Swing Wings: Yea or Neah?
Old February 11th 04, 04:29 PM
Jeff Crowell
Nele VII wrote:
Fast AND agile. Syrian 23M and ML models were better to fo fight or chase
with F-16 at the deck. Medium sweep gave good 16 degrees/sec sustained (ML
excellent 18 degrees, MLD has a lower medium sweep and can go to 19 with
less buffeting) turn rate with missiles onboard- remember R-23/24 are HUGE
missiles, and R-60 M(?) are carried in quartet on ML! If it turned against
them, they would sweep back the wings, increase wing loading and went to a
low-level smooth high-speed ride, while Israeli pilots (F-16A, F-15A) were
banging their helmets on canopies due to gusts of Golan. MiG-23 has no
ailerons, it uses wing spoilers and stabilators for roll that is quite
snappy-just like one of Tornado.
There were drawbacks to the Flogger, though. Or at least so we
were briefed. I personally never turned 'n burned against one, but
the guys who did said it was so. The wing sweep mechanism on
the MiG-23 was limited to only 2.5G, at which piit it locked up.
If you put the press on a Flogger, you could drive him out of his
optimum wing angle very quickly. If he was never able to unload
to 2.5G or less, he could not change his wing angle and you had
your kill.
Also, you mention HUGE missiles... let's just imagine the bleed
rate if you start an angles fight carrying all that drag.
Due credit to Ed, a lot of guys would not bother to slow down for
the angles fight anyway.
Jeff
Old February 14th 04, 11:28 AM
Nele VII
Jeff Crowell wrote in message ...
(ML
HUGE
against
a
were
your kill.
Jeff
Hm. I am not a pilot, but I know this-there's no aircraft without the
drawback. You can't roll F-15 a couple 360'es w/out some loading, or one
will be "punished" with inertia-roll coupling (interestingly, MiG-21 shares
the same "drawback", but not to the same amount). You MUST NOT roll an F-4
with it (more or less). You can't slow down the f-111 with full wing sweep
without loosing it... shall I go on? It is all up to the driver. If You have
a fruitcake in the cockpit, it does not matter what he/she flies!
Honestly, I thought that there's much lower g limit on '23 sweep change; I
also don't know how fast it can change the wingsweep (MLD migh be better
than M/MF/ML?).
My bottom line is that MiG-23 is not a bad airplane, but was prone to be
piloted by bad pilots...
Nele
NULLA ROSA SINE SPINA
Discovery Wings Channel ??? RobertR237 Home Built 1 November 8th 04 09:40 PM
VP-II wings available in Oregon, USA (Or, "How I was coconuted...") Roberto Waltman Home Built 2 October 29th 04 05:21 PM
Double covering fabric covered wings [email protected] Home Built 9 May 9th 04 09:39 PM
Pitt wings Al MacDonald Aerobatics 2 November 4th 03 07:40 AM
Crooked or Wavy Trailing Edges of Wings and Control Surfaces Larry Smith Home Built 3 October 24th 03 03:31 AM
