DIY Two-Stroke Engine Construction Methods
Old March 10th 10, 12:17 PM posted to rec.aviation.homebuilt,rec.aviation.ultralight,rec.crafts.metalworking,rec.models.scale,uk.rec.models.engineering
Jim Wilkins
Default DIY Two-Stroke Engine Construction Methods
On Mar 10, 1:45*am, durabol wrote:
One method I have thought of is to produce a wax model of the engine
with molds (to a fairly high tolerance to minimize machining) ...
Brock
What machine tools do you have?
Some WW1 engine cylinders were machined from SOLID steel forgings.
Casting can easily have internal voids unless well designed, because
the metal shrinks as it solidifies inwards. Aluminum is easy enough to
melt that you could cast a simple shape and then test it for strength
or cut it apart.
Or you could make a lawnmower engine and see how durable it is.
jsw
DIY Two-Stroke Engine durabol[_2_] Home Built 55 April 5th 10 05:11 PM
Methods for altitude changes Mxsmanic Piloting 141 April 18th 07 12:48 AM
Small 4 stroke engine? Ron Wanttaja Home Built 35 July 2nd 05 07:25 PM
BSFC vs gas mileage, 2 stroke vs 4 stroke Jay Home Built 10 August 24th 04 02:26 PM
engine construction blueprints Håken Military Aviation 0 April 27th 04 05:23 PM
