Question about the F-22 and cost.
Old February 13th 04, 09:19 PM
phil hunt
On Fri, 13 Feb 2004 09:55:27 -0500, Kevin Brooks wrote:
Not necessarily. The number that has been bandied about (180) would allow
around six squadrons to be fielded, along with with attrition, training, and
test aircraft. That would, given the likely air-to-air threats we can
currently envision, be sufficient to ensure our ability to apply airpower in
any likely required scenarios, withthe F-35 bulking up the force. We have
managed to do quite well with only one wing of F-117's for a number of years
now.
I have difficulty imagining a threat that could not be dealt with by
several thousand F-35s (plus no doubt large numbers of legacy
F/A-18s, F-16s, etc), but which could be dealt with by an extra 180
F-22s.
"It's easier to find people online who openly support the KKK than
people who openly support the RIAA" -- comment on Wikipedia
(Email: zen19725 at zen dot co dot uk)
Old February 13th 04, 09:58 PM
Kevin Brooks
"phil hunt" wrote in message
and
in
years
now.
F-22s.
Firstly, I think you are exaggerating the F-35 situation a bit--the total US
buy is a bit over two thousand over the lifetime of the rpogram, IIRC (the
Navy has already reduced the number of aircraft to be procured). Secondly,
the F-22 in those numbers mentioned can indeed still serve a vital role,
namely as a "silver bullet" asset in case we run into an opponent who *can*,
however unlikey that may be right now, field a truly advanced fighter that
could challenge the capabilities of the legacy aircraft. Dumping the F-22
entirely at this point would seem to be a big waste with no capability to
dominate any foe that might be able to realistically challenge us in the
foreseeable future; OTOH, building the currently desired USAF quantity
(around 400 plus, IIRC, with the funding currently capped for 339), when the
USAF has other requirements that appear to be even more vital in the
environment we now face, and that which we are likely to face during the
coming years, seems to me to be a bit of overkill.
Brooks
Old February 14th 04, 11:01 PM
John Cook
On Fri, 13 Feb 2004 15:58:48 -0500, "Kevin Brooks"
and
in
years
now.
How many aircraft do you have now (F15/F16) Your present rate of
replacement will not be 1 to 1 at the price thats being quoted..
The idea was that the f-22 was the silver bullet force that would
make up for t he JSF's shortcomings.
The JSF was to have used off board sensors to fulfill its missions.
But the cuts to the F-22 buy and pressure from the non US partner in
the JSF mean its capability has grown to start encroaching on the
F-22.
This is where the US has to be very careful, If the JSF get to
look too good then the F-22 dies a death.
If the JSF isn't made to be a pretty good autonomous fighter (read
as 'the JSF must have a sensor suite that's as good as the present
F15's') then the Partner nations won't be very happy (Note how the
Netherlands are keeping in with the Typhoon program), and may shop
elsewhere.
The nasty part of this is then the price of the JSF skyrockets!!
(it started out at around $25M USD), you'll find it will be well over
double that now, and possible treble come production time.
Which means the USA will not have an 'F16' replacement ie a Light
Weight Fighter in the $30-40M USD bracket.
So what's it to be??? cut the number of wings, cut the number of
aircraft in a wing, to make it look like there are no cuts while
cutting the number of aircraft to be purchased or the very slight
chance of doubling/trebling the amount spent of fighter
procurement in the next decade or two.
Some thing has to give - I still think the F-22 is vulnerable.
I just cannot imaging the present fiscal bloat continuing.
Cheers
F-22s.
Brooks
Old February 15th 04, 01:58 AM
Kevin Brooks
"John Cook" wrote in message
allow
training,
and
airpower
in
have
years
now.
It does not have to be. The F-22 is lauded as being so much more effective
than both its contemporaries and forseeable opponents, a one-for-one
replacement is not required. Same goes for the F-35 versus F-16. And recall
that in the case of the latter, the later block F-16's will be serving long
after the F-35 enters into service.
Actually, I think you have that sort of backwards. The ATF program was well
underway before the JSF program even coalesced into its current form. The
JSF enables the F-22 to be bought in lower numbers than would be the case
without the JSF. Under the evolving views, your statement becomes more true
today--the F-22 can be a silver bullet that can enhance the abilities of the
F-35 (and other aircraft) to do their missions. The old days' philosophy of
"not a pound for air-to-ground" just does not really cut it in the modern
threat environment; hence the belated "F/A-22" wordsmithing to try and
portray it as *really* being a platform that was equally intended to serve
in the strike role.
Programs evolve and change--that has always been the case with major weapons
sytems like these.
F-22.
elsewhere.
I mmay have misunderstood your earlier comments. I believe the F-22 buy will
in all likelihood never exceed the 180-200 aircraft figure. The F-35 will
indeed have more capabilities than may have originally been envisioned for
it. Improved PGM's, improved C4ISR, advances in UAV (to the point of
UCAV)...all of these point eventually to a smaller force structure
footprint, IMO. The F-22 will be a silver bullet asset, while the F-35 will
be capable of dealing with all but the most advanced opposition systems.
Actually, I think the case for the F-22 would have been much stronger had
the USAF committed early to developing a somewhat modified strike version
(not necessarily having to go as far as the FB-22 proposal put forth by
LMCO) to eventually replace the F-15E.
Brooks
Cheers
F-22s.
US
(the
Secondly,
*can*,
that
Brooks
Old February 15th 04, 10:46 PM
phil hunt
in the strike role.
Indeed.
The F-22 is suffering from the same root cause that's affected the
Typhoon program -- the enemy against which it was envisaged, the
USSR, no longer exists.
That seems probable.
The F-35 will
UCAV)...
And that.
Old February 15th 04, 10:17 PM
phil hunt
F15's')
I've not heard that before. Is it likely the F-35 sensors will be
that cut-down?
elsewhere.
I expect in that instance Britain would consider having its F-35s
contain the same sensor set as the Typhoon.
All military aircraft increase in price over time. In part this is a
deliberate ploy by defence contractors, some of whom have admitted
as much.
Old February 16th 04, 01:32 AM
Tarver Engineering
F15's')
that cut-down?
The F-35 was late enough to get some COTS relief, so it is likely to have
superior sensors and integration when compared to the F-22. Letting
engineers buy parts saves a lot of heartache, if the program follows a few
simple rules.
Old February 16th 04, 07:05 PM
Tarver Engineering
"Harry Andreas" wrote in message
I've never heard such a confession and I've been in the industry for
25+ years. Can you provide a source please?
IME the cost growth over time have been the result of a steady
increase in performance at the request of the customer.
The schedule slippage is the cause of the steadily decreasing number of
F-22s for delivery. The schedule slip is a direct rsult of performance
issues.
Old February 16th 04, 11:24 PM
phil hunt
You may be surprised at the capabilities of the so-called "cut down"
sensor system. Typhoon currently has a mechanically scanned
radar.
Yes, I know, I was considering the phased one to replace it.
as much.
Sure.
http://news.scotsman.com/latest.cfm?id=2442322
Sir Raymond Lygo is a former boss of British Aerospace, so I
imagine he knows what he's talking about.
Yes, that's part of the ploy. to quote the article:
---------------------- begin ----------------------
I think it's a well-known fact, whether anybody admits it or not, is
you'll never get any programme through the Government if you ever
revealed the real cost.
Whatever you want to get through Government, you have to first of
all establish what is the Treasury likely to approve in terms of
money? And then you think, what can you offer for these terms within
the parameters that have been set? And pretty often it is pretty
nearly impossible.
So you say right, we can do this and we'll do it for the price and
then the programme goes ahead. But you know automatically that it's
going to cost more than that because it will.
And so after a year you say 'I'm terribly sorry but the costs have
now risen for this reason and the other reason'.
----------------------- end -----------------------
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 04:13 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 1st 04 03:31 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 September 2nd 04 06:15 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
