#31
Dave wrote:
On Mon, 07 Dec 2009 17:40:06 -0600, brian whatcott wrote: In powerboat context.. "BOAT" means. "Bring On Another Thousand" I know this, and.. I also know what an "AMU" is... ![]() Dave Ross wrote: ... there use to be the AMU. I think it was aeronautical money unit. It equaled $1000.00. Therefore your $150.00 was only .150 AMU. Doesn't sound so large. In a sailboat context, that's 0.15 boatbuck... Brian W But with a boat you do not need an A&P/IA to sign off your work. I had a 21' Chriscraft for several years and did all the work myself. -- Regards, Ross C-172F 180HP Sold ![]() KSWI |
#32
On Dec 9, 12:45*pm, Ross wrote:
brian whatcott wrote: Ross wrote: ... *there use to be the AMU. I think it was aeronautical money unit. It equaled $1000.00. Therefore your $150.00 was only .150 AMU. Doesn't sound so large. In a sailboat context, that's 0.15 boatbuck... Brian W What kind of sailboat do you own? -- Regards, Ross C-172F 180HP Sold ![]() KSWI The O'Day sloop (25 foot swing keel) was simply not expensive -- the biggest annual cost was a pier side docking, and that was a bit over $1000. "Flight" planning for 5 knots took a different mindset though. |
#33
a wrote:
On Dec 9, 12:45 pm, Ross wrote: brian whatcott wrote: Ross wrote: ... there use to be the AMU. I think it was aeronautical money unit. It equaled $1000.00. Therefore your $150.00 was only .150 AMU. Doesn't sound so large. In a sailboat context, that's 0.15 boatbuck... Brian W What kind of sailboat do you own? -- Regards, Ross C-172F 180HP Sold ![]() KSWI The O'Day sloop (25 foot swing keel) was simply not expensive -- the biggest annual cost was a pier side docking, and that was a bit over $1000. "Flight" planning for 5 knots took a different mindset though. I used to have a 21 foot Chriscraft power boat. My aircraft (to keep aviation content) mechanic has the building rights to the Valiant Yachts. http://cedarmills.com/valiant.htm Check out his airstrip also. Nice gathering place for all of us. -- Regards, Ross C-172F 180HP Sold ![]() KSWI |
#34
Ross wrote:
brian whatcott wrote: Ross wrote: ... there use to be the AMU. I think it was aeronautical money unit. It equaled $1000.00. Therefore your $150.00 was only .150 AMU. Doesn't sound so large. In a sailboat context, that's 0.15 boatbuck... Brian W What kind of sailboat do you own? A SouthCoast 22. That's a swing keel. I keep it at the house. But it wants three people for anxiety-free mast raising, and that's a problem. My younger son has a better way. He recently rented a lake-front place with a personal mooring out front for his Hunter 25 - and space for a trailer too.... Brian W |
#35
On Dec 10, 8:09*am, brian whatcott wrote:
Ross wrote: brian whatcott wrote: Ross wrote: ... *there use to be the AMU. I think it was aeronautical money unit. It equaled $1000.00. Therefore your $150.00 was only .150 AMU. Doesn't sound so large. In a sailboat context, that's 0.15 boatbuck... Brian W What kind of sailboat do you own? A SouthCoast 22. That's a swing keel. I keep it at the house. But it wants three people for anxiety-free mast raising, and that's a problem. My younger son has a better way. He recently rented a lake-front place with a personal mooring out front for his Hunter 25 - and space for a trailer too.... Brian W Brian, for what it's worth, I could 'walk' the mast up on the O'Day 25 with the side and aft standing rigging in place. It was designed to pivot at its socket. I'd run a line near the top with a quick release knot and have my wife cleat it to the anchor cleat on the bow when it's upright. then I could attach the forestay and yank on the free end of the line to release it. The boom goes on after all of that. It may be your mast is a lot heavier or it didn't pivot into its socket. I would not want to go through that every time we went sailing, but the boat once rigged stayed that way all season. It did not trailer well, I wish it did. |
#36
In article , betwys1
@sbcglobal.net says... Ross wrote: brian whatcott wrote: Ross wrote: ... there use to be the AMU. I think it was aeronautical money unit. It equaled $1000.00. Therefore your $150.00 was only .150 AMU. Doesn't sound so large. In a sailboat context, that's 0.15 boatbuck... Brian W What kind of sailboat do you own? A SouthCoast 22. That's a swing keel. I keep it at the house. But it wants three people for anxiety-free mast raising, and that's a problem. Surely not! My trailer-sailer is 25' - I can raise and lower the mast myself (level ground helps!). Surely only one person is needed to hold the mast up, while the forestay is secured (I use the main on the jib halyard to tension the mast and allow the forestay to be secured). -- Duncan. |
#37
On Dec 10, 2:41*pm, Dave Doe wrote:
In article , betwys1 @sbcglobal.net says... Ross wrote: brian whatcott wrote: Ross wrote: ... *there use to be the AMU. I think it was aeronautical money unit. It equaled $1000.00. Therefore your $150.00 was only .150 AMU. Doesn't sound so large. In a sailboat context, that's 0.15 boatbuck... Brian W What kind of sailboat do you own? A SouthCoast 22. That's a swing keel. I keep it at the house. But it wants three people for anxiety-free mast raising, and that's a problem. Surely not! *My trailer-sailer is 25' - I can raise and lower the mast myself (level ground helps!). *Surely only one person is needed to hold the mast up, while the forestay is secured (I use the main on the jib halyard to tension the mast and allow the forestay to be secured). -- Duncan. The jib halyard would work at least as well as what I do. Just thinking, if one attached a pulley to the anchor cleat the hoisting line could be brought back to one of the main's winches. . .hmm, getting the mast up could be a one man task! |
#38
a wrote:
... there use to be the AMU. I think it was aeronautical money unit. It equaled $1000.00. Therefore your $150.00 was only .150 AMU. Doesn't sound so large. In a sailboat context, that's 0.15 boatbuck... Brian W What kind of sailboat do you own? A SouthCoast 22. That's a swing keel. I keep it at the house. But it wants three people for anxiety-free mast raising, and that's a problem. My younger son has a better way. He recently rented a lake-front place with a personal mooring out front for his Hunter 25 - and space for a trailer too.... Brian W Brian, for what it's worth, I could 'walk' the mast up on the O'Day 25 with the side and aft standing rigging in place. It was designed to pivot at its socket. I'd run a line near the top with a quick release knot and have my wife cleat it to the anchor cleat on the bow when it's upright. then I could attach the forestay and yank on the free end of the line to release it. The boom goes on after all of that. It may be your mast is a lot heavier or it didn't pivot into its socket. I would not want to go through that every time we went sailing, but the boat once rigged stayed that way all season. It did not trailer well, I wish it did. As bought, the boom and sails were available, but the mast was gone. There had evidently been a mishap, cos several of the stays were broke near one end. So I found a mast from a Hobie 16 - which had a slightly longer (25 ft?) and rather stout mast. Actually an old boy offered me the whole ball of wax on a trailer for next to nothing, because the trailer had been sitting out front too long... I rigged a jack staff with a second winch at the trailer head, and made a wooden tree to fit in the rudder pintle, so that fastening the winch line to the forestay allows the mast to wind up without too much stress on the mast footer. But half way to vertical, the mast is apt to sway sidewards way too much, without a steady line on the foot of each side stay held by an innocent bystander... Brian W p.s. Obligatory flying note: with the thermometer standing at 33 deg, I thought I would fly the plane in the hour before dark this evening. ...If I could start it.... There was a placard by the ki-gas primer: "Positively One stroke only in ANY conditions" and biding by that rule gave me several stuttering start/stops in previous chills. So I finally got the bit between the teeth, and treated it more like my previous C-150 which took FOUR ki-gas strokes on a cold day. This time, with THREE strokes, and a follow up with one stroke, it was running on the second pull (of the manual start handle) I think I know why that placard was there - despite low hours on the engine - one cylinder had been replaced after perhaps 100 hours by the prior owner. The easiest possible way to need a pot replaced, as you may know, is to over prime and get not a stack fire, but rather a back fire. *Bang!* and it's gone... Pumping the throttle can do that.... Brian W |
#39
![]() "brian whatcott" wrote I rigged a jack staff with a second winch at the trailer head, and made a wooden tree to fit in the rudder pintle, so that fastening the winch line to the forestay allows the mast to wind up without too much stress on the mast footer. But half way to vertical, the mast is apt to sway sidewards way too much, without a steady line on the foot of each side stay held by an innocent bystander... I have a solution for that problem. Rig a loop on each one of the side stays with a short section of wire rope and U-splice fittings, (or some way of your own choosing to attach extra lines) up high enough that you can still reach it when the mast is up. Fix up a rope with two hooks the right length that you will fix to an added eye on the rails of the boat, exactly abeam of the mast pivot. If you do it right, you can find the right place and lengths to keep lines tight on both sides, all of the way up. You get the picture, I hope. Using your method to wind up the mast, the extra temp rigging will prevent any and all movement of the mast side to side. Once it is up all the way, you can switch over to the correct stays. I also had an O'Day 25, for quite a few years. Added an inboard, with my dad, after we got tired of the 9.9 kicker packing it in at the most inconvenient times. I did get pretty good at coming into the slip under sail! g I kick myself for selling that boat, sometimes. -- Jim in NC |
#40
Morgans wrote:
"brian whatcott" wrote I rigged a jack staff with a second winch at the trailer head, and made a wooden tree to fit in the rudder pintle, so that fastening the winch line to the forestay allows the mast to wind up without too much stress on the mast footer. But half way to vertical, the mast is apt to sway sidewards way too much, without a steady line on the foot of each side stay held by an innocent bystander... I have a solution for that problem. Rig a loop on each one of the side stays with a short section of wire rope and U-splice fittings, (or some way of your own choosing to attach extra lines) up high enough that you can still reach it when the mast is up. Fix up a rope with two hooks the right length that you will fix to an added eye on the rails of the boat, exactly abeam of the mast pivot. If you do it right, you can find the right place and lengths to keep lines tight on both sides, all of the way up. I have thought about this kind of setup, more than once. The problem is the geometry of this particular hull. The mast pivots on the cabin-top, and the stays fix at the toe rails which are perhaps 2 ft lower, so the mast goes floppy on the way up. So I sniffed around the internet, when Richard wanted me to help dropping his mast (Hunter 25)while afloat. I was struck by a uTube video of a guy raising and dropping mast while under way to traverse low bridges - single-handed. He rigged an a-frame whose feet pivoted abeam the mast foot and whose peak folded down to the pulpit. The peak of the A-frame fixes to the fore stay foot, so that you could rig a jib halyard back to a cockpit winch. The idea behind this a-frame is that it starts providing support against side-sway from about half way down. The first 2 or 3 feet of drop is still a swaying issue though. The single-hander bear-hugged the mast with one hand, and loosed the halyard with the other. Neat! This approach worked for us too using a jury-rig a frame of two spars fastened together and to the toe rails. After writing this, I reread your suggestion, and finally got it. your rig pulls the slack out of the stays on the way up or down. Yes, that's the idea I needed! Thanks Brian W p.s. Aviation content: with the thermometer at 36 degrees, three primes gave a start on the first pull last night! I have got it beat... |
Looking for Partner / Aircraft Fractional Ownership / NJ | [email protected] | Aviation Marketplace | 0 | August 17th 08 09:34 PM |
Aircraft Ownership Spreadsheet | KevinBlack | Owning | 11 | November 19th 06 06:17 PM |
Aircraft ownership in Ohio | [email protected] | Owning | 15 | September 8th 06 02:26 PM |
The Joys of Aircraft Ownership 1,532 & 1,533 | Brock Boss | Owning | 15 | July 15th 06 05:05 AM |
2 years of aircraft ownership | NW_PILOT | Owning | 2 | March 28th 06 06:26 PM |
