#41
John Cochrane wrote:
No, Gary means it. In theory, we can gain a lot by strong pull ups and pushovers in thermal entries and exits. In fact, in theory, you can stay up when there is only sink. You push to strong negative g's in the sink, then strong positive gs when you are out of the sink. Huh? Think of a basketball; your hand is sink and the ground is still air. When you push hard negative g's in the sink, the glider exits the sink with more airspeed than it entered, just like the basketball as it hits your hand. The opposite happens when you pull hard for the first second or two after entering lift. I _think_ I get what you are saying: you basically propose extracting the kinetic energy that is available due to the different fluid speeds. It doesn't matter which direction the fluid streams flow - merely that one part of the fluid is moving relative to another part and you can move your aircraft from one to the other. We're so used to getting energy out of upward fluid flows that we overlook the fact that in a fundamental sense it doesn't matter (to a first approximation) which direction the stream is going. So what you all seem to be saying is that there is energy available for extraction in wind shear, sinks, and thermals. If the whole mass of fluid is moving then you are out of luck because you need a difference in fluid speeds - with the exception that upward flows always make energy available due to conversion of the fluid kinetic energy to gravitational potential energy. (Hence the "first approximation" caveat.) Is all that about right? |
#42
On Jun 6, 10:33*am, John Cochrane
wrote: Hi John: Precisely what Taras Keceniuck, Paul MacCready and I were doing in a DARPA funded study when Paul passed away. Best Regards, Gary Osoba Is the study finished and any publication done? I want the pitch controller for the worlds! Hmm. Come to think of it, I don't recall seeing anything in the rules that prevent use of an autopilot. Do you even have to have a human on board? |
#43
Hi John: Precisely what Taras Keceniuck, Paul MacCready and I were doing in a DARPA funded study when Paul passed away. Best Regards, Gary Osoba Is the study finished and any publication done? I want the pitch controller for the worlds! John Cochrane Hmmm..I see the ArduIMU runs about $300. That might make a suitable start on it? Brian W |
#44
On Jun 5, 4:08*pm, Jim Logajan wrote:
John Cochrane wrote: No, Gary means it. In theory, we can gain a lot by strong pull ups and pushovers in thermal entries and exits. In fact, in theory, you can stay up when there is only sink. You push to strong negative g's in the sink, then strong positive gs when you are out of the sink. Huh? Think of a basketball; your hand is sink and the ground is still air. When you push hard negative g's in the sink, the glider exits the sink with more airspeed than it entered, just like the basketball as it hits your hand. The opposite happens when you pull hard for the first second or two after entering lift. I _think_ I get what you are saying: you basically propose extracting the kinetic energy that is available due to the different fluid speeds. It doesn't matter which direction the fluid streams flow - merely that one part of the fluid is moving relative to another part and you can move your aircraft from one to the other. We're so used to getting energy out of upward fluid flows that we overlook the fact that in a fundamental sense it doesn't matter (to a first approximation) which direction the stream is going. So what you all seem to be saying is that there is energy available for extraction in wind shear, sinks, and thermals. If the whole mass of fluid is moving then you are out of luck because you need a difference in fluid speeds - with the exception that upward flows always make energy available due to conversion of the fluid kinetic energy to gravitational potential energy. (Hence the "first approximation" caveat.) Is all that about right? Yes. Your wing is a machine, and the work it performs imparts a downward flow to the air it moves through. When that downward force is aligned in a direction that opposes the movement of the air, it gains energy. The air movement can be from the side, from above, or below- the most efficient case since this vector opposes gravity. The transfer of energy from air motion can be increased by manipulating the inertial field of the glider, and there is an optimal g loading or unloading for each case. Although physicists define such inertial forces as "psuedo", the wing does not know this and must develop twice the lift to sustain 2g flight as 1g flight, three times the lift for 3g flight,etc. The power transferred from the air to the wing increases linearly with g force increases, while the the losses associated with the increased g loadings are fractional and therefore nonlinear, yielding excess power. This excess power can be carried by the glider into a differential airmass with relative sink by a coupled acceleration and a portion of it can be transferred to this airmass. The case of 0g accelerations (freefall) is special in that theoretically the wing doesn't produce induced drag. Theoretically only, because the lift distribution will never be perfect- especially in the unsteady flows which punctuate a soaring environment. In practice, I have found 0g to be the best target for accelerations since most of our wing sections are not designed to fly efficiently upside down and everything is happening so quickly you lose less if you guess wrong on the strength of the relative downdraft. Much of this is counterintuitive. For example, here's something presented in a 2001 lecture on the subject. It is stated as exclusionary to emphasize how flight through a discontinuous atmosphere can up-end long held conventions. "For any body of mass moving through or in contact with a medium that is not uniform, the most efficient path(s) for a given power input will never be defined by a straight line or a constant speed." - Osoba's Theorem of Dynamic Locomotion The concise statement of this is "...never be defined by a constant velocity..." since velocity incorporates both speed and direction but most pilots don't understand the term that way. Best Regards, Gary Osoba |
#45
Gary Osoba wrote:
/snip/ "For any body of mass moving through or in contact with a medium that is not uniform, the most efficient path(s) for a given power input will never be defined by a straight line or a constant speed." - Osoba's Theorem of Dynamic Locomotion /snip/ Gary Osoba Darn! I was following along nicely with this note, until I got to the conjunction of a heading which included the word "physics" and a person citing his own name for a physics construct. That's usually a warning about the level of information.... :-) Brian W |
#46
On Jun 5, 3:07*pm, Gary Osoba wrote:
On Jun 5, 2:41*pm, Nine Bravo Ground wrote: On Jun 5, 2:30*pm, Gary Osoba wrote: On Apr 25, 8:21*am, Andy wrote: As an aside - the strong G-effect on induced drag is the main reason why you should try to avoid hardpullupsinto thermals - you give away a bunch of altitude. 9B Yes, if you both accelerated and are now pulling up in a constant velocity of transportation field. But by mentioning the thermal, this is not likely. With discontinuous fluid fields, coupled pullups and pushovers which are properly timed within a shifting frame of reference have the potential to gain much more energy than is ever lost to induced and friction drag- dry or fully loaded. The fully loaded case has more potential in typical soaring environments because more time is available to apply the technique and the events can be further apart. For most gliders, the optimized multiplier is so substantial that you run out of positive g maneuvering envelope (based on JAR standards) with a mere 2-3 knots of lift. Best Regards, Gary Osoba If you mean dynamic soaring then the airmass velocity gradient needs to be horizontal, not vertical as is the case with thermals - plus the magnitude of the gradient in a thermal is way too low to be useful, even if it were in the correct orientation. If you aren't referring to dynamic soaring then all I can say is "huh"? 9B 9B: The physics apply in all directions, but the potential is greatest with positive vertical velocity gradient since that vector directly opposes gravity- *and that's our job if we're going to stay up. The reason the horizontal gradients are more readily recognized is that they are often sustainable in a cycle, witness the Albatross. However, I'm not wanting to argue about it. I know the physics and the math and have been using them effectively for about 15 years now. Best Regards, Gary Osoba Got it - sounds a bit uncomfortable since moving the velocity vector around in the vertical axis takes a lot more aggressiveness then horizontally. I assume it also helps to know where the boundaries of the gradients are before you reach them. If you miss you just mush and lose altitude fro all the induced drag. It's the exact opposite technique from what I see and hear from most top racing pilots who advise flying slower than McCready theory and maintaining laminar flow over the wing with only modest maneuvering. How do you decide when to use which technique when you are cruising along at 15,000 feet and 85 knots and run into a 6 knot thermal? 9B |
#47
On Jun 6, 10:06*am, Andy wrote:
Got it - sounds a bit uncomfortable since moving the velocity vector around in the vertical axis takes a lot more aggressiveness then horizontally. I assume it also helps to know where the boundaries of the gradients are before you reach them. If you miss you just mush and lose altitude fro all the induced drag. Yes, as you have properly shown in the still air case- only now the penalties are even higher than in still air. It's the exact opposite technique from what I see and hear from most top racing pilots who advise flying slower than McCready theory and maintaining laminar flow over the wing with only modest maneuvering. How do you decide when to use which technique when you are cruising along at 15,000 feet and 85 knots and run into a 6 knot thermal? 9B Well. that's the trick, isn't it? I would say that if you're at 15,000', full of water, but only going 85 knots, it must be pretty spotty overall and would recommend sticking to the conventional approach. For one thing, you only have a little over a second of deceleration time at that speed. When the conditions allow, it is much better to have more maneuvering time through higher velocities. However, it has also been shown that chasing MacCready through a thermal will usually yield poorer results than stick-fixed excursions (Braunschweig Tech. University, 1982). Chasing any of this with the vario is futile due to lag times. In any event, much of this does run counter to the normal "racing" protocol. E.g., Moffat's final turn at the top of a climb when it is tightened and you accelerate across the thermal core before exiting. Exactly opposite to the best total energy/dynamic maneuvering scenario, apart from tightening the turn in order to be right at the center of the core for the straight line flight. I only entered a contest once as an individual, and chose to fly it without a computer (or even a speed ring). I did effectively use these techniques, and lateral dynamic maneuvering as well. Best Regards, Gary Osoba |
#48
thermal will usually yield poorer results than stick-fixed excursions (Braunschweig Tech. University, 1982). Chasing any of this with the vario is futile due to lag times. As I think of Gary's maneuvers, they are more characterized by sharp pull ups and pushovers when lift changes, as opposed to classic "chasing the needle" which we know doesn't work. I suspect that when we get this right, G and airspeed will be a much more important input than varios. We're trying to pull when we get the increased G from entering a thermal, "bouncing" off the change in vertical speed, and vice versa. Similarly, the time when this works is during the rush of positive airspeed as you enter a vertical gust. The instrument or pitch controller that gets this right may be essentially one that tells us what the G reading is subtracting the effects of controls -- a "total energy g meter" if you will. Then you can pull when "total energy" g is positive and push when it's negative, subtracting the "stick g" In any event, much of this does run counter to the normal "racing" protocol. E.g., Moffat's final turn at the top of a climb when it is tightened and you accelerate across the thermal core before exiting. Exactly opposite to the best total energy/dynamic maneuvering scenario, apart from tightening the turn in order to be right at the center of the core for the straight line flight. Moffat's technique was great in the 70s, but most pilots don't use it now. Especially in wind or under clouds, there is often not sink surrounding a thermal, but a long stretch of buoyant air. They didn't know that in the 70s because they didn't have netto or speed to fly varios, so when they sped up to 90 knots they were in fact sinking like stones. Most of the time the key to thermal exit is to leave gently in such a way as to milk the surrounding up air while cruising relatively slowly for a few miles John Cochrane |
#49
On Jun 7, 5:42*am, Gary Osoba wrote:
In any event, much of this does run counter to the normal "racing" protocol. E.g., Moffat's final turn at the top of a climb when it is tightened and you accelerate across the thermal core before exiting. I've never understood how you are supposed to do that. I'm *already* circling as tightly as I can at the speed I'm flying! Unless all you're doing is increasing the bank angle while maintaining the same elevator setting, which will make you turn in a bit more and enter a dive. |
#50
On Jun 6, 1:14*pm, John Cochrane
wrote: However, it has also been shown that chasing MacCready through a thermal will usually yield poorer results than stick-fixed excursions (Braunschweig Tech. University, 1982). Chasing any of this with the vario is futile due to lag times. As I think of Gary's maneuvers, they are more characterized by sharp pull ups and pushovers when lift changes, as opposed to classic "chasing the needle" which we know doesn't work. I suspect that when we get this right, G and airspeed will be a much more important input than varios. We're trying to pull when we get the increased G from entering a thermal, "bouncing" off the change in vertical speed, and vice versa. Similarly, the time when this works is during the rush of positive airspeed as you enter a vertical gust. The instrument or pitch controller that gets this right may be essentially one that tells us what the G reading is subtracting the effects of controls -- a "total energy g meter" if you will. Then you can pull when "total energy" g is positive and push when it's negative, subtracting the "stick g" In any event, much of this does run counter to the normal "racing" protocol. E.g., Moffat's final turn at the top of a climb when it is tightened and you accelerate across the thermal core before exiting. Exactly opposite to the best total energy/dynamic maneuvering scenario, apart from tightening the turn in order to be right at the center of the core for the straight line flight. Moffat's technique was great in the 70s, but most pilots don't use it now. Especially in wind or under clouds, there is often not sink surrounding a thermal, but a long stretch of buoyant air. They didn't know that in the 70s because they didn't have netto or speed to fly varios, so when they sped up to 90 knots they were in fact sinking like stones. Most of the time the key to thermal exit is to leave gently in such a way as to milk the surrounding up air while cruising relatively slowly for a few miles John Cochrane Okay, this is going to totally mess up my next contest. I admit that I substantially rely on Gs to decide whether to turn in lift - the vario only tells you if you made a good choice 1/4 turn later. I honestly don't find that many thermals with a very strong gradient, so I am wondering how much benefit I'll get from the extra push and pull, especially if the optimal strategy emphasizes search range over theoretical McCready optimum cruise speed. As to flying 85 knots - that's pretty common for me when I am dry - maybe 95 knots wet on a good day. If the thermals are closely placed and consistent and the lift band is deep enough I'll bump it up, otherwise I like the extra search range. 9B |
| Thread Tools | |
| Display Modes | |
| Physics Quiz Question | Dallas | Piloting | 28 | August 14th 07 03:02 AM |
| Pull up a chair and hear me out: | Vaughn | Aviation Marketplace | 0 | February 2nd 06 03:04 AM |
| Physics question | Rich S. | Home Built | 62 | September 14th 05 03:05 PM |
| Question about center-line push-pull engine configuration | Shin Gou | Home Built | 4 | June 7th 04 06:57 PM |
| Glider pull-up and ballast | M B | Soaring | 0 | September 15th 03 07:29 PM |
