trailer wheels won't turn
Old June 17th 10, 03:00 PM posted to rec.aviation.soaring
Andy[_1_]
Default trailer wheels won't turn
On Jun 17, 5:45*am, chris wrote:
Also is there a way to temporarily disengage the brakes, I was
thinking i could take out the brake pads etc.
If the wheels are locked by the brakes it is very unlikely that you
would be able to remove the drums,.and you can't remove the shoes
without removing the drums. The first step in fixing the problem will
have to be getting the brakes to release.
You say the brake rod is free to move. Can you determine if the
cables are under tension? It may be possible to feel slack in the
cable outers. If the cables themselves are seized it may be possible
to free them by working them sideways at the same time as lubricating
them.
If the cables are slack then the problem must be internal to the
drum. If all else fails squirting penetrating oil in every possible
opening may help. That's a last resort thought as you may have to
replace the contaminated shoes.
If pushing it backwards, as suggested by Peter, does not work then try
rocking the wheels backward and forwards. One way to do that would be
to pull the trailer tongue sideways in opposite directions as hard and
quickly as possible.
Of course this all assumes that you left the trailer with the parking
brake set. If not then check to see if anyone you may have upset
recently has welded the drums to the back plates.
Good luck!
Andy
Old June 18th 10, 09:36 AM posted to rec.aviation.soaring
Michael Huber
Is the hand brake lever nearly vertical when the brake is engaged? I once
had exactly the same symptoms with a relatively new Swan Trailer. There is a
rod that connects the brake lever in front to the flat bar that distributes
brake force from the rod to the cables. Due to run - in wear of the brake
pads the rod moved too far forward when pulling the brake lever and popped
out of its support and jammed. It took me some time to find that ...
Michael
Old June 18th 10, 02:20 PM posted to rec.aviation.soaring
chris
I used a 1 lb /.45kg hammer and hit both brake mounting plates before
7am to the neigbors delight. The first side released after hammering.
The second side was harder, I hammered but it did not release until
after rolling the trailer back and forth. The top shoe was jamming on
that side. I could see that the lower shoe was not in contact with
the drum.
All in all it turned out to be just a few minutes and all is good
now. I did not have to jack up the trailer or take the wheels off.
Thankfully I got lots of good advice from RAS.
I should get better gas mileage with wheels that turn.
The trailer has been sheltered from rain. All this rusting must have
just been from 2 months humidity [in ample supply].
I did not find a slot to adjust a star wheel. I have done that on
cars in the past so I know what to look for. This design has 2 slots
but they are for the spring to hook through.
I never did figure out what the bolt was for, shown in the 2 o'clock
position in the photo:
http://gliderpilot.org/Temporary
On both sides there were small viewing holes to see if the shoe was in
contact with the drum [shown in the 10 & 5 o'clock position]
I suppose I should soon take the drums off and lubricate the sides of
the shoes/mechanism [not the face that touches the drum].
I don't know if the mechanism or the face of the shoe and the drum
surface that rusted together.
Thanks guys!
Chris
Old June 18th 10, 02:58 PM posted to rec.aviation.soaring
Peter Scholz[_2_]
the drum.
Good to hear that it worked out well.
nice shot. Your brake seems to be in a very good state, compared to
others I have seen here in Germany.
You have KNOTT brake. The bolt opposite the cable inlet is for adjusting
the brake, e.g. to compensate for pad wear. It has the same function as
the star wheel used on other types.
The instructions (partly) from KNOTT to do the adjustments are as follows:
Make sure that the rod and cables are under no tension.
Turn the adjustment bolt clockwise until the wheel cannot be turned any
more or turns very hard. (Turn the wheel only in Forward direction, as
the brake loosens itself automatically when turning the wheel backwards)
Then loosen approx. 1/2 turn counter-clockwise until the wheel turns
free again. a slight scratching noise doesn't harm,
A complete inscruction as well as diagrams of the inside ofthe brake can
be found here (only german, I'm afraid):
http://www.boeckmann.com/pferdeanhae...ein_66564.html
Peter Scholz
ASW24 JE
Thanks guys!
Chris
Old June 18th 10, 08:21 PM posted to rec.aviation.soaring
Chris Reed[_2_]
I have a KNOTT trailer, which I presume has KNOTT brakes as well.
Sometimes after standing over a humid winter one or both brakes locks
on. The solution is a hammer (I now keep a 4 lb club hammer in the
trailer). Jack up the offending wheel, give the head of each wheel nut a
firm tap, rock the wheel, repeat until it frees.
I've had the brakes checked out by a garage (auto repair shop in US?)
and all is fine, but this still happens. My guess is that somewhere in
the brake mechanism is a narrow clearance which tends to lock up with
corrosion.
The wheel won't free up if I don't jack it off the ground (well, not
without hitting it harder than I care to), but jacked up it usually
frees before I've tapped every wheel nut. Obviously, hit the nuts
square-on so as not to round them over.
Old June 20th 10, 03:18 AM posted to rec.aviation.soaring
Morgans[_2_]
"Chris Reed" wrote
I've had the brakes checked out by a garage (auto repair shop in US?) and
all is fine, but this still happens. My guess is that somewhere in the
corrosion.
Most all drum brakes on automobiles have strong springs that forcibly pull
the brake shoes away from the drums, nearly all of the way. Only a small
part of the pad would be touching the drum in one small area of each shoe.
That is when the adjusters are working well and are keeping the pads out as
far as they are able. Most are not working well, and have a good bit of
slack that the brake piston has to take up when you press on the brakes. A
shoe in this condition does not have enough contact area with the shoe and
drum to rust together.
I am not familiar with this particular model of brake, but with most cable
actuated brakes, there can not be a lot of clearance from the drum, or the
cable movement would be too small to take up the slack and apply the
stopping pressure. It is the nature of the beast that the design must have
the shoes in closer contact to the drum, thus increasing the likelihood of
the two parts rusting together.
It might be a good idea to back off the adjusting nut, or star wheel
(whatever your model would have as an adjuster) before parking the trailer
for the winter.
Jim in NC
Trailer tires for old (1981) Komet Trailer [email protected] Soaring 3 May 13th 09 10:24 PM
Minden Trailer Dolly Wheels gfoster07k Soaring 3 September 19th 08 05:12 AM
Where can I buy wheels for a Cobra trailer? Eric Greenwell Soaring 5 April 28th 07 03:44 AM
Wheels [email protected] Soaring 7 October 19th 05 02:29 PM
Replacing Cobra trailer wheels samcgiltner Soaring 8 August 12th 04 07:46 PM
