#21
So how does rubber (or modern synthetic varieties thereof) compare on
an energy storage per mass basis with lithium/ion batteries? We use them for bungee launches - how about powering a sustainer? I have this vision of a large coil of rubber between my legs powering a slow-turning single-bladed prop! Mike |
On Mon, 02 Nov 2009 15:47:40 -0800, Mike the Strike wrote:
So how does rubber (or modern synthetic varieties thereof) compare on an energy storage per mass basis with lithium/ion batteries? We use them for bungee launches - how about powering a sustainer? Good quality rubber strip stores around 3000 ft/lb per pound of rubber. Sad to say, I've completely forgotten how to convert that to something we could compare with a battery, say to kW/kg. I have this vision of a large coil of rubber between my legs powering a slow-turning single-bladed prop! That sounds potentially as dangerous to valued objects as snapping the drive shaft of a P.39 Airacobra. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Nov 2, 4:37*pm, Martin Gregorie
wrote: On Mon, 02 Nov 2009 15:47:40 -0800, Mike the Strike wrote: So how does rubber (or modern synthetic varieties thereof) compare on an energy storage per mass basis with lithium/ion batteries? *We use them for bungee launches - how about powering a sustainer? Good quality rubber strip stores around 3000 *ft/lb per pound of rubber.. Sad to say, I've completely forgotten how to convert that to something we could compare with a battery, say to kW/kg. I have this vision of a large coil of rubber between my legs powering a slow-turning single-bladed prop! That sounds potentially as dangerous to valued objects as snapping the drive shaft of a P.39 Airacobra. -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | If I've calculated correctly (and I may not have) 3000 ft-lb/lb of rubber = 8,965 joules/kg of rubber. So a 100 kg rubber band would store 896.5 kilo joules of energy which expended over 60 seconds provides a stunning power output of (drum roll please) 15 kw. It would be damn exciting on a FF model, but probably not practical as a sustainer. Craig |
Would that be 1987 Pirelli?? I've heard that sometimes FAI Tan is
comperable. I seem to recall a man-carrying rubber powered plane making an attemp in the late 1980's or early '1990's. Good quality rubber strip stores around 3000 *ft/lb per pound of rubber.. Sad to say, I've completely forgotten how to convert that to something we could compare with a battery, say to kW/kg. |
On Mon, 02 Nov 2009 17:25:56 -0800, Craig wrote:
On Nov 2, 4:37Â*pm, Martin Gregorie wrote: On Mon, 02 Nov 2009 15:47:40 -0800, Mike the Strike wrote: So how does rubber (or modern synthetic varieties thereof) compare on an energy storage per mass basis with lithium/ion batteries? Â*We use them for bungee launches - how about powering a sustainer? Good quality rubber strip stores around 3000 Â*ft/lb per pound of rubber. Sad to say, I've completely forgotten how to convert that to something we could compare with a battery, say to kW/kg. I have this vision of a large coil of rubber between my legs powering a slow-turning single-bladed prop! That sounds potentially as dangerous to valued objects as snapping the drive shaft of a P.39 Airacobra. -- martin@ Â* | Martin Gregorie gregorie. | Essex, UK org Â* Â* Â* | If I've calculated correctly (and I may not have) 3000 ft-lb/lb of rubber = 8,965 joules/kg of rubber. So a 100 kg rubber band would store 896.5 kilo joules of energy which expended over 60 seconds provides a stunning power output of (drum roll please) 15 kw. It would be damn exciting on a FF model, but probably not practical as a sustainer. So that's 0.25 kWh by my reckoning. By contrast the LAK FES installation carries two 3.6 kWh batteries. I make that rubber 0, electric 1 -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Mon, 02 Nov 2009 17:59:21 -0800, Uncle Fuzzy wrote:
Would that be 1987 Pirelli?? I've heard that sometimes FAI Tan is comperable. I seem to recall a man-carrying rubber powered plane making an attemp in the late 1980's or early '1990's. That value was from a 2008 NFFS Sympo paper for Tan 2. I don't fly rubber, preferring 50m of towline or a screaming Cyclon 06, but IIRC Tan 2 is now about as good as the best Pirelli and the Tan SuperSport is coming pretty close too. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
| Thread Tools | |
| Display Modes | |
| The HPH 304S Turbine sustainer glider | kd6veb | Soaring | 2 | September 23rd 09 06:10 AM |
| would an electric sustainer be practical | Brad[_2_] | Soaring | 7 | July 24th 09 07:29 PM |
| Sustainer engine ignition noise (Solo2350) | Per | Soaring | 8 | January 4th 07 06:56 AM |
| DG goes the sustainer option. | Paul | Soaring | 25 | June 4th 04 01:16 AM |
| Chasing the front | Paul Tomblin | Piloting | 7 | April 21st 04 02:09 PM |
