Tail wheels, or is this forum really dead?
Old February 4th 10, 09:04 PM posted to rec.aviation.homebuilt
Default Tail wheels, or is this forum really dead?
On Feb 3, 7:27*pm, wrote:
On Wed, 3 Feb 2010 07:48:26 -0800 (PST), "
On Feb 2, 7:15*pm, wrote:
. Anytime you try to put the tread contact ahead of the pivot
you are creating an unstable arrangement that simply won't work.
Not a completely true statement. *Have you ever used a measuring
wheel?
Leon
*Virtually every distance measuring wheel available on the market
today has the pivot point well ahead of the patch.
The lufkin PSMW38 does. Northern's rotatape does. So does every other
RolaTape listed. DriVall Fencing's units do. *The DuraWheel does. So
does the TruMeter. So does the Gill.
And EVERY measuring wheel I've ever seen, unless you DRAG it instead
of pushing it. And dragging is not accurate because you unload the
wheel, rather than loading it, over obstructions.
Let's talk apples to apples here. The measuring wheel is a hand-
held device and will pivot both along the handle axis in your hand,
and swing side-to-side. We have TWO axes of motion here, where there's
only one for a tailwheel or nosewheel. It's not the same effect at
all. If you were able to make your wrist rigid so that the side-to-
side swing was impossible, your instability would disappear.
Dan
Old February 4th 10, 11:47 PM posted to rec.aviation.homebuilt
On Thu, 4 Feb 2010 12:04:48 -0800 (PST),
Not a completely true statement. Â*Have you ever used a measuring
wheel?
Leon
Â*Virtually every distance measuring wheel available on the market
RolaTape listed. DriVall Fencing's units do. Â*The DuraWheel does. So
Dan
Who said anything about instability? Not me. Properly handled, pushing
a measuring wheel is dead easy.. I'm saying the measuring wheels and
tail-wheels - and bycycles - are all set up the same way FOR
stability.
Old February 5th 10, 02:33 AM posted to rec.aviation.homebuilt
stability.
I mistook your meaning. Sorry.
Dan
AUDIO: Bush jewish. Blair jewish. Howard jewish. Sarkozy jewish. 1.2 million muslims dead. Thousands of Americans dead. Trillion$ missing. [email protected] Naval Aviation 0 November 2nd 07 06:56 PM
Source for tail wheels Simon Soaring 11 May 25th 05 05:05 AM
FS: Blanik L-13 Tail Skid & Tail Wheel Assembly Tim Hanke Soaring 0 February 8th 05 02:34 PM
Wheels Lou Parker Home Built 14 October 31st 04 01:08 AM
