Ted et al
Your FSDO dude is a bit behind the times as the most current FAA order is 8130.2F Change 5 dated 01/15/2010. Check out para. 161 in order to get started. I've been told by our local FSDO that older gliders can no longer use their old "one time" program letter and that the operations limitations need to reflect the airport from which the glider is flown and that a yearly program letter must be submitted. HOWEVER, the local feds have not as yet quoted me book, chaper and verse of the reg/order that supports their statement. I'm still working on that but I suspect it can be found in the above mentioned order. Zulu |
On Feb 4, 1:30*pm, zulu wrote:
Ted et al Your FSDO dude is a bit behind the times as the most current FAA order is 8130.2F Change 5 dated 01/15/2010. *Check out para. 161 in order to get started. I've been told by our local FSDO that older gliders can no longer use their old "one time" program letter and that the operations limitations need to reflect the airport from which the glider is flown and that a yearly program letter must be submitted. HOWEVER, the local feds have not as yet quoted me book, chaper and verse of the reg/order that supports their statement. *I'm still working on that but I suspect it can be found in the above mentioned order. Zulu Yeah, I can see that coming! Maybe time to put bogus N numbers on the glider - different on each side? But more seriously, has anyone out there been checked by the FAA to see if they are complying with their program letter? I can just see a ramp check at a big Sports Class contest! And what is the penalty? "You can't fly it here." "OK, where's the Fax machine?". Speaking of Faxing - what's with that? Can't the FAA handle an email attachement of a Word doc or a PDF file? Sheesh.... Kirk |
A little more seriously, looking at 8130.2F (change 4), Section 10,
para e, it states: Effectivity. Aircraft that received original airworthiness certification before July 9, 1993, are NOT affected by this order unless the original airworthiness certification purpose changes, for example, from R&D to exhibition. Those aircraft, except for purpose changes, will not be affected until the FAA works with the public to determine the best strategy to certificate all experimental exhibition and/or air racing aircraft in accordance with the new policy. The policy established in this order will not be used in these cases unless specifically requested by the applicant. So it looks like older gliders should be safe. For now. Maybe.... See: http://www.faa.gov/documentLibrary/m...F%20Ch%204.pdf, page 166. Kirk "Fingers crossed" 66 |
On Feb 4, 2:46*pm, "kirk.stant" wrote:
A little more seriously, looking at 8130.2F (change 4), Section 10, para e, it states: Effectivity. Aircraft that received original airworthiness certification before July 9, 1993, are NOT affected by this order unless the original airworthiness certification purpose changes, for example, from R&D to exhibition. Those aircraft, except for purpose changes, will not be affected until the FAA works with the public to determine the best strategy to certificate all experimental exhibition and/or air racing aircraft in accordance with the new policy. The policy established in this order will not be used in these cases unless specifically requested by the applicant. So it looks like older gliders should be safe. *For now. *Maybe.... See: *http://www.faa.gov/documentLibrary/m...F%20Ch%204.pdf, page 166. Kirk "Fingers crossed" 66 Well, if the FAA really does intend to "work with the public" on a new policy, perhaps that's the SSA's opportunity to work out a sensible policy for all experimental sailplanes. Preferably a one time letter that places no geographic restrictions. Would that common sense prevail for once.... -Evan Ludeman / T8 |
![]() Speaking of Faxing - what's with that? Can't the FAA handle an email attachement of a Word doc or a PDF file? Sheesh.... Kirk A inquiry to your friendly FSDO might be in order. Electronic is easier for both parties. The Houston (TX) FDSO accepted my program letter (and other's) electronically this year. Understandably, they want a signature, so a plain Word file is generally not going to cut it. I printed the letter, signed it, scanned it to a pdf, and submitted. Based on a recommendation I saw some months ago (in Soaring mag or ras, I don't recall) to ask for receipt confirmation, I asked for a return email stating they received it, which they did. I realize that's not legally definative, but it's an easy step to at least confirm they read it and felt it was acceptable. While the whole program letter idea for sailplanes does seem a bit pointless, I did feel that our local FDSO was trying to make the best of the existing requirements and very willing to work with pilots. - Frank |
kirk.stant wrote:
On Feb 4, 1:30 pm, zulu wrote: Ted et al Your FSDO dude is a bit behind the times as the most current FAA order is 8130.2F Change 5 dated 01/15/2010. Check out para. 161 in order to get started. I've been told by our local FSDO that older gliders can no longer use their old "one time" program letter and that the operations limitations need to reflect the airport from which the glider is flown and that a yearly program letter must be submitted. HOWEVER, the local feds have not as yet quoted me book, chaper and verse of the reg/order that supports their statement. I'm still working on that but I suspect it can be found in the above mentioned order. Zulu Yeah, I can see that coming! Maybe time to put bogus N numbers on the glider - different on each side? But more seriously, has anyone out there been checked by the FAA to see if they are complying with their program letter? I can just see a ramp check at a big Sports Class contest! And what is the penalty? "You can't fly it here." "OK, where's the Fax machine?". Speaking of Faxing - what's with that? Can't the FAA handle an email attachement of a Word doc or a PDF file? Sheesh.... Kirk Regrettably we may as well get used to this. We have had a full ramp check for the entire grid at a regional contest- 29 aircraft -(2009 Gauteng regionals - that is in South Africa for the rest of the world) All documentation - glider and pilot, weight and balance etc. Contest check - Briefing, tasking, airspace ad turnpoint files, safety documentation and policies the whole nine yards. Kept the contest directors busy the whole day. Fortunately no major problems - except the time consumed. Bruce --- news://freenews.netfront.net/ - complaints: --- |
Program Letters US Experimental Exhibition | [email protected] | Soaring | 7 | April 16th 09 01:38 PM |
Letters Asking to Buy My Glider | ContestID67 | Soaring | 20 | November 30th 06 08:19 PM |
Service Bulletins, Service Letters, Service Spares Letters | O. Sami Saydjari | Owning | 5 | December 26th 03 05:36 AM |
Old Contest Letters | Mhudson126 | Soaring | 10 | December 24th 03 02:55 PM |
