At 16:51 25 March 2011, soartech wrote:
I almost snickered a bit after watching this "real life" story about how a pilot had to land his plane after loosing engine power at 500 feet. After 35 years of flying gliders this looks normal to me. Maybe power planes are really hard to fly. This guy has 4700 hours and he overshot his turn onto the runway and lands way left of the center line. I think the solution is that every new power pilot should be required to have 20 flights in gliders before even stepping into a plane with an engine. http://flash.aopa.org/asf/pilotstori...turn/index.cfm As A Commercial Glider Pilot who happens to fly alot of Cessna single engine stuff the above comment that Mr. Soartech was snickering at one of our fellow airmans ,less than stellar performance, in a aircraft Completely different than a glider , in what is a hair raising, scary, potentially fatal situation,is sad to me. A 500' engine out is a serious thing. In a glider at 500' you can glide a couple of miles, easy. At something like a 120 ft/ min sink rate. I would like to load Mr. Soartech in a C172 full of fuel, and at max climb attitude,full power, turn off the mags and see how he does. First of all, if you ball it, up the odds are you are going to turn into a fireball. Second, by the time you react, with a surprising very large attitude nose down shove required on the yoke, which you NEVER do in normal flight ops, the airspeed is going to be low and the ground coming up very fast, oh yea and you might have some people in there with you, like your kids. Its not quite like your at 500' at 65 knots in your LS 4 let me tell you. So lets not be to harsh on our fellow aviators, after all the history books are full of World Class level Multi Nationals winners/instructors in gliders that have killed themselves and we continue to do so at a very steady and consistent pace. We land short, we forget to lower the gear, we forget to connect the controls, we forget to turn on the 02, were on the wrong frequency, We hit our friends in thermals we land in the trees! the list goes on. Lets be careful out there this season and watch out for each other. |
Yes, a 500 ft engine out on takeoff in a light plane is more like a
125 ft rope break. Now do a 180 turn around to land. Try to simulate this emergency some time if you have power license or a friend to fly with. Just be prepared to see how fast the ground comes up. |
![]() Quote:
Walt |
On Mar 25, 1:48*pm, toad wrote:
Yes, a 500 ft engine out on takeoff in a light plane is more like a 125 ft rope break. *Now do a 180 turn around to land. Try to simulate this emergency some time if you have power license or a friend to fly with. *Just be prepared to see how fast the ground comes up. I have maintained for a long time that power pilot training for engine failure had the priorities wrong. Power pilots are taught to set best glide speed first. All this does is waste time and altitude going away from the landing place if a turn back is the only option. One year, when I was active as an airplane CFI, I trained 3 different pilots in engine out turn back. All were able to turn back, and be in position to land, when power loss was simulated 400ft above the runway at Vy. The aircraft used were a PA28-180 and a Grumman AA5A. The better pilots did it so well they had loads of altitude to burn after getting lined up to land. With the right technique 400agl power loss in these aircraft was similar to 200ft rope break in a glider. The right technique of course was to do just what we teach in gliders. Immediate 45 deg banked turn, into the wind if any. Speed in the turn not best glide speed but the minimum speed that gives a safe stall margin. In most airplanes that is much slower than best glide speed. The initial training was performed about 1500 agl using a road as a simulated runway. Only when the technique was mastered was an actual low altitude turn back performed. Andy |
On 3/26/2011 10:41 AM, Andy wrote:
On Mar 25, 1:48 pm, wrote: Yes, a 500 ft engine out on takeoff in a light plane is more like a 125 ft rope break. Now do a 180 turn around to land. Try to simulate this emergency some time if you have power license or a friend to fly with. Just be prepared to see how fast the ground comes up. I have maintained for a long time that power pilot training for engine failure had the priorities wrong. Power pilots are taught to set best glide speed first. All this does is waste time and altitude going away from the landing place if a turn back is the only option. One year, when I was active as an airplane CFI, I trained 3 different pilots in engine out turn back. All were able to turn back, and be in position to land, when power loss was simulated 400ft above the runway at Vy. The aircraft used were a PA28-180 and a Grumman AA5A. The better pilots did it so well they had loads of altitude to burn after getting lined up to land. With the right technique 400agl power loss in these aircraft was similar to 200ft rope break in a glider. The right technique of course was to do just what we teach in gliders. Immediate 45 deg banked turn, into the wind if any. Speed in the turn not best glide speed but the minimum speed that gives a safe stall margin. In most airplanes that is much slower than best glide speed. The initial training was performed about 1500 agl using a road as a simulated runway. Only when the technique was mastered was an actual low altitude turn back performed. Andy Andy's hands-on experience supports a (several, actually) thought(s) the skeptical engineer in me has mulled ever since gaining sufficient experience and knowledge to be able to. Teaching (of anything) is an inexact process, while teaching of a demonstrable physical skill (e.g. piloting) requires - for all practical purposes - creation of defined methodologies, the goal generally being infusing the student with sufficient knowledge and abilities to continue 'self-training' throughout the rest of their applied learning activities. So far so good... However, when it comes to teaching of certain 'immediately' life-threatening emergency aviation-related procedures (rope breaks, engine loss, etc.), where one 'sets the bar' for 'acceptably safe' is arguably statistically important to future accident rates. My growing suspicion has been the bar for light, single-piston-engined GA may well be set 'too high (above the ground, I mean)' when it comes to defining safe turn-around altitude(s) above ground. Sort of the equivalent of adults setting/permitting expectations of kids in school 'too low.' Or, maybe focusing on the wrong thing (a magic height, say) rather than some more fundamentally important metric (e.g. what it takes as a pilot to effect a safe, minimal-altitude-loss 'teardrop reversal'). While fully recognizing the aero-perfomance differences between (say) any Bonanza and a Taylorcraft BC-12, how much sense does it make to set the 'safe-180-height' for both the same? More to the point - since review of NTSB accident data yields a drearily consistent litany of unfortunately-terminated engine-loss incidents - maybe it would make more training sense to 'set the bar' as an airframe-dependent, outcome-based, training exercise designed more to inculcate in student-pilots (not to mention instructors, and eventually to the entire pilot base) the concept of obtaining maximum-performance, minimum-altitude-loss turnarounds, as distinct from some 'magical universal turnaround height'. That latter may well be a poor choice of teaching metric simply because the training often (in my observation) tends to morph into 'rote memorization of some universal safety height', when almost certainly universality of numbers is *way* too crude a metric. In any event, my (non-CFIG-based) personal bias has long been to try to highlight fundamental underlying concepts to any 'teachable moment', whether aviation-related or not. Works for me! Meanwhile, mental review of one's own ideas and applicable skill-sets is probably never a waste of time. What Tom Knauff too-gently euphemizes as 'The Silly Season' is well underway in the U.S. as spring advances here, and the honest among sailplane pilots will place the underlying responsibility for the vast majority of sailplane accidents and incidents squarely where it belongs, on Joe PIC. Let's have fun, but wisely, thoughtfully and (presumably, more) safely! Bob - none of my gliders ever bent themselves - W. |
![]() "Andy" wrote in message ... wrote: .. I have maintained for a long time that power pilot training for engine failure had the priorities wrong. Power pilots are taught to set best glide speed first. All this does is waste time and altitude going away from the landing place if a turn back is the only option. .When teaching this stuff, remember to mention that turn radius increases with the square of airspeed! An amazing number of power pilots (and even some glider pilots) don't know that. Both the bank angle and the airspeed of that turn are vitally important. Vaughn |
On Mar 26, 12:13*pm, "vaughn" wrote:
"Andy" wrote in ... wrote: . I have maintained for a long time that power pilot training for engine failure had the priorities wrong. *Power pilots are taught to set best glide speed first. All this does is waste time and altitude going away from the landing place if a turn back is the only option. *.When teaching this stuff, remember to mention that turn radius increases with the square of airspeed! *An amazing number of power pilots (and even some glider pilots) don't know that. *Both the bank angle and the airspeed of that turn are vitally important. Vaughn That's why I said speed only that required for a safe margin above stall. |
On Mar 26, 1:13*pm, "vaughn" wrote:
"Andy" wrote in ... wrote: . I have maintained for a long time that power pilot training for engine failure had the priorities wrong. *Power pilots are taught to set best glide speed first. All this does is waste time and altitude going away from the landing place if a turn back is the only option. *.When teaching this stuff, remember to mention that turn radius increases with the square of airspeed! *An amazing number of power pilots (and even some glider pilots) don't know that. *Both the bank angle and the airspeed of that turn are vitally important. Vaughn Nobody has seen fit to bring in runway heading versus runway track while on initial tow in a significant crosswind. In our neck of the woods this happens. Is a significant factor in least time/space to get back to a downwind landing. |
Oh, I thought someone mentioned it in passing. Always turn into wind.
At 21:42 26 March 2011, n7ly wrote: On Mar 26, 1:13=A0pm, "vaughn" wrote: "Andy" wrote in messagenews:45b8c464-c350-4983-be8= ... wrote: . I have maintained for a long time that power pilot training for engine failure had the priorities wrong. =A0Power pilots are taught to set best glide speed first. All this does is waste time and altitude going away from the landing place if a turn back is the only option. =A0.When teaching this stuff, remember to mention that turn radius increa= ses with the square of airspeed! =A0An amazing number of power pilots (and even so= me glider pilots) don't know that. =A0Both the bank angle and the airspeed of that = turn are vitally important. Vaughn Nobody has seen fit to bring in runway heading versus runway track while on initial tow in a significant crosswind. In our neck of the woods this happens. Is a significant factor in least time/space to get back to a downwind landing. |
On Mar 26, 8:30*pm, Nyal Williams wrote:
Oh, I thought someone mentioned it in passing. *Always turn into wind. At 21:42 26 March 2011, n7ly wrote: On Mar 26, 1:13=A0pm, "vaughn" *wrote: "Andy" *wrote in messagenews:45b8c464-c350-4983-be8= ... wrote: . I have maintained for a long time that power pilot training for engine failure had the priorities wrong. =A0Power pilots are taught to set best glide speed first. All this does is waste time and altitude going away from the landing place if a turn back is the only option. =A0.When teaching this stuff, remember to mention that turn radius increa= ses with the square of airspeed! =A0An amazing number of power pilots (and even so= me glider pilots) don't know that. =A0Both the bank angle and the airspeed of that = turn are vitally important. Vaughn Nobody has seen fit to bring in runway heading versus runway track while on initial tow in a significant crosswind. In our neck of the woods this happens. Is a significant factor in least time/space to get back to a downwind landing. Let me restate this a bit for those who don't often have 15 knot crosswind components. Should the towplane maintain runway heading after liftoff and after establishing a normal climb, allowing the tow plane to drift while maintaining runway heading? Or should the towplane maintain runway track after liftoff and after establishing a normal climb, keeping the tow plane on what would be runway centerline? It makes a significant difference in how many degrees of turn necessary as you turn into the wind and get lined up for a downwind landing. |
Emergency Landing-Engine DEAD | Ol Shy & Bashful | Piloting | 39 | June 23rd 08 10:12 AM |
F-16 landing no engine | doylflier | Piloting | 2 | December 14th 06 07:20 AM |
NC Engine Out Landing? | John A. Weeks III | General Aviation | 7 | September 7th 04 06:28 PM |
Prop Feathers and Engine Shuts down after landing???????? | AIR ADVENTURE82 | Owning | 16 | August 29th 03 09:36 PM |
Prop Feathers and Engine Shuts down after landing???????? | AIR ADVENTURE82 | Piloting | 3 | August 21st 03 05:42 AM |
