Mike -
I occasionally get a loss of signal with my ewMicroRecorders (I have had 2); but it usually lasts for no more than about 5 seconds. Do you have the antenna securely attached, with a good view of the sky? You didn't alter the antenna wire length, did you? --Noel |
On May 3, 2:50*am, "noel.wade" wrote:
Mike - I occasionally get a loss of signal with my ewMicroRecorders (I have had 2); but it usually lasts for no more than about 5 seconds. Do you have the antenna securely attached, with a good view of the sky? You didn't alter the antenna wire length, did you? --Noel I see a lot of dropped signals on mine as well. I've used both a Cambridge Model 20 and an NK Clearnav in exactly the same place (identical antenna positions). I was planning to try temporarily relocating the antenna to an even more unobstructed spot. P3 |
For Sale: EW MicroRecorder $500 | noel.wade | Soaring | 1 | February 24th 10 07:14 PM |
EW microRecorder and ERIXX | --=JJay=--[_2_] | Soaring | 8 | June 12th 09 01:00 PM |
EW Microrecorder Battery Issues? | ContestID67[_2_] | Soaring | 5 | May 10th 09 12:25 PM |
ConnectMe / EW Microrecorder | Kevin Neave | Soaring | 0 | May 27th 07 06:48 PM |
microTracker/microRecorder | Bob | Soaring | 15 | May 11th 06 01:50 PM |
