Assuming that I have a installed and working FSG 60M tray in my panel,
what Dittel radios, if any, are a slide-in upgrade replacement? Regards, Ken |
Hi Ken,
It is my understanding that no two models of Dittel radios are wired the same. So re-wiring of the DB connector is likely necessary. However, the existing speaker and microphone should work fine with a newer Walter Dittel radio. Best Regards, Paul Remde Cumulus Soaring, Inc. "kenward1000" wrote in message ... Assuming that I have a installed and working FSG 60M tray in my panel, what Dittel radios, if any, are a slide-in upgrade replacement? Regards, Ken |
On Dec 2, 7:38*pm, "Paul Remde" wrote:
Hi Ken, It is my understanding that no two models of Dittel radios are wired the same. *So re-wiring of the DB connector is likely necessary. *However, the existing speaker and microphone should work fine with a newer Walter Dittel radio. Best Regards, Paul Remde Cumulus Soaring, Inc. "kenward1000" wrote in message ... Assuming that I have a installed and working FSG 60M tray in my panel, what Dittel radios, if any, are a slide-in upgrade replacement? Regards, Ken Or while at it just buy the new Becker AR6401 (not sure if they are shipping yet, but if it was me I'd hold out...). Darryl |
Only the FSG40, FSG50 and FSG60 use the same type connector and are tray
mounted radios..all were excellent radios but alas they are getting older and parts may become an issue. You will however use the same component parts and Microphone, Speakers ect are all compatible with newer Walter Dittel radios so you can leave all of your wiring in the glider and just if you like snip it off at the radio trailer and make a short pigtail for whatever new radio you want to install and use a terminal strip or similar connector to attach your existing wiring to the new pigtail. The only issue you might run into if installing a different radio brand like a Microair, Xcom or Flightline radio is that these do not accept the non-amplified Dynamic microphones that you "might" have now....might have because the Walter Dittel radio could be set up to use either amplified or non-amplified microphones, in which case you can still use your existing Microphone but will need an added amplifier, (I also have these) so you can choose almost any replacement radio and make the swap with relative low cost and ease..just add an adapter plate to change the panel from the square opening to small round opening and splice the harness and you're done see my website for all radio and installation options best regards Tim Mara Please visit the Wings & Wheels website at www.wingsandwheels.com "kenward1000" wrote in message ... Assuming that I have a installed and working FSG 60M tray in my panel, what Dittel radios, if any, are a slide-in upgrade replacement? Regards, Ken __________ Information from ESET NOD32 Antivirus, version of virus signature database 5672 (20101203) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com __________ Information from ESET NOD32 Antivirus, version of virus signature database 5672 (20101203) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com |
| Thread Tools | |
| Display Modes | |
| Dittel FSG 50 in Dittel base station | [email protected] | Soaring | 2 | February 18th 09 10:15 AM |
| Dittel FSG 50 in Dittel base station, Perfect for crews and FBO | [email protected] | Soaring | 1 | February 18th 09 10:15 AM |
| Substitute DME for GPS? | Thomas Borchert | Instrument Flight Rules | 24 | September 30th 04 04:54 PM |
| Substitute for MEK? | Rich S. | Home Built | 3 | August 30th 03 09:14 PM |
| GPS SUbstitute for DME or ADF | S. Ramirez | Instrument Flight Rules | 12 | August 20th 03 05:04 PM |
