![]() "Lloyd E. Sponenburgh" lloydspinsidemindspring.com wrote in message . 3.70... "basilisk" fired this volley in news:J4Nln.198564 : you will have to provide a slave cylinder or roots type blower to move the air. Some variants use a cylinder skirt with reed valving. LLoyd You're right, I didn't really consider that before posting. I supposed it could be worked out but that looks hard to do in a completely bottom assembled engine, just my 2 cents worth, I'm not an engine specialist. basilisk |
In article , "basilisk" wrote:
"Lloyd E. Sponenburgh" lloydspinsidemindspring.com wrote in message .3.70... "basilisk" fired this volley in news:J4Nln.198564 : you will have to provide a slave cylinder or roots type blower to move the air. Some variants use a cylinder skirt with reed valving. LLoyd You're right, I didn't really consider that before posting. I supposed it could be worked out but that looks hard to do in a completely bottom assembled engine, just my 2 cents worth, I'm not an engine specialist. basilisk it's not so hard, it just costs a bit more. but it adds a lot of grunt. the 750 i have puts out almost 90hp. dragster h2's running exotic fuels have been dynoed at over 400hp!. they need to be rebuilt often, but what drag motor doesn't. the quest for hp is expensive but doable. honda built a tt racer that got 18hp out of 50cc! the 8 speed gearbox got it up to 100mph. read about the mv augusta racers, you wouldn't believe me. |
In article , TonyW wrote:
On 3/10/2010 7:46 AM, in wrote: it's not so hard, it just costs a bit more. but it adds a lot of grunt. the 750 i have puts out almost 90hp. dragster h2's running exotic fuels have been dynoed at over 400hp!. they need to be rebuilt often, but what drag motor doesn't. the quest for hp is expensive but doable. honda built a tt racer that got 18hp out of 50cc! the 8 speed gearbox got it up to 100mph. read about the mv augusta racers, you wouldn't believe me. Suzuki built but never raced a 3 cylinder 50cc engine that was rated at the highest output per liter on record for use with pump gas. However to get to one liter it would have 60 cylinders... Tony yeah, with enough money and resources, pigs will fly. |
basilisk wrote:
"Lloyd E. Sponenburgh" lloydspinsidemindspring.com wrote in message . 3.70... "basilisk" fired this volley in news:J4Nln.198564 : you will have to provide a slave cylinder or roots type blower to move the air. Some variants use a cylinder skirt with reed valving. LLoyd You're right, I didn't really consider that before posting. I supposed it could be worked out but that looks hard to do in a completely bottom assembled engine, just my 2 cents worth, I'm not an engine specialist. basilisk Try modifying an existing engine...and don't go hard over on it being a 2-stroke. I've often thought of trying to construct a full 9 or 7 cylinder aircraft radial using Harley engine parts - hell, those engines have more in common with an air cooled radial than about anything I can think of other than a Pratt & Whitney. For your ultralight purpose, a basic V-twin would probably do, and I'd suggest the fuel injected HD 88B counterbalanced one...just to keep things smoother. The straight Dyna or touring Twin Cam 88 is lighter, but I'm not sure how much vibration it would produce if hard mounted. Something else you could do is use Harley studs and design your own crank and case to make a flat twin, if you just want to build an engine yourself - that would be a neat project, too. If you need to use a reducer, you can machine your own pulley plate and use a wide primary belt. Given that you'll be mounting the engine behind a prop, you may also ba able to get away with shaving the fins to lighten it a bit. I'd also suggest you hot-rod the motor to a high compression setup - that and the fuel injection will solve some horsepower vs altitude curve problems for you - or at least help minimize them. -- - Rufus |
On Mar 11, 3:20*am, Rufus wrote:
basilisk wrote: "Lloyd E. Sponenburgh" lloydspinsidemindspring.com wrote in message .3.70... "basilisk" fired this volley in news:J4Nln.198564 : you will have to provide a slave cylinder or roots type blower to move the air. Some variants use a cylinder skirt with reed valving. LLoyd You're right, *I didn't really consider that before posting. I supposed it could be worked out but that looks hard to do in a completely bottom assembled engine, just my 2 cents worth, I'm not an engine specialist. basilisk Try modifying an existing engine...and don't go hard over on it being a 2-stroke. *I've often thought of trying to construct a full 9 or 7 cylinder aircraft radial using Harley engine parts - hell, those engines have more in common with an air cooled radial than about anything I can think of other than a Pratt & Whitney. SNIP -- * * * - Rufus Worth noting: there is a radial project out there with quite a few builders that uses VW jugs and a custom crankcase and heads. Around 100hp if I remember correctly. There are also a couple of half VW engine projects with plans available. If you take a stroll around the national air and space museum you will get a feel for the art that went into many of the early engines. The old designers and machinists were a different breed, and their work inspires awe in any mechanically inclined mind. It is worth noting that many of the older radial and fan engine configurations used a pie- wedge style crankcase, where the cylinder and the case were a single piece, and the crankcase bolted together in pieces arranged in circumference to the crankshaft. With modern alloys and machining techniques, I've wondered if returning to this style might be tolerable for a small engine today. Lawn mowers are done similarly, and so I'd imagine an engine designed in this fashion would scale up quickly from a production standpoint. While building a new engine solely for art is a lofty goal, I can't really see it for any other reason. What performance specs could you be looking for that aren't currently available in a production engine, or are not otherwise achievable by making minor modifications to a production engine? The engine of interest to me lately is the new subaru TDI boxer motor. Wow that thing is fancy, and I'm hoping it makes its way to the states some time soon. With modern boosting techniques I'd also like to see the packard aero diesel configuration revisited, perhaps integrating some of the features in the elsbett engines. . If I was heading off in the scratch built direction, I would outsource the casting process. There are many shops domestic and overseas that can do short runs of castings based on a provided dxf file. It is unlikely that a backyard foundry will ever get close to the level of detail these shops can create. I would probably search far and wide before starting to CAD the thing up. Of course, thinking down the road, if ever I should build my own bird, I'm thinking Rotec, or PZL Franklin. I'd like to go heavy kung fu into engine design, but it is just way to much work, for way to little optimization. Thanks! |
DIY Two-Stroke Engine | durabol[_2_] | Home Built | 55 | April 5th 10 05:11 PM |
Methods for altitude changes | Mxsmanic | Piloting | 141 | April 18th 07 12:48 AM |
Small 4 stroke engine? | Ron Wanttaja | Home Built | 35 | July 2nd 05 07:25 PM |
BSFC vs gas mileage, 2 stroke vs 4 stroke | Jay | Home Built | 10 | August 24th 04 02:26 PM |
engine construction blueprints | Håken | Military Aviation | 0 | April 27th 04 05:23 PM |
