On Nov 13, 3:26*pm, Papa3 wrote:
On Nov 13, 5:50*pm, Bruno wrote: On my last flight my audio vario suddenly started to read a consistent 300-400 fpm too high for the present conditions. *I have a mechanical vario that remained accurate and on my L-Nav screen my average fpm sink rate was correct. *Any ideas what I can check? *It was really annoying when I was sinking at a true 300 fpm on glides but my audio was telling me I was going up 100fpm. *If only it was always that way in real life! * ![]() Thanks, Bruno - B4 Hi Bruno, What you wrote is a little confusing. *I wonder if you meant that the dial was showing high along with the audio tone, while the LNAV LCD screen showed a believable average (and netto)? * *As you probably know, it is possible to adjust the zero and gain on the vario through the configure screen, and the manual tells you what the acceptable zero number ranges are. * *It would at least be interesting to have a look at those values and see what they show. * But, it wouldn't explain (at least to me) while the dial and audio are out of sync with the other values. Sounds like a trip to NK is in order. P3 That's interesting. I have an old Cambridge CAV series audio vario in my Speed Astir. Every once in a great while, it will start to read 200-300 fpm climb when I'm NOT climbing. This usually happens several hours into the flight, when I'm fairly tired of the annoying noises it makes too much of the time anyhow. In its defense, it is probably just trying to make up for the seemingly endless fields of sink that force it to honestly inform me that I'm dropping like a frigging rock (and have been for the last dozen miles). Perhaps it's just trying to cheer me up?? I used to think maybe it was voltage related, when I was using a 12v battery, but it does it even with my 14v setup. |
| Thread Tools | |
| Display Modes | |
| CAV 11 Audio Vario/no Audio ideas? (Cambridge) | Gregg Leslie[_2_] | Soaring | 3 | June 4th 11 01:08 AM |
| FS: Cambridge CAV-II vario/audio/averager | [email protected] | Soaring | 1 | May 13th 09 02:41 AM |
| WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario | ufmechanic | Soaring | 0 | March 24th 09 06:31 PM |
| Cambridge vario audio control | Solo | Soaring | 4 | October 23rd 06 02:03 AM |
| L-13 + TE + Audio Vario | Ray Lovinggood | Soaring | 4 | January 12th 05 04:21 AM |
