Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
polar diagram in high altitude
Old February 11th 11, 11:50 PM posted to rec.aviation.misc
John Szalay[_2_]
Default polar diagram in high altitude
"dominik lenné" wrote in
Hi,
I wonder whether the lift over resistance coefficient diagram (aka
polar diagram or lilienthal diagram) of a given airplane changes much
with altitude.
The rationale behind the question is, that I read somewhere, that
commercial aircraft are flying in the so called "coffin corner", that
is so high they can't go faster because of compression and can't go
slower because of stall.
Why should they do this, when they could well be a little lower and
comfortly fly at the point of optimal angle of access, well away from
stall.
Do optimal point and stall point come closer together with increasing
height?
Are you sure you are refering to commercial aircraft ?
sure sounds as if you thinking of the U-2 with its VERY narrow
flight envelope at close to max.
Old February 13th 11, 06:33 PM posted to rec.aviation.misc
Stubby[_3_]
On Feb 11, 5:50*pm, John Szalay john.szalayATatt.net wrote:
"dominik lenné" wrote :
Hi,
with altitude.
stall.
height?
*Are you sure you are refering to commercial aircraft ?
flight envelope at close to max.- Hide quoted text -
- Show quoted text -
Glider pilots talk alot about polar curves. The peak is the best L/
D point. Lift is proportional to mass flow over the wings so thin
air (up high) and slow speed reduce lift. Drag decreases with thin
air, partially compensating. I'm not aware that any commerical flight
would be allowed to operate at a level where this makes a
difference. Plus, Class-A air space does not extend above FL600.
Old February 22nd 11, 04:31 AM
skesouptfup skesouptfup is offline
Banned
First recorded activity by AviationBanter: Feb 2011
Send a message via ICQ to skesouptfup
High on Final, Summary; was Polar with spoilers extended? Steve Leonard Soaring 4 October 27th 07 08:22 AM
Discus polar curve at high speeds [email protected] Soaring 12 December 20th 05 02:59 AM
High altitude & RPM abripl Home Built 1 September 1st 05 01:12 AM
Polar diagram for Mosquito? Dave Boulter Soaring 9 February 2nd 05 08:07 PM
High-altitude autorotations? Bill McClain Military Aviation 17 March 15th 04 05:23 PM
