On Thu, 12 Feb 2004 16:03:28 GMT, "Mark" wrote:
"David E. Powell" wrote in message ws.com... OK. I have seen the debate over GWB as an F-102 pilot, so I was wondering about a couple of things. First, was the F-102 taken out of service in the early 1970s? I have to ask because as a kid I remember the Guard around here flying F-106s up to around 1990 or 1991 or so, and they were closely related to the F-102. Though I recall them being (much) faster. Mach 1.8 vs. Mach 2.32 IIRC. HANG (Hawaii) flew 102 until 1977 (last unit as best I can find out). Now the be TOTALLY correct Deuce was flown much longer than that as drone. The Six was faster due to the fact that F-106 had engine with more thrust (J75 vice J57). Not sure, but don't think Deuce had variable inlet either (open to correction) The six also had an area-ruled fuse, that is significant for a +mach bird. Al MInyard |
![]() "Alan Minyard" wrote in message ... On Thu, 12 Feb 2004 16:03:28 GMT, "Mark" wrote: "David E. Powell" wrote in message ws.com... OK. I have seen the debate over GWB as an F-102 pilot, so I was wondering about a couple of things. First, was the F-102 taken out of service in the early 1970s? I have to ask because as a kid I remember the Guard around here flying F-106s up to around 1990 or 1991 or so, and they were closely related to the F-102. Though I recall them being (much) faster. Mach 1.8 vs. Mach 2.32 IIRC. HANG (Hawaii) flew 102 until 1977 (last unit as best I can find out). Now the be TOTALLY correct Deuce was flown much longer than that as drone. The Six was faster due to the fact that F-106 had engine with more thrust (J75 vice J57). Not sure, but don't think Deuce had variable inlet either (open to correction) The six also had an area-ruled fuse, that is significant for a +mach bird. Actually, Al, the 102 used area rule--the lack of area rule resulted in the first protype YF-102 being firmly subsonic. Redesign to incorporate area rule yielded the F-102A, which was our first supersonic interceptor. Brooks Al MInyard |
On Fri, 13 Feb 2004 14:05:42 -0500, "Kevin Brooks" wrote:
"Alan Minyard" wrote in message .. . On Thu, 12 Feb 2004 16:03:28 GMT, "Mark" wrote: "David E. Powell" wrote in message ws.com... OK. I have seen the debate over GWB as an F-102 pilot, so I was wondering about a couple of things. First, was the F-102 taken out of service in the early 1970s? I have to ask because as a kid I remember the Guard around here flying F-106s up to around 1990 or 1991 or so, and they were closely related to the F-102. Though I recall them being (much) faster. Mach 1.8 vs. Mach 2.32 IIRC. HANG (Hawaii) flew 102 until 1977 (last unit as best I can find out). Now the be TOTALLY correct Deuce was flown much longer than that as drone. The Six was faster due to the fact that F-106 had engine with more thrust (J75 vice J57). Not sure, but don't think Deuce had variable inlet either (open to correction) The six also had an area-ruled fuse, that is significant for a +mach bird. Actually, Al, the 102 used area rule--the lack of area rule resulted in the first protype YF-102 being firmly subsonic. Redesign to incorporate area rule yielded the F-102A, which was our first supersonic interceptor. Brooks Al MInyard OOOOPS, thanks for the correction, I was probably thinking of pictures of the prototypes. A;l Minyard |
![]() "Alan Minyard" wrote in message ... The six also had an area-ruled fuse, that is significant for a +mach bird. So did the deuce. |
![]() "Alan Minyard" wrote in message ... The six also had an area-ruled fuse, that is significant for a +mach bird. Al MInyard As did the F-102. See Joe Baugher article at http://home.att.net/~jbaugher1/f102_1.html part of which I quote below. The XF-92A is the aircraft which did not have "area rule". Tex The F-102 project was in serious trouble, and if a fix for the performance problems could not be found, the entire project was in danger of cancellation. While eight more YF-102s (Model 8-82, serials 53-1779/1786) were being built to the same standards as the first two aircraft, Convair embarked on a major investigation and redesign program in an attempt to save the F-102. The salvation of the project turned out to be in the "area rule" devised by NACA scientist Richard Whitcomb. According to the area rule, the total cross sectional area along the direction of flight should be a constant in order to achieve minimum transonic drag. In order to achieve this, it was required that the fuselage be narrowed down in the region where the wing roots were attached, then broadened back out again when the wing trailing edge was reached. This gave the aircraft fuselage a characteristic "wasp-waist" or "Coke-bottle" shape. In order to achieve this, the length of the fuselage was increased by 11 feet, and a pair of aerodynamic tail fairings were added aft of the trailing edge, these fairings extending beyond the end of the afterburner tailpipe in a pair of characteristic protrusions. These tail fairings were for purely aerodynamic purposes and had no other function. A new cockpit canopy with a sharper leading edge was fitted, although it had an adverse effect on overall visibility. Cambered leading edges were fitted to the thin delta wings to improve the behavior of the thin airfoil at high angles of attack, and the wingtips were given wash-in. |
On Fri, 13 Feb 2004 12:41:07 -0700, "Tex Houston" wrote:
"Alan Minyard" wrote in message .. . The six also had an area-ruled fuse, that is significant for a +mach bird. Al MInyard As did the F-102. See Joe Baugher article at http://home.att.net/~jbaugher1/f102_1.html part of which I quote below. The XF-92A is the aircraft which did not have "area rule". Tex The F-102 project was in serious trouble, and if a fix for the performance problems could not be found, the entire project was in danger of cancellation. While eight more YF-102s (Model 8-82, serials 53-1779/1786) were being built to the same standards as the first two aircraft, Convair embarked on a major investigation and redesign program in an attempt to save the F-102. The salvation of the project turned out to be in the "area rule" devised by NACA scientist Richard Whitcomb. According to the area rule, the total cross sectional area along the direction of flight should be a constant in order to achieve minimum transonic drag. In order to achieve this, it was required that the fuselage be narrowed down in the region where the wing roots were attached, then broadened back out again when the wing trailing edge was reached. This gave the aircraft fuselage a characteristic "wasp-waist" or "Coke-bottle" shape. In order to achieve this, the length of the fuselage was increased by 11 feet, and a pair of aerodynamic tail fairings were added aft of the trailing edge, these fairings extending beyond the end of the afterburner tailpipe in a pair of characteristic protrusions. These tail fairings were for purely aerodynamic purposes and had no other function. A new cockpit canopy with a sharper leading edge was fitted, although it had an adverse effect on overall visibility. Cambered leading edges were fitted to the thin delta wings to improve the behavior of the thin airfoil at high angles of attack, and the wingtips were given wash-in. Thank you very much, Tex. Al Minyard |
![]() "Alan Minyard" wrote in message ... The six also had an area-ruled fuse, that is significant for a +mach bird. As did the Deuce. |
Juan Jiminez is a liar and a fraud (was: Zoom fables on ANN | ChuckSlusarczyk | Home Built | 105 | October 8th 04 12:38 AM |
Bush's guard record | JDKAHN | Home Built | 13 | October 3rd 04 09:38 PM |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 04:24 AM |
D.C. Air Guard Unit Flies New 737s | Otis Willie | Military Aviation | 0 | January 14th 04 11:12 PM |
