On 10/27/2010 12:29 AM, Darryl Ramm wrote:
On Oct 26, 8:14 pm, Mike wrote: On 10/26/2010 10:22 PM, 5Z wrote: On Oct 26, 10:46 am, wrote: what about GA? What good is Flarm for GA? They are never going to use it in the US. The FAA has another system in store for GA and commercial aircraft. Seems to like cheap insurance for helicopters in metro areas as well as airports with heavy training operations, as well as places such as the Grand Canyon with heavy sightseeing operations. All of these situations could easily get buy-in with a little bit of peer pressure and local politics. Don't get the FAA involved, instead local pilot groups and FBOs / commercial operators could make the case for PowerFlarm as a useful tool for high density VFR operations. As mentioned in other threads, ADS/B and ATC are just not designed for these operations. I recall that after the helicopter midair near Phoenix a few years ago, there was a local news story of someone working on a $50K (fifty thousand) solution to prevent these accidents. Just my $0.02 -Tom What would make you think that ADS-B was not designed for high density VFR operations???? That's exactly what it was designed for, before the FAA focused everyone's attention on using the technology to decrease separations between IFR aircraft. -- Mike Schumann Do you have reference to any ADS-B work on close quarters flying, like links you can give to research, design, testing etc. related to close flying like say where you have helicopters orbiting a crime scene or accident and which vendors make those systems? That scenario may be like thermalling in gliders, if I operated news helicopters or similar I'd be interested in checking a PowerFLARM (since they are such low cost and don't involve any reglatory hassle) and seeing how it worked. I'd also probalby want to look at ADS-B if I could would work out an affordable/approved install to test with. The big work in helicopters with ADS-B was the Gulf of Mexico trial where the core there was really solving in-flight separation and moving out of the "one in the slot" sequencing where they had no radar offshore radar. By all accounts the GOMEX trial was pretty positive. All the helicopter operators in any area would also need to get together and agree on what ADS=B link-layer they will operate on because where/how helicopters fly they are quite likely to be outside GBT coverage and won't have any ADS-R service at times. But hopefully that's a short meeting to get agreement on. There is significant experience gained from GOMEX (Gulf of Mexico) helicopter 1090ES operation. Again thanks to the FAA STC installation are required for each helicopter type and ADS-B data-out equipment. Some of the work was done for the GOMEX trial could probalby be updated to meet a new STC. The issue there likely will be justifying this STC development for some of the lighter helicopters that won't have any work from GOMEX to piggy back on -- and Garmin's GTX-330ES (probably the natural choice for light-medium helicopter avionics given Gamin's push there recently) is not quite ready with DO-260B rev yet so I don't see the FAA allowing a TSO until it is. I'm guessing equipped price per light-medium helicopter for ADS-B data-out and -in and display is likely to start in the $10k range (depends if the helicopter has an existing TSO'ed WAAS GPS or an existing display capability (I suspect a PDA is not going to cut it to a busy helicopter crew)). Its unclear to me if the GPS used is specific in the ADS-B data-out STC, if so that's may be another hurdle. There may be question about display systems suitable for a no-hands helicopter pilot. The obstacle database in Flarm might also be interesting esp. for the very light helicopters vs. existing relatively expensive GA TAWS systems. But there is a question of getting the obstacle database in Flarm format. Darryl There's a difference between flying in high density VFR environments and close quarters flying. Flying in the pattern at a very busy GA airport is not nearly as challenging as flying in a gaggle with numerous other gliders. Neither ADS-B nor FLARM can provide foolproof collision protection between gliders sharing a thermal. Urs, Rob Strain and I had a discussion about this at the SSA convention in Albuquerque a number of years ago. This is a fundamental problem of GPS accuracy limits, coupled with how far a glider can move in an unexpected direction between the 1 sec position updates. That's not to say that FLARM or ADS-B can't be helpful in notifying you of new aircraft (gliders or GA) approaching a gaggle, so you can keep an eye out, or in letting you see how many gliders are in a gaggle and their relative orientation when you are approaching. -- Mike Schumann |
On Wed, 27 Oct 2010 09:06:31 -0400, Mike Schumann
wrote: Neither ADS-B nor FLARM can provide foolproof collision protection between gliders sharing a thermal. .... That's not to say that FLARM or ADS-B can't be helpful in notifying you of new aircraft (gliders or GA) approaching a gaggle, so you can keep an eye out, or in letting you see how many gliders are in a gaggle and their relative orientation when you are approaching. I agree. In facts, I think we don't NEED any "foolproof collision protection". I also believe that we don't need Flarm to be infallible. If it will warn me from relatively distant gliders I have already seen, and which don't seem to be a threat, I'll say "thanks pal, I already knew about him". The accidents that have happened are the proof that, however, we NEED a device to turn our attention on, when it might momentarily, unvoluntarily and unawarely be off. I recall an old, dramatic report which appeared in Soaring magazine. It was written by the survivor of a glider-glider collision. They had been flying together since taking off, so they both were well aware of the traffic. Not a lot of VFR traffic, not a huge gaggle, not a densely participated competition. Just two gliders. Nevertheless, while searching for lift, they collided. Would Flarm have been available at the time, and installed in both gliders, it most probably would have turned into a non-event, less than an incident. We just wouldn't think about it today, and the gliding community would have one more member and less sorrow. I see no reason to wait longer before takeing advantage of this technology. We've been using it for many years now, in Europe. Aldo Cernezzi |
On 10/27/2010 6:06 AM, Mike Schumann wrote:
There's a difference between flying in high density VFR environments and close quarters flying. Flying in the pattern at a very busy GA airport is not nearly as challenging as flying in a gaggle with numerous other gliders. It's hard to put numbers on this, because the particular situation can be important in determining the risk, but I'm comfortable stating this: "That's not true for me, as I am much more accustomed to gaggle flying than flying at or near very busy GA airports, and I'm more comfortable in the gaggle with numerous other gliders." -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
| Thread Tools | |
| Display Modes | |
| Flarm in the US | Steve Freeman | Soaring | 163 | August 15th 10 01:12 AM |
| Reflections on good and evil | [email protected] | Piloting | 6 | April 18th 06 09:48 PM |
| FLARM | Robert Hart | Soaring | 50 | March 17th 06 12:20 AM |
| Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 02:11 AM |
| B29 - "Necessary Evil" | Matt Tauber | Military Aviation | 30 | August 28th 03 11:35 AM |
