experimental to standard certificate
Old January 14th 10, 01:29 AM posted to rec.aviation.soaring
Todd
Default experimental to standard certificate
A few days ago I was looking for something unrelated and came across
this document (a bit old) that may help you. This one is canceled,
but it may help lead you to the current procedure.
The document: 8130.15 dated 09/14/1979
Airworthiness Certification of "Prematurely" Exported Gliders
http://www.airweb.faa.gov/Regulatory...gh light=8130
You might also try a google search like:
convert type certificate experimental site:faa.gov
FAA Revoking Standard Airworthiness Certificate DG-505 NG Soaring 32 February 16th 17 03:23 PM
USA Glider Experimental Airworthiness Certificate charlie foxtrot Soaring 4 April 15th 06 06:04 AM
Weird Experimental Certificate wording - Normal? Noel Luneau Soaring 12 January 11th 05 07:11 PM
Weird Experimental Certificate wording - Normal? Noel Luneau Soaring 7 January 11th 05 03:53 PM
PA-32 on Experimental Certificate Mike Granby Owning 3 July 21st 04 04:04 AM
