Engine Out Landing. Big Deal?
Old March 27th 11, 03:22 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default Engine Out Landing. Big Deal?
On 3/27/2011 6:47 AM, n7ly wrote:
Nobody has seen fit to bring in runway heading versus runway track
while on initial tow in a significant crosswind. In our neck of the
woods this happens. Is a significant factor in least time/space to get
back to a downwind landing.
Let me restate this a bit for those who don't often have 15 knot
crosswind components.
Should the towplane maintain runway heading after liftoff and after
establishing a normal climb, allowing the tow plane to drift while
maintaining runway heading?
Or should the towplane maintain runway track after liftoff and after
establishing a normal climb, keeping the tow plane on what would be
runway centerline?
It makes a significant difference in how many degrees of turn
necessary as you turn into the wind and get lined up for a downwind
landing.
It's easy for me in my motorglider to control my track during the
launch. I typically track about 20-30 degrees downwind of the runway for
these reasons:
* I can easily see the runway, my glide angle to the aim point, and how
much I have left; otherwise, the nose of the glider obscures all that.
* By the time I can no longer land ahead on the runway, I can make an
downwind landing with a ~220 degree turn that begin with an
into-the-wind, towards the runway turn.
* At my airport, the cross runway is can be an even better choice, as I
can make a continuous 270 degree turn and land into the wind.
Why not take off from that runway to begin with? The landing options
beyond it are poor, so I prefer the other runway as long as the cross
wind is 10 knots or less.
email me)
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what
you need to know tinyurl.com/yfs7tnz
Old March 27th 11, 05:47 PM posted to rec.aviation.soaring
toad
On Mar 27, 9:47*am, n7ly wrote:
On Mar 26, 8:30*pm, Nyal Williams wrote:
Oh, I thought someone mentioned it in passing. *Always turn into wind..
At 21:42 26 March 2011, n7ly wrote:
On Mar 26, 1:13=A0pm, "vaughn" *wrote:
"Andy" *wrote in messagenews:45b8c464-c350-4983-be8=
... wrote:
I have maintained for a long time that power pilot training for
engine
failure had the priorities wrong. =A0Power pilots are taught to set
best
glide speed first. All this does is waste time and altitude going
away
from the landing place if a turn back is the only option.
=A0.When teaching this stuff, remember to mention that turn radius
increa=
ses with
the square of airspeed! =A0An amazing number of power pilots (and even
so=
me glider
pilots) don't know that. =A0Both the bank angle and the airspeed of
that
turn are
vitally important.
Vaughn
runway centerline?
landing.
As a towpilot, I allow myself to drift downwind if possible ( no
terrain to avoid or noise sensitive areas ) to make it easier for a
glider to turn into the wind in case of a rope break.
Todd
3S
Old March 28th 11, 06:59 AM posted to rec.aviation.soaring
BruceGreeff
Our standard operating procedure is for the tug to track downwind of the
runway on all launches once through 50 or so feet. Self launchers tend
to do the same.
Why? For the reasons other people have stated - i.e. Because it gives
the glider the maximum number of alternatives.
It increases the time during which you can land ahead, both because of
the extra distance back to the runway, and because of the headwind
component.
It reduces the chance of a situation developing where you are too low to
turn 180 degrees, but can't land ahead safely.
It ensures that you are turning into wind for landing so have less
chance of overshooting the runway.
It ensures that the pilot has the runway in sight during the manoeuvre.
As Eric said, it increases the time you can see the runway because the
downward visibility is better to the side of the nose, so situational
awareness is better.
Naturally it is possible to overdo that and end up too low to reach the
runway. For example if the tuggie forgets that it is a lowly club class
hack on the end of the string, not an uber wingspan supership... So - no
process is perfect when people are making decisions, but this process is
generally safer.
Again, we do this because we don't end up traversing over hangars, trees
etc. Other airfields may differ.
runway centerline?
landing.
these reasons:
Bruce Greeff
T59D #1771 & Std Cirrus #57
Old March 28th 11, 07:11 AM posted to rec.aviation.soaring
BruceGreeff
PS - from the video it looks like he misjudged the approach to me.
The first field was bigger and I think he was aiming for it but overshot.
It certainly looks like he collected the wall with his main gear.
Doubt I would do any better in a YAK, but I did wonder why he did not
use sideslip to increase the descent angle. I expect it is that power
pilots, especially those used to the output of a M14P get totally
focussed on stretching the glide when the engine goes out. The thought
process that comes naturally to a glider pilot in terms of managing
energy to get to a landing point is perhaps not intuitive to someone
used to using only one control to achieve this?
So it looks like he arrived at the field with more energy than he expected.
SNIP
Old March 29th 11, 05:14 PM posted to rec.aviation.soaring
Mike[_28_]
Barry Shiff wrote a good article on the Impossible Turn that appears
in AOPA Pilot this month. Its worth the read. He touches on many of
the issues mentioned in the above posts.
Emergency Landing-Engine DEAD Ol Shy & Bashful Piloting 39 June 23rd 08 10:12 AM
F-16 landing no engine doylflier Piloting 2 December 14th 06 07:20 AM
NC Engine Out Landing? John A. Weeks III General Aviation 7 September 7th 04 06:28 PM
Prop Feathers and Engine Shuts down after landing???????? AIR ADVENTURE82 Owning 16 August 29th 03 09:36 PM
Prop Feathers and Engine Shuts down after landing???????? AIR ADVENTURE82 Piloting 3 August 21st 03 05:42 AM
