In article , robert
arndt writes Dave Eadsforth wrote in message news:$P6suhAzKlEAFwML ... Good day, good people, I wondered if anyone might be able to help with a couple of questions on the Junkers Ju86R-1 high altitude reconnaissance aircraft that was in service between 1943 and 1944? I have a reference that states that these were operated by a Luftwaffe unit called the 1./Versuchsverband Ob.d.L. Can anyone tell me in which theatre this unit operated, and if at all possible, which base(s)? Forty Ju-86Ps were delivered to Versuchsverband Ob.d.l., 2.(F)/Aufkl.Gr.33, and Kommando Rowehl in 1940. Most were P-2 recon a/c but there were also P-1 bomber aircraft. The P-2 was unarmed at first but the P-2 could carry four SC250 bombs. It was used in the same recon role but also performed bombing missions on occasion. The aircraft operated over England as a nuisance raider before being used to take photos of the Soviet Union prior to the invasion of June 1941. When the Ju-86R became available in 1941 it was used again against southern England until by September 1942 the Spitfire IX was able to reach it. After that, the a/c operated mostly on the eastern and southern fronts. Is there any (accessible) record of the operations they carried out? I haven't seen any... Also, the Ju86P that preceded the Ju86R-1 was given a single rear-firing machine gun after the first ones were shot down by specially prepped Spitfire Vs. (It didn't help!) Was the Ju86R-1 given any defensive armament? Not that I can see from the photographic record; however, if a single MG was mounted it most likely was in a dorsal position... the dustbin mount having ben removed and no photos of a nose gun. I'll look around to see if I can find a pic with armament. There was also the Ju86R-2, which was a bomber version; did that have any defensive armament? Probably not, just the four SC250 bombs as in the P-version. The bombers were only used "on occassion"... Thanks very much! Cheers, Dave Rob Hi Rob, Thanks very much for all that - very much appreciated! Cheers, Dave -- Dave Eadsforth |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 02:31 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
