Frozen Flaps
Old December 13th 09, 04:36 AM posted to rec.aviation.piloting
Brian Whatcott
Default Frozen Flaps
I am still familiarizing with a newly acquired 150.
The other day I flew on a chilly evening just above freezing.
I applied flaps in the pattern, and when I landed, the flaps didn't want
to retract
I had earlier exercised the flaps on preflight without problem
and before the plane was put away, the flaps went up OK.
I guessed that the actuator froze up, so it probably needs lube to keep
the water away.... The flap motor fuse checked OK of course...
Any thoughts?
Brian W
Old December 13th 09, 10:35 PM posted to rec.aviation.piloting
Scott Braddock
to retract
Any thoughts?
Brian W
Brian,
The most common cause of "frozen flaps" in Cessnas like yours are the
limit switches on the flap actuator, rather than the actuator itself. A
judicious application of a heat gun, through the appropriate inspection
panel, will free them up for a while. They are relatively inexpensive
to replace, however, and that's what is needed for a more permanent fix.
Happy Flying!
Scott Skylane
Old December 13th 09, 10:45 PM posted to rec.aviation.piloting
Those little microswitches get oil in them from the jackscrew
threads, and the oil draws dust and crud and gunks up the switch
contacts with sludge. In the cold the sludge will congeal and make the
switch's mechanism stick, too. Replacing them is the best thing, and
you want to do it soon. If you had to abort a landing and go around,
the flaps on a 150/152 will hurt the climbout dangerously; there's
just too much drag.
Dan
Old December 14th 09, 04:01 PM posted to rec.aviation.piloting
Gezellig
the limit switches on the flap actuator, rather than the actuator
itself. A judicious application of a heat gun, through the
appropriate inspection panel, will free them up for a while.
They are relatively inexpensive to replace, however, and that's
the switch's mechanism stick, too. Replacing them is the best
thing, and you want to do it soon. If you had to abort a landing
and go around, the flaps on a 150/152 will hurt the climbout
dangerously; there's just too much drag.
There's too much jackscrew grease or the lube's spreading too easily if
its getting to the switches. Get it right. Alaskan 261 was running a
failing jackscrew which looked like lube drift.
I thought the 261 failed because it wasn't lubricated, maybe not. What
that has to do with a 150/2, I have no clue.
Old December 14th 09, 05:45 PM posted to rec.aviation.piloting
Ross
to retract
Any thoughts?
Brian W
When I had the Skyhawk and cleaning of relube of the jack screw for the
flaps was mandatory at annual. Has this been done? Or the motor can be
wearing out. the track on the flap rollers needs lubrication also.
Regards, Ross
C-172F 180HP
Sold
KSWI
Old December 14th 09, 07:42 PM posted to rec.aviation.piloting
Huh. I wonder if you've ever had anything to do with these things?
Cessna calls for SAE 10 non-detergent oil on the jackscrew every 100
hours. The microswitches are mounted immediately below the jackscrew
and sooner or later the oil gets onto and into them. It's a poor
setup. The older airplanes get moly disulphide grease.
Alaska's problem was too little of the right lube. It was a stab
actuator jackscrew, not a flap jack, and once the screw's nut threads
failed the stab did its own thing. If a flap jackscrew fails it'll
either jam in some position or the flaps will retract. The airplane is
still flyable. Cessna has other flap problems, like the roller sleeves
slipping sideways on their bearings and cutting a disc out of the flap
support arm and causing flap jamming. There was an SB on that in '96
or so. The only bits on the flap itself that need a little oil are the
flap roller bearings, not the tracks. Oiling the tracks attracts dirt
and lets the rollers slip instead of roll and they'll get flat spots.
Dan
Old December 14th 09, 07:50 PM posted to rec.aviation.piloting
Gezellig
On Mon, 14 Dec 2009 11:42:52 -0800 (PST),
Dan
Jeffrey's struggling, let's all bow and say a prayer for him :0)
Old December 15th 09, 12:34 AM posted to rec.aviation.piloting
Brian Whatcott
Good question. I don't see a record of the jackscrew lube on the last
annual - but I haven't looked for it either....
Thanks
Brian W
Old December 15th 09, 01:53 PM posted to rec.aviation.piloting
Mark
* Huh. I wonder if you've ever had anything to do with these things?
Dan
Hi Dan. What you wanna do is never respond to that poster
again, or better yet, killfile that name. It reads our posts,
runs to google to "brush up", then hurrys back to insult you.
Killfile it or don't ever read it or answer.
Mark
More flaps? WingFlaps Piloting 36 May 26th 08 07:33 AM
Almost no frozen tickets since the abysmal movie were pleasing alongside the fond wedding. Hamid Bin Laden Piloting 0 August 14th 07 04:17 AM
Frozen airman's body headed home; remains identified from crash Matt Barrow Piloting 1 February 12th 06 11:18 PM
floatplane - taking off frozen lake Lets Fly Piloting 32 December 8th 05 04:19 AM
Frozen spoilers stephanevdv Soaring 0 November 4th 04 05:24 PM
