Scaled Composites builds plane for solo nonstop globe circumnavigation attempt
Old October 26th 03, 05:47 AM
David O
Default Scaled Composites builds plane for solo nonstop globe circumnavigation attempt
Aviation Week & Space Technology
10/27/2003, page 14
Virgin Atlantic Airways plans to use a Scaled Composites aircraft in
an attempt next year to complete the first solo nonstop
circumnavigation of the globe. The aircraft, dubbed the GlobalFlyer,
will be flown by either Steve Fossett or Virgin Atlantic Chairman
Richard Branson. Branson is acting as the reserve pilot. The aim is to
complete the flight in less than 80 hr. The Burt Rutan-designed,
composite-material aircraft has a maximum gross weight of 22,066 lb.
and an empty weight of 3,577 lb., which allows for 18,000 lb. of fuel.
Wingspan is 114 ft. The GlobalFlyer is powered by a single Williams
FJ44-3 turbofan engine. Maximum altitude for the pressurized cockpit
aircraft is 52,000 ft.
Old October 28th 03, 12:01 AM
Dave Hyde
The clip you posted didn't say, and I haven't
gotten this weeks issue yet, but I presume this
is also unrefueled?
Dave 'vectors to the tanker!' Hyde
Old October 28th 03, 12:51 AM
Kevin Horton
On Tue, 28 Oct 2003 00:01:13 +0000, Dave Hyde wrote:
The clip you posted didn't say, and I haven't gotten this weeks issue yet,
but I presume this is also unrefueled?
"Sir Richard Branson and Steve Fossett announce plans to attempt the
world's first non-stop solo flight around the globe without refuelling."
http://www.virginatlanticglobalflyer.com/
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://go.phpwebhosting.com/~khorton/rv8/
e-mail: khorton02(_at_)rogers(_dot_)com
Old October 28th 03, 12:31 PM
David O
is also unrefueled?
Actually, Dave, the clip I posted was the entire article. To me,
though, 18,000 lb of fuel kinda screamed "unrefueled" anyway. I'm
sure it did to you as well. The artist's rendering in Aviation Week
appeared very Voyager-like so I didn't consider anything but
unrefueled until you posed the question. Kevin's link confirms it
will be an unrefueled attempt.
If the GlobalFlyer performs nominally it will likely be a much easier
trip for Fossett or Branson than it was for Dick and Jeana. In my
opinion, it will therefore be less of an achievement but still quite
interesting technically. The GlobalFlyer will fly above most weather
at 45,000 ft.
I put together this Voyager/GlobalFlyer comparison using actual
performance numbers from the Voyager and nominal numbers for the
GlobalFlyer:
Voyager GlobalFlyer
Wing Span (ft) 110.7 114
Empty Weight (lb) 2,250 3,577
T.O. weight (lb) 9,695 22,066
Useful Load (lb) 7,445 18,489
Fuel (lb) 7,011 18,000
Distance (sm) 26,366 23,000
Flight Time (hr) 216.06 80
Flight Time (days) 9 3.33
Avg Speed (mph) 122.03 287.5
Avg fuel burn rate (lb/hr) 32.36 225
Optimum altitude (ft) 8,000 45,000
Max altitude (ft) 20,500 52,000
David O -- http://www.AirplaneZone.com
P.S. The distance shown for the Voyager is the actual distance flown,
not the FAI credited distance. The Voyager average speed is based on
the actual distance flown. The max altitude figure for the Voyager is
the maximum achieved (over Africa) in an attempt to get above weather.
Notice that although it will be a solo attempt, the GlobalFlyer's
useful load would allow for two people plus full fuel.
Old October 28th 03, 01:41 PM
nafod40
is also unrefueled?
A friend of mine logged a .3 while flying an F-111 at 300 feet and Mach
..95 (ingress) and Mach 1.3 (egress) in a Maple Flag exercise in Canada.
They burned 20,000+ lbs of go juice. I guess 18,000 lbs screamed "low
fuel light" to them. : )
at 45,000 ft.
I've had an interest in dynamic soaring, where you can extract energy
from the boundary of two different air streams (it's how an albatross
stays airborne just above the ocean). The ultimate would be to soar the
boundary of the jet stream, unpowered. Probably not doable, but never
say never. you might be able to extend the range at least this way.
Google "dynamic soaring" for more info.
Old October 28th 03, 01:48 PM
Corky Scott
is also unrefueled?
Actually Dave, the article does say:
refuelling.
This is a quote from the article.
Corky Scott
Old October 28th 03, 05:01 PM
Bernie the Bunion
refuelling.
Well now the Bunion is confused...... I thought that had already been
accomplished by the voyager flight.
where did they stop for fuel or what part of the globe did they not fly
around.
Old October 28th 03, 05:14 PM
Kyle Boatright
"Bernie the Bunion" wrote in message
refuelling.
around.
The key phrase there was "solo". The Voyager had a crew of two.
KB
Old October 28th 03, 05:20 PM
alexy
refuelling.
All but the "solo" part.
around.
Alex
Make the obvious change in the return address to reply by email.
Old October 28th 03, 05:28 PM
Corky Scott
On Tue, 28 Oct 2003 17:01:42 GMT, Bernie the Bunion
refuelling.
around.
Heh heh, what does the word "solo" mean to Bunion's?
Corky Scott
A Good Story Badwater Bill Home Built 15 September 3rd 03 03:00 PM
