reversed polarity to Dittel issue
Old April 15th 10, 04:33 PM posted to rec.aviation.soaring
Erik Braun
Default reversed polarity to Dittel issue
The repairman changed the fuse and all was ok.
Some radios have a thermal fuse on the side. It just has to be pushed
and the radio works again. At least some Becker types have this.
Regards, Erik.
Old April 15th 10, 10:14 PM posted to rec.aviation.soaring
ContestID67[_2_]
The MicroAire radios have an internal "pico" fuse that protects the
unit from reversed power. Ask me how I know ;-) Maybe the Becker has
the same thing.
A pico fuse is about the side of a 1/8w resistor (grain of rice) and
is soldered inside the unit. It is not considered user repairable/
replaceable. While I have been able to replace the fuse, it isn't a
task for the uninitiated without a good small wattage, small grounded
tip, soldering iron. Too much heat and you can lift a trace or scorch
the board. Too big of a soldering iron tip and you might unsolder
more than you intend. A bit of a static spark and the device goes
poof. Sorry to scare anyone but you don't want to toast a very nice
radio.
Old April 15th 10, 10:36 PM posted to rec.aviation.soaring
Dave Nadler
unit from reversed power. *Ask me how I know ;-) *Maybe the Becker has
the same thing.
is soldered inside the unit. *It is not considered user repairable/
replaceable. *While I have been able to replace the fuse, it isn't a
tip, soldering iron. *Too much heat and you can lift a trace or scorch
the board. *Too big of a soldering iron tip and you might unsolder
more than you intend. *A bit of a static spark and the device goes
poof. *Sorry to scare anyone but you don't want to toast a very nice
radio.
One time I saw a 1943 Buzzard-Master - someone hooked up
the battery backwards and there was a giant flash from
under the panel ! Maybe look under the panel for one of them
old-style screw fuses and put a penny in there ?
Dittel FSG 50 in Dittel base station [email protected] Soaring 2 February 18th 09 09:15 AM
Dittel FSG 50 in Dittel base station, Perfect for crews and FBO [email protected] Soaring 1 February 18th 09 09:15 AM
Arlington Fly-In Lawsuit Reversed Ron Wanttaja Home Built 8 October 17th 08 03:04 PM
reversed towbar Jose Piloting 2 January 6th 06 02:49 AM
Reversed ADF indications DP Piloting 12 November 10th 03 03:01 AM
