ew microrecorder dropping GS signal
Old May 3rd 10, 02:32 PM posted to rec.aviation.soaring
Papa3
Default ew microrecorder dropping GS signal
On May 3, 2:50*am, "noel.wade" wrote:
Mike -
I occasionally get a loss of signal with my ewMicroRecorders (I have
had 2); but it usually lasts for no more than about 5 seconds.
Do you have the antenna securely attached, with a good view of the
sky? You didn't alter the antenna wire length, did you?
--Noel
I see a lot of dropped signals on mine as well. I've used both a
Cambridge Model 20 and an NK Clearnav in exactly the same place
(identical antenna positions). I was planning to try temporarily
relocating the antenna to an even more unobstructed spot.
P3
For Sale: EW MicroRecorder $500 noel.wade Soaring 1 February 24th 10 07:14 PM
EW microRecorder and ERIXX --=JJay=--[_2_] Soaring 8 June 12th 09 01:00 PM
EW Microrecorder Battery Issues? ContestID67[_2_] Soaring 5 May 10th 09 12:25 PM
ConnectMe / EW Microrecorder Kevin Neave Soaring 0 May 27th 07 06:48 PM
microTracker/microRecorder Bob Soaring 15 May 11th 06 01:50 PM
