On Jan 3, 1:44*pm, "vaughn" wrote:
"Brian" wrote in message ... The biggest problem with the sport pilot glider certificate is there is little incentive to get it over a private certifcate. As I recall the training in nearly identical. One just has to take the Knowledge test (I think) and find a DPE to take a practical test, instead of with a CFI. Most soaring sites are already set up for this. This will add a few hundred dollars and some additional study for the knowledge test, but then one does not have the limitations of the Sport pilot certificate. I agree with what you say. *I would try to talk any new student into going for the Private, but that wasn't the original question. *The OP seemed to be asking about a glider add-on to an existing Sport Pilot certificate. *That is actually a pretty simple thing for any glider school to do providing they have a suitable trainer and two CFIG's.willing to sign. Vaughn Except that the Sport certificate is only valid for flying light sport aircraft. I am not aware that any two-seat LSA gliders exist. Mike |
![]() Quote:
Walt |
Mike the Strike wrote:
...... the Sport certificate is only valid for flying light sport aircraft. I am not aware that any two-seat LSA gliders exist. Schweizer 2-33, for one. Tony |
On Jan 5, 1:09*am, Mike the Strike wrote:
Except that the Sport certificate is only valid for flying light sport aircraft. *I am not aware that any two-seat LSA gliders exist. The only thing stopping most of them is a too-high Vne. There are a number of older two seat gliders with Vne until 120 knots: Ka7: 92 ASK13: 108 Janus: 119 It's easy, and I suspect even legal, to simply make up a plate with a lower Vne than the manufacturer originally specified. There are many cases where a glider model's Vne has been reduced due to problems discovered later such as flutter. Can you (or your engineer) reduce a single glider's placarded Vne because of repairs, or simply because you feel that it is "old"? It's no great hardship in most glider flying to lose a few knots off the top speed. I've definitely seen a powered aircraft operated as a LSA by replacing the placard with one specifying a lower MTOW (which was then ignored...). |
On Jan 4, 4:40*pm, Bruce Hoult wrote:
On Jan 5, 1:09*am, Mike the Strike wrote: Except that the Sport certificate is only valid for flying light sport aircraft. *I am not aware that any two-seat LSA gliders exist. The only thing stopping most of them is a too-high Vne. There are a number of older two seat gliders with Vne until 120 knots: Ka7: 92 ASK13: 108 Janus: 119 It's easy, and I suspect even legal, to simply make up a plate with a lower Vne than the manufacturer originally specified. There are many cases where a glider model's Vne has been reduced due to problems discovered later such as flutter. Can you (or your engineer) reduce a single glider's placarded Vne because of repairs, or simply because you feel that it is "old"? It's no great hardship in most glider flying to lose a few knots off the top speed. I've definitely seen a powered aircraft operated as a LSA by replacing the placard with one specifying a lower MTOW (which was then ignored...). You may have seen a powered aircraft operated as you describe, but not legally if type certificated. Limits for determination of LSA eligibility are as originally certified. UH |
On Jan 4, 1:40*pm, Bruce Hoult wrote:
On Jan 5, 1:09*am, Mike the Strike wrote: Except that the Sport certificate is only valid for flying light sport aircraft. *I am not aware that any two-seat LSA gliders exist. The only thing stopping most of them is a too-high Vne. There are a number of older two seat gliders with Vne until 120 knots: Ka7: 92 ASK13: 108 Janus: 119 It's easy, and I suspect even legal, to simply make up a plate with a lower Vne than the manufacturer originally specified. There are many cases where a glider model's Vne has been reduced due to problems discovered later such as flutter. Can you (or your engineer) reduce a single glider's placarded Vne because of repairs, or simply because you feel that it is "old"? It's no great hardship in most glider flying to lose a few knots off the top speed. I've definitely seen a powered aircraft operated as a LSA by replacing the placard with one specifying a lower MTOW (which was then ignored...). No.. you cannot change the MTOW or Vne of an aircraft, airplane or glider from what it was originally certified at just to make it qualify for LSA. If you have seen this in powered aircraft, do you have an example you would like to cite? In any case, it is not legal, and if the pilot did so to be able to fly under LSA rules sans medical, he may have just invalidated his insurance, his airworthy certificate and would be subject to penalties and possible loss of certificates from the FAA. Reducing an "experimental" aircraft due to "re-enginnering" would subject the aircraft to a new airworthy certification and review and a new round of flying off phase 1 and phase 2 requirements. And if it is an imported aircraft.. even more headaches are possible. T |
On Jan 4, 11:46*pm, T wrote:
On Jan 4, 1:40*pm, Bruce Hoult wrote: On Jan 5, 1:09*am, Mike the Strike wrote: Except that the Sport certificate is only valid for flying light sport aircraft. *I am not aware that any two-seat LSA gliders exist. The only thing stopping most of them is a too-high Vne. There are a number of older two seat gliders with Vne until 120 knots: Ka7: 92 ASK13: 108 Janus: 119 It's easy, and I suspect even legal, to simply make up a plate with a lower Vne than the manufacturer originally specified. There are many cases where a glider model's Vne has been reduced due to problems discovered later such as flutter. Can you (or your engineer) reduce a single glider's placarded Vne because of repairs, or simply because you feel that it is "old"? It's no great hardship in most glider flying to lose a few knots off the top speed. I've definitely seen a powered aircraft operated as a LSA by replacing the placard with one specifying a lower MTOW (which was then ignored...). No.. you cannot change the MTOW or Vne of an aircraft, airplane or glider from what it was originally certified at just to make it qualify for LSA. If you have seen this in powered aircraft, do you have an example you would like to cite? In any case, it is not legal, and if the pilot did so to be able to fly under LSA rules sans medical, he may have just invalidated his insurance, his airworthy certificate and would be subject to penalties and possible loss of certificates from the FAA. Reducing an "experimental" aircraft due to "re-enginnering" would subject the aircraft to a new airworthy certification and review and a new round of flying off phase 1 and phase 2 requirements. And if it is an imported aircraft.. even more headaches are possible. T I still maintain my original assertion that no gliders have been certified by FAA as LSA. Certainly a number could meet the limitations, but decertification would be non-trivial. If I am wrong, please cite specific aircraft. Mike |
At 05:39 05 January 2011, Mike the Strike wrote:
I still maintain my original assertion that no gliders have been certified by FAA as LSA. Certainly a number could meet the limitations, but decertification would be non-trivial. If I am wrong, please cite specific aircraft. Given that the FAA has a long list of type certified light aircraft that can be flown as LSAs (various Aeroncas, Luscombes, Ercoupes, Pipers, Taylorcrafts) one wonders why the compliant certified gliders (2-22, 2-33, Ka7) weren't also added to this list. And, the possibility was well known early on in the rule-making process, I know as I asked about it years ago during an FAA session years ago at an SSA convention. What happened, and can it be fixed? Seems like a no-brainer to me... Marc |
![]() "Marc Ramsey" wrote in message ... At 05:39 05 January 2011, Mike the Strike wrote: I still maintain my original assertion that no gliders have been certified by FAA as LSA. Certainly a number could meet the limitations, but decertification would be non-trivial. If I am wrong, please cite specific aircraft. Given that the FAA has a long list of type certified light aircraft that can be flown as LSAs (various Aeroncas, Luscombes, Ercoupes, Pipers, Taylorcrafts) Any list you may have found is for information only and not part of any regulation. The answer is in front of you, in FAR Part 1.1 "Light-Sport aircraft means an aircraft, other than a helicopter or powered lift that, since its original certification, has continued to meet the following" ; (the LSA limitations follow, including 120 knots Vne for gliders) This means that any certified aircraft can be flown by a sport pilot as long at it meets the LSA limitations and has ALWAYS met those regulations. Vaughn " |
In article Mike the Strike writes:
I still maintain my original assertion that no gliders have been certified by FAA as LSA. Certainly a number could meet the limitations, but decertification would be non-trivial. If I am wrong, please cite specific aircraft. Mike http://www.sportpilot.org/learn/slsa/ lists two gliders (actually one is a motorglider) that they claim are S-LSA. One is the Lambada and the other is the TST-14 (available as self launch or unpowered). Following the links from there, one finds a note that N107SM was registered in 2007 as a LSA glider. Alan |
Adding an airplane rating to private pilot glider | gmcd05 | Soaring | 35 | April 25th 08 01:43 AM |
Foreign Pilot Getting US Glider Rating | Papa3 | Soaring | 10 | April 16th 07 02:27 PM |
Sport Pilot and Glider Questions | Ralph Steiner | Soaring | 17 | February 22nd 06 11:34 AM |
endorsements for private pilot glider rating | Joel Taylor | Soaring | 2 | October 2nd 03 06:44 AM |
Private Pilot Glider Rating Requirements | John | Soaring | 8 | August 21st 03 01:09 AM |
