One other thing... DO include a fuse or circuit breaker at the battery
and do make certain that the connections between the CB and the battery are absolutely as reliable as you can make them (as mentioned on another thread, problems here aren't covered by your CB). I recommend a 5 amp push to reset CB, provided that you have some place to mount it correctly, teflon insulated aircraft wire of 18ga and Molex or equivalent industrial quality crimp on connectors which are *far* better than consumer grade stuff at your hardware store. This is a great area to solicit some help if you aren't completely confident in your ability. That's my public service announcement for the day :-). -T8 |
On Aug 24, 11:14*am, T8 wrote:
One other thing... DO include a fuse or circuit breaker at the battery and do make certain that the connections between the CB and the battery are absolutely as reliable as you can make them (as mentioned on another thread, problems here aren't covered by your CB). *I recommend a 5 amp push to reset CB, provided that you have some place to mount it correctly, teflon insulated aircraft wire of 18ga and Molex or equivalent industrial quality crimp on connectors which are *far* better than consumer grade stuff at your hardware store. *This is a great area to solicit some help if you aren't completely confident in your ability. That's my public service announcement for the day :-). -T8 And Evan, why do we put fuses on the batteries and why do we use aircraft wire? I wonder if the aircraft in the following report had a fused battery and aircraft wire? http://www.ntsb.gov/ntsb/brief.asp?e...01X51612&key=1 Ray Lovinggood Carrboro, North Carolina, USA |
On Aug 24, 11:39*am, rlovinggood wrote:
On Aug 24, 11:14*am, T8 wrote: One other thing... DO include a fuse or circuit breaker at the battery and do make certain that the connections between the CB and the battery are absolutely as reliable as you can make them (as mentioned on another thread, problems here aren't covered by your CB). *I recommend a 5 amp push to reset CB, provided that you have some place to mount it correctly, teflon insulated aircraft wire of 18ga and Molex or equivalent industrial quality crimp on connectors which are *far* better than consumer grade stuff at your hardware store. *This is a great area to solicit some help if you aren't completely confident in your ability. That's my public service announcement for the day :-). -T8 And Evan, why do we put fuses on the batteries and why do we use aircraft wire? * I wonder if the aircraft in the following report had a fused battery and aircraft wire? http://www.ntsb.gov/ntsb/brief.asp?e...01X51612&key=1 Ray Lovinggood Carrboro, North Carolina, USA Yeah, there's one convert, for sure! Btw, if anyone wonders where to get them, McMaster Carr is a good source of Molex connectors and crimp on terminals. Get a good quality crimper and a wire stripper while you are at it. They also sell teflon insulated wire. Mouser Electronics is another source for good quality electrical bits, including circuit breakers (but not teflon wire IIRC). Some of the glider supply guys have a pretty good selection of stuff too. -Evan Ludeman / T8 |
On Aug 24, 11:14*am, T8 wrote: One other thing... DO include a fuse or circuit breaker at the battery and do make certain that the connections between the CB and the battery are absolutely as reliable as you can make them (as mentioned on another thread, problems here aren't covered by your CB). *I recommend a 5 amp push to reset CB, provided that you have some place to mount it correctly, teflon insulated aircraft wire of 18ga and Molex or equivalent industrial quality crimp on connectors which are *far* better than consumer grade stuff at your hardware store. *This is a great area to solicit some help if you aren't completely confident in your ability. That's my public service announcement for the day :-). -T8 And Evan, why do we put fuses on the batteries and why do we use aircraft wire? * I wonder if the aircraft in the following report had a fused battery and aircraft wire? http://www.ntsb.gov/ntsb/brief.asp?e...01X51612&key=1 Ray Lovinggood Carrboro, North Carolina, USA We put the fuse right at to the battery so there is never a high current running through the rest of the circuitry. Wire short anywhere- fuse blows. This simple protection prevents having to deal with the consequences of many sins, including the PVC insulated wire many production gliders are incorporating. This is a simple and very useful safety enhancement which costs about $3 and takes 20 minutes to accomplish. Unless something falls on the battery terminals, you're pretty well covered. FWIW UH |
One other thing... DO include a fuse or circuit breaker at the battery and do make certain that the connections between the CB and the battery are absolutely as reliable as you can make them (as mentioned on another thread, problems here aren't covered by your CB). *I recommend a 5 amp push to reset CB, provided that you have some placeer Moxex-type connectors to mount it correctly, teflon insulated aircraft wire of 18ga and Molex or equivalent industrial quality crimp on connectors which are *far* better than consumer grade stuff at your hardware store. *This is a great area to solicit some help if you aren't completely confident in your ability. That's my public service announcement for the day :-). -T8 For any battery connections I highly recommend Anderson Powerpole connectors: http://www.andersonpower.com/product...onnectors.html. They are hermaphorditic (sexless) and are being used as a defacto standard in the Amateur Radio community for battery connections. This article: http://www.westmountainradio.com/supportrr.htm gives details on their application. There was a recent article in one of the ham magazines discussing their advantages over Molex-type connectors. The use of 30-amp size connectors has been suggested as standard due to their rugged construction and low contact resistance. Don. |
On Aug 24, 9:01*pm, Donald S Brant Jr wrote:
On Aug 24, 11:14*am, T8 wrote: One other thing... DO include a fuse or circuit breaker at the battery and do make certain that the connections between the CB and the battery are absolutely as reliable as you can make them (as mentioned on another thread, problems here aren't covered by your CB). *I recommend a 5 amp push to reset CB, provided that you have some placeer Moxex-type connectors to mount it correctly, teflon insulated aircraft wire of 18ga and Molex or equivalent industrial quality crimp on connectors which are *far* better than consumer grade stuff at your hardware store. *This is a great area to solicit some help if you aren't completely confident in your ability. That's my public service announcement for the day :-). -T8 For any battery connections I highly recommend Anderson Powerpole connectors:http://www.andersonpower.com/product...onnectors.html. They are hermaphorditic (sexless) and are being used as a defacto standard in the Amateur Radio community for battery connections. *This article:http://www.westmountainradio.com/supportrr.htmgives details on their application. *There was a recent article in one of the ham magazines discussing their advantages over Molex-type connectors. *The use of 30-amp size connectors has been suggested as standard due to their rugged construction and low contact resistance. Don. We also use Powerpoles for the same reason. They will take much more abuse than Molex connectors and have virtually no power loss. Can get them at any hobby shop that handles RC cars. Note these are not hobby products, they are industrial connectors. UH |
On Aug 25, 9:25*am, wrote:
On Aug 24, 9:01*pm, Donald S Brant Jr wrote: On Aug 24, 11:14*am, T8 wrote: One other thing... DO include a fuse or circuit breaker at the battery and do make certain that the connections between the CB and the battery are absolutely as reliable as you can make them (as mentioned on another thread, problems here aren't covered by your CB). *I recommend a 5 amp push to reset CB, provided that you have some placeer Moxex-type connectors to mount it correctly, teflon insulated aircraft wire of 18ga and Molex or equivalent industrial quality crimp on connectors which are *far* better than consumer grade stuff at your hardware store. *This is a great area to solicit some help if you aren't completely confident in your ability. That's my public service announcement for the day :-). -T8 For any battery connections I highly recommend Anderson Powerpole connectors:http://www.andersonpower.com/product...onnectors.html. They are hermaphorditic (sexless) and are being used as a defacto standard in the Amateur Radio community for battery connections. *This article:http://www.westmountainradio.com/sup...tmgivesdetails on their application. *There was a recent article in one of the ham magazines discussing their advantages over Molex-type connectors. *The use of 30-amp size connectors has been suggested as standard due to their rugged construction and low contact resistance. Don. We also use Powerpoles for the same reason. They will take much more abuse than Molex connectors and have virtually no power loss. Can get them at any hobby shop that handles RC cars. Note these are not hobby products, they are industrial connectors. UH I'll have to check these out. FWIW, my Molex recommendation was intended for the spade lug connectors that attach directly to the battery -- these are bullet proof. I agree that the Molex disconnects are a little light duty. -T8 |
On Aug 25, 7:28*am, T8 wrote:
On Aug 25, 9:25*am, wrote: On Aug 24, 9:01*pm, Donald S Brant Jr wrote: On Aug 24, 11:14*am, T8 wrote: One other thing... DO include a fuse or circuit breaker at the battery and do make certain that the connections between the CB and the battery are absolutely as reliable as you can make them (as mentioned on another thread, problems here aren't covered by your CB). *I recommend a 5 amp push to reset CB, provided that you have some placeer Moxex-type connectors to mount it correctly, teflon insulated aircraft wire of 18ga and Molex or equivalent industrial quality crimp on connectors which are *far* better than consumer grade stuff at your hardware store. *This is a great area to solicit some help if you aren't completely confident in your ability. That's my public service announcement for the day :-). -T8 For any battery connections I highly recommend Anderson Powerpole connectors:http://www.andersonpower.com/product...onnectors.html. They are hermaphorditic (sexless) and are being used as a defacto standard in the Amateur Radio community for battery connections. *This article:http://www.westmountainradio.com/sup...givesdetailson their application. *There was a recent article in one of the ham magazines discussing their advantages over Molex-type connectors. *The use of 30-amp size connectors has been suggested as standard due to their rugged construction and low contact resistance. Don. We also use Powerpoles for the same reason. They will take much more abuse than Molex connectors and have virtually no power loss. Can get them at any hobby shop that handles RC cars. Note these are not hobby products, they are industrial connectors. UH I'll have to check these out. FWIW, my Molex recommendation was intended for the spade lug connectors that attach directly to the battery -- these are bullet proof. *I agree that the Molex disconnects are a little light duty. -T8 And good advice. If you want to be fancy, Molex, 3M or Amp/Tyco FASTON brand fully insulated *nylon jacketed* female 1/4" blade aka "Faston" or "quick connect" connectors. You normally want the standard "non-locking" type, unless you battery terminals have a small hole/depression in them designed to catch the dimple on a locking style connector (most do not). The nylon jacket is more robust then the common PVC style. The really cheap PVC jacketed blade connectors you find in auto parts stores can be pretty bad. Some PVC jackets are so poorly attached they can slide off, move up the wire if damaged slightly when crimping on the connectors. Other sources for all this stuff is DigiKey (www.digikey.com) - search for "quick connects", or Mouser Electronics (www.Mouser.com) although Mouser tend to be more expensive. Buy a bulk bag of them and they'll last forever. Darryl |
On Aug 25, 7:52*am, Darryl Ramm wrote:
On Aug 25, 7:28*am, T8 wrote: On Aug 25, 9:25*am, wrote: On Aug 24, 9:01*pm, Donald S Brant Jr wrote: On Aug 24, 11:14*am, T8 wrote: One other thing... DO include a fuse or circuit breaker at the battery and do make certain that the connections between the CB and the battery are absolutely as reliable as you can make them (as mentioned on another thread, problems here aren't covered by your CB). *I recommend a 5 amp push to reset CB, provided that you have some placeer Moxex-type connectors to mount it correctly, teflon insulated aircraft wire of 18ga and Molex or equivalent industrial quality crimp on connectors which are *far* better than consumer grade stuff at your hardware store. *This is a great area to solicit some help if you aren't completely confident in your ability. That's my public service announcement for the day :-). -T8 For any battery connections I highly recommend Anderson Powerpole connectors:http://www.andersonpower.com/product...onnectors.html. They are hermaphorditic (sexless) and are being used as a defacto standard in the Amateur Radio community for battery connections. *This article:http://www.westmountainradio.com/sup...detailsontheir application. *There was a recent article in one of the ham magazines discussing their advantages over Molex-type connectors. *The use of 30-amp size connectors has been suggested as standard due to their rugged construction and low contact resistance. Don. We also use Powerpoles for the same reason. They will take much more abuse than Molex connectors and have virtually no power loss. Can get them at any hobby shop that handles RC cars. Note these are not hobby products, they are industrial connectors. UH I'll have to check these out. FWIW, my Molex recommendation was intended for the spade lug connectors that attach directly to the battery -- these are bullet proof. *I agree that the Molex disconnects are a little light duty. -T8 And good advice. If you want to be fancy, Molex, 3M or Amp/Tyco FASTON brand fully insulated *nylon jacketed* female 1/4" blade aka "Faston" or "quick connect" connectors. You normally want the standard "non-locking" type, unless you battery terminals have a small hole/depression in them designed to catch the dimple on a locking style *connector (most do not). The nylon jacket is more robust then the common PVC style. The really cheap PVC jacketed blade connectors you find in auto parts stores can be pretty bad. Some PVC jackets are so poorly attached they can slide off, move up the wire if damaged slightly when crimping on the connectors. Other sources for all this stuff is DigiKey (www.digikey.com) - search for "quick connects", or Mouser Electronics (www.Mouser.com) although Mouser tend to be more expensive. Buy a bulk bag of them and they'll last forever. Darryl Darryl , another source of very high quality crimp-on connectors, if you just want to drive to a local store, is electrical supply houses. They stock UL listed (to 600 volts) terminals by companies like Turner & Betts and Panduit. They have to meet a performance spec and they are not cheap, and they are quite good. I share your frustration as everyone in my club has one of those kits they got at Sears or Radio Shack with the bogus tool. The terminals fail over and over so you tend to see that kit come out quite often. Brian |
Still interested in Lithium batteries for your glider? | Eric Greenwell | Soaring | 5 | March 5th 05 02:32 PM |
Battery Chargers | Stan Amyett | Soaring | 2 | March 12th 04 05:27 AM |
Battery Chargers | Mike Rapoport | Owning | 11 | December 2nd 03 11:55 PM |
Rechargable AA batteries and chargers | TripFarmer | General Aviation | 2 | October 17th 03 06:34 PM |
Rechargable batteries and chargers....... | TripFarmer | Products | 2 | October 17th 03 06:31 PM |
