this didn't seem real bad, we had some risks and I had read so many stories of pilots being reluctant to declare an emergency. We were only about 5 miles from Camarillo, our home airport which has a 5000' runway. We discussed and within about 20 seconds agreed that I would fly the plane since I was left seat, he would handle radio, and we would declare and emergency since we did not have throttle control. We had decided that I would try to modulate power with the mixture, but if necessary I could fly over the the airport and then just kill the engine and we would glide down. The weather was very clear and it was just about dusk. My partner called Camarillo tower, reported our position (about 5 miles out) and indicated we had a throttle problem and we needed to declare and emergency. The tower immediately cleared us to land on runway 8 and cleared out one other plane in the pattern. The runway in use was 26 but it was calm and rwy 8 was the closer approach. I was at about 1700' and full power; I leveled off and flew at about yellow line toward the airport. As I got closer I started a dive to lose altitude and flew fast; I had not yet adjusted the mixture. I realized that I was going to be quite high - I was on a 1 mile base so I began to pull the mixture back and the engine roughened as it slowed down some more. Still flying fast, I descended. I realized I was still pretty high so I overshot the centerline a bit before turning to about a .5 mile final to lose some more altitude. I leaned the mixture more aggressively and the engine ran really rough with some backfiring. As we came in a bit high on final and I knew the runway was assured I asked my partner for flaps. I leaned more aggressively and the engine was really choking now. As we came over the threshold a bit high I told my partner I was going to kill the engine. I didn't want to be trying to modulate a full throttle enging with mixture once I was on the runway. About 20 feet or so I pulled to idle cutoff and it was weird to see a prop stopped as I flared for a nice landing. I rolled out and used residual speed to pull off on a turnoff and coast to a stop. Airport security showed up and the guy didn't quite know what to do. We told him we just needed a tow into our tiedown spot. He took our names and certificate numbers and a brief statement of what had happened. In discussion with my partner, we felt we did almost everything correctly. We did not panic, we did not hesitate to declare the emergency, we quickly agreed on roles and everything went smoothly. We never really felt scared about the situation (a power failure might have felt different!). When the situation first presented itself I thought about flying to over the airport and cutting power, but I felt it would be better not to have a guaranteed engine failure. We both felt this was the less-risky way to handle the situation. We sort of stood there saying to ourselves "we can't believe we just had an emergency!". It was the first one for both of us in more than 20 years of flying each. The plane is in the shop to get its cable replaced, apparently it broke somewhere between the throttle quadrant and the carburetor, not at either end. Event Horizon Glad it worked out so well. Cheers |
#33
![]() "BeechSundowner" wrote in message ... On Sep 9, 8:44 pm, Dana M. Hague wrote: Sounds like you handled the situation well, but it doesn't sound like an "emergency". My understanding is that you declare an emergency when you need assistance or clearance RIGHT NOW. In this case, you weren't in any imminent danger; Judgement call on the pilots part as you already know, but if you can't control the engine, if that isn't an emergency, I don't know what is. For all intent and purposes, he had a runaway plane until he worked the problem! No, you still had at least 2 ways to control the engine. |
#34
On Oct 25, 8:32 am, "Aluckyguess" wrote:
"BeechSundowner" wrote in message ... On Sep 9, 8:44 pm, Dana M. Hague wrote: Sounds like you handled the situation well, but it doesn't sound like an "emergency". My understanding is that you declare an emergency when you need assistance or clearance RIGHT NOW. In this case, you weren't in any imminent danger; Judgement call on the pilots part as you already know, but if you can't control the engine, if that isn't an emergency, I don't know what is. For all intent and purposes, he had a runaway plane until he worked the problem! No, you still had at least 2 ways to control the engine. Sounds like OP had a good battery, something I would check then I would've dialed the emergency frequency, tell tower my situation and put myself into position for a 'dead-stick', mags-off. It's a good case to practice some 'dead stick' landings. AFAIK you should be able to kill the bird anyway in the circuit and dead stick. That's how I was trained on a cessna-152. Ken |
#35
Ken S. Tucker wrote:
It's a good case to practice some 'dead stick' landings. AFAIK you should be able to kill the bird anyway in the circuit and dead stick. That's how I was trained on a cessna-152. Ken It used to be training SOP to pull the throttle to idle onto base until the cold shock issue forced a gentler kinder approach Brian W |
#36
On Oct 27, 5:23 pm, brian whatcott wrote:
Ken S. Tucker wrote: It's a good case to practice some 'dead stick' landings. AFAIK you should be able to kill the bird anyway in the circuit and dead stick. That's how I was trained on a cessna-152. Ken It used to be training SOP to pull the throttle to idle onto base until the cold shock issue forced a gentler kinder approach Brian W Never heard of that, but I can understand it. Ken |
#37
In article
, "Ken S. Tucker" wrote: On Oct 27, 5:23 pm, brian whatcott wrote: Ken S. Tucker wrote: It's a good case to practice some 'dead stick' landings. AFAIK you should be able to kill the bird anyway in the circuit and dead stick. That's how I was trained on a cessna-152. Ken It used to be training SOP to pull the throttle to idle onto base until the cold shock issue forced a gentler kinder approach Brian W Never heard of that, but I can understand it. Ken I was taught to pull the power on downwind, even with the desired touchdown point. -- Remove _'s from email address to talk to me. |
#38
On Oct 28, 12:46*pm, Orval Fairbairn
wrote: In article , *"Ken S. Tucker" wrote: On Oct 27, 5:23 pm, brian whatcott wrote: Ken S. Tucker wrote: It's a good case to practice some 'dead stick' landings. AFAIK you should be able to kill the bird anyway in the circuit and dead stick. That's how I was trained on a cessna-152. Ken It used to be training SOP to pull the throttle to idle onto base until the cold shock issue forced a gentler kinder approach Brian W Never heard of that, but I can understand it. Ken I was taught to pull the power on downwind, even with the desired touchdown point. -- Remove _'s *from email address to talk to me. This was pretty standard procedure during the period when I learned to fly. As an instructor I "altered" the way I approached this a bit by stressing proper stepped down power reduction on letdowns prior to entering downwind so that by the time the power was reduced on final, the engine temps and pressures were under control. There's always been a "discussion" about the advantages and disadvantages of doing power off approaches as practice for forced landings. What I did was to treat forced landing practice as forced landing practice and otherwise stressed proper engine management as suggested by the engine manufacturer. Dudley Henriques |
#39
wrote: In article , *"Ken S. Tucker" wrote: On Oct 27, 5:23 pm, brian whatcott wrote: Ken S. Tucker wrote: It's a good case to practice some 'dead stick' landings. AFAIK you should be able to kill the bird anyway in the circuit and dead stick. That's how I was trained on a cessna-152. Ken It used to be training SOP to pull the throttle to idle onto base until the cold shock issue forced a gentler kinder approach Brian W Never heard of that, but I can understand it. Ken I was taught to pull the power on downwind, even with the desired touchdown point. -- Remove _'s *from email address to talk to me. In my Mooney with its IO 360, we consider it a good approach if the throttle does not have to be advanced from downwind until turning off of the active (and using the brakes to slow down on the runway is considered bad form). At most airports I use good planning would be a touchdown maybe a 1000 feet past the numbers to make the first turnoff comfortably, so my thinking is if the engine chooses to fail I do have some altitude in the bank. |
#40
On Oct 28, 9:46 am, Orval Fairbairn
wrote: In article , "Ken S. Tucker" wrote: On Oct 27, 5:23 pm, brian whatcott wrote: Ken S. Tucker wrote: It's a good case to practice some 'dead stick' landings. AFAIK you should be able to kill the bird anyway in the circuit and dead stick. That's how I was trained on a cessna-152. Ken It used to be training SOP to pull the throttle to idle onto base until the cold shock issue forced a gentler kinder approach Brian W Never heard of that, but I can understand it. Ken I was taught to pull the power on downwind, even with the desired touchdown point. Yeah, I had no prob with dead stick, but I respect what Brian wrote, as I flew a lot in cold weather. Shutting off the heat flow to the air cooled fins, while the core (cylinder temp) is hot and the exterior cools rapidly may induce a thermal gradient stress due to uneven contraction of the metal as it cools from the outside in. Ken |
A few from - Last Week 00.jpg (0/1) | RustY© | Aviation Photos | 1 | May 23rd 08 02:01 PM |
More Evidence Bush Was Actually Declared a Deserter | WalterM140 | Military Aviation | 9 | August 23rd 04 11:36 PM |
Declared "minimum fuel" | O. Sami Saydjari | Instrument Flight Rules | 14 | April 4th 04 02:43 AM |
A record: 1 in 73 US households declared bankruptcy in '03 | Krztalizer | Military Aviation | 7 | March 15th 04 09:27 PM |
