On Apr 8, 4:10*pm, jsbrake wrote:
Its possible to root hack the Nook now and run Android 2.2 (and maybe 3.0) on it and should be able to install the current XCSoar Android software and see if it works. I believe there is supposed to be an official upgrade to Android 2.2 coming for the Nook which should make this easier. Anybody tried XCSoar on the Nook? Perhaps a foolish question, but since the Nook Color doesn't have a GPS, how are you thinking of getting the GPS signal? *I found that there's an app called tetherGPS, but that uses an Android smartphone to transmit over wi-fi to the Nook. *Is there a way to feed the GPS directly into the nook from another GPS source? *Could it, somehow, be connected to a PowerFLARM? The Color Nook has Bluetooth hardware and enabling that and the required SPP (serial over Bluetooth) is just a matter of software. If that support is not in the common Android 2.2 root hack then it _may_ be in the official Android 2.2 update that is supposedly coming to the Color Nook. Once you have BT SSP support in the operating system the rest should be easy. And ideally applications that know how to use this (like XCSoar) should in principle just work. Once you have Bluetooth you can go out to those low cost Bluetooth GPS receivers or via a Bluetooth adapter (like the K6-BT) to a PowerFLARM etc. Of course my hand waving and seeing it all work are two different things. BTW another nook root hack resource for the color Nook is http://nookdevs.com/Portal:NookColor I just ordered a iPad 2 but the inner geek in me is thinking of getting a Moto Xoom as well since I want to play more with Android. Darryl |
getting a Moto Xoom as well since I want to play more with Android. My wife loves her iPad 2 (I braved the lines on opening day in Canada), but I have an aversion the thing. My inner geek wants a Notion Ink Adam, but in 7" format... however my inner geek is being beaten up the harsh reality of 1 child in college and 2 more close behind, plus a wife that loves to spend my sailplane money on travelling to places where I can't take my sailplane. Perhaps I can con her into getting me a Nook Color if the BT connection works to the PowerFLARM. |
On 4/8/2011 7:34 PM, Darryl Ramm wrote:
On Apr 8, 4:10 pm, wrote: Its possible to root hack the Nook now and run Android 2.2 (and maybe 3.0) on it and should be able to install the current XCSoar Android software and see if it works. I believe there is supposed to be an official upgrade to Android 2.2 coming for the Nook which should make this easier. Anybody tried XCSoar on the Nook? Perhaps a foolish question, but since the Nook Color doesn't have a GPS, how are you thinking of getting the GPS signal? I found that there's an app called tetherGPS, but that uses an Android smartphone to transmit over wi-fi to the Nook. Is there a way to feed the GPS directly into the nook from another GPS source? Could it, somehow, be connected to a PowerFLARM? The Color Nook has Bluetooth hardware and enabling that and the required SPP (serial over Bluetooth) is just a matter of software. If that support is not in the common Android 2.2 root hack then it _may_ be in the official Android 2.2 update that is supposedly coming to the Color Nook. Once you have BT SSP support in the operating system the rest should be easy. And ideally applications that know how to use this (like XCSoar) should in principle just work. Once you have Bluetooth you can go out to those low cost Bluetooth GPS receivers or via a Bluetooth adapter (like the K6-BT) to a PowerFLARM etc. Of course my hand waving and seeing it all work are two different things. BTW another nook root hack resource for the color Nook is http://nookdevs.com/Portal:NookColor I just ordered a iPad 2 but the inner geek in me is thinking of getting a Moto Xoom as well since I want to play more with Android. Darryl The Nook Color also has a USB interface, which might be another way to connect the required GPS receiver. -- Mike Schumann |
On Apr 8, 8:14*pm, Mike Schumann
wrote: On 4/8/2011 7:34 PM, Darryl Ramm wrote: On Apr 8, 4:10 pm, *wrote: Its possible to root hack the Nook now and run Android 2.2 (and maybe 3.0) on it and should be able to install the current XCSoar Android software and see if it works. I believe there is supposed to be an official upgrade to Android 2.2 coming for the Nook which should make this easier. Anybody tried XCSoar on the Nook? Perhaps a foolish question, but since the Nook Color doesn't have a GPS, how are you thinking of getting the GPS signal? *I found that there's an app called tetherGPS, but that uses an Android smartphone to transmit over wi-fi to the Nook. *Is there a way to feed the GPS directly into the nook from another GPS source? *Could it, somehow, be connected to a PowerFLARM? The Color Nook has Bluetooth hardware and enabling that and the required SPP (serial over Bluetooth) is just a matter of software. If that support is not in the common Android 2.2 root hack then it _may_ be in the official Android 2.2 update that is supposedly coming to the Color Nook. Once you have BT SSP support in the operating system the rest should be easy. And ideally applications that know how to use this (like XCSoar) should in principle just work. Once you have Bluetooth you can go out to those low cost Bluetooth GPS receivers or via a Bluetooth adapter (like the K6-BT) to a PowerFLARM etc. Of course my hand waving and seeing it all work are two different things. BTW another nook root hack resource for the color Nook is http://nookdevs.com/Portal:NookColor I just ordered a iPad 2 but the inner geek in me is thinking of getting a Moto Xoom as well since I want to play more with Android. Darryl The Nook Color also has a USB interface, which might be another way to connect the required GPS receiver. -- Mike Schumann The Color Nook as shipped is USB client only but it apparently has chipset support for Bluetooth On-The-Go (i.e. client/host switching). I don't think this is working yet with any of the root hacked Android versions. But if the BT OTG support is really there then yes this is a possibility. If its client only then it won't work. Still the first step now would be for somebody to just try out XCSoar on Android 2.2 on this platform, you don't need a physical GPS to do a test. Darryl |
![]() t 03:31 09 April 2011, Darryl Ramm wrote: On Apr 8, 8:14=A0pm, Mike Schumann wrote: On 4/8/2011 7:34 PM, Darryl Ramm wrote: On Apr 8, 4:10 pm, jsbrake =A0wrote: Its possible to root hack the Nook now and run Android 2.2 (and mayb= e 3.0) on it and should be able to install the current XCSoar Android software and see if it works. I believe there is supposed to be an official upgrade to Android 2.2 coming for the Nook which should mak= e this easier. Anybody tried XCSoar on the Nook? Perhaps a foolish question, but since the Nook Color doesn't have a GPS, how are you thinking of getting the GPS signal? =A0I found that there's an app called tetherGPS, but that uses an Android smartphone to transmit over wi-fi to the Nook. =A0Is there a way to feed the GPS directly into the nook from another GPS source? =A0Could it, somehow, = be connected to a PowerFLARM? The Color Nook has Bluetooth hardware and enabling that and the required SPP (serial over Bluetooth) is just a matter of software. If that support is not in the common Android 2.2 root hack then it _may_ be in the official Android 2.2 update that is supposedly coming to the Color Nook. Once you have BT SSP support in the operating system the rest should be easy. And ideally applications that know how to use this (like XCSoar) should in principle just work. Once you have Bluetooth you can go out to those low cost Bluetooth GPS receivers or via a Bluetooth adapter (like the K6-BT) to a PowerFLARM etc. Of course my hand waving and seeing it all work are two different things. BTW another nook root hack resource for the color Nook is http://nookdevs.com/Portal:NookColor I just ordered a iPad 2 but the inner geek in me is thinking of getting a Moto Xoom as well since I want to play more with Android. Darryl The Nook Color also has a USB interface, which might be another way to connect the required GPS receiver. -- Mike Schumann The Color Nook as shipped is USB client only but it apparently has chipset support for Bluetooth On-The-Go (i.e. client/host switching). I don't think this is working yet with any of the root hacked Android versions. But if the BT OTG support is really there then yes this is a possibility. If its client only then it won't work. Still the first step now would be for somebody to just try out XCSoar on Android 2.2 on this platform, you don't need a physical GPS to do a test. Darryl No inner geek here, but I did download XCsoar and custom map for my Droid X which is running 2.2 Android and it seems to run fine. I haven't done any flying with it yet (I have a SN10 in the glider) because I don't have any way of mounting or powering it. The droid really eats batteries ![]() CH |
Cliff:
I have a ram air turbine you can use to power your Droid. I'll put it on your glider this weekend! tuN7o |
At 23:00 12 April 2011, Tuno wrote:
Cliff: I have a ram air turbine you can use to power your Droid. I'll put it on your glider this weekend! tuN7o Not wanting to hijack the thread, but I want a small air turbine that will fit into the scoop vent in the window that would supply charging power to my batteries. As much 100+ knot flying and outside temps in the 100+ that we have out here I could have a surplus and never need to charge my batteries ![]() How about it Bumper, Do I see a high tech Quiet Vent 6 out there? CH |
On Apr 13, 9:51*am, Cliff Hilty
wrote: At 23:00 12 April 2011, Tuno wrote: Cliff: I have a ram air turbine you can use to power your Droid. I'll put it on your glider this weekend! tuN7o Not wanting to hijack the thread, but I want a small air turbine that will fit into the scoop vent in the window that would supply charging power to my batteries. As much 100+ knot flying and outside temps in the 100+ that we have out here I could have a surplus and never need to charge my batteries ![]() How about it Bumper, Do I see a high tech Quiet Vent 6 out there? CH Better idea: Piezoelectric materials to generate power from wing flexing or a Faraday device like this: http://peswiki.com/index.php/Directory:M2E_Power |
On 4/13/2011 8:51 AM, Cliff Hilty wrote:
At 23:00 12 April 2011, Tuno wrote: Cliff: I have a ram air turbine you can use to power your Droid. I'll put it on your glider this weekend! tuN7o Not wanting to hijack the thread, but I want a small air turbine that will fit into the scoop vent in the window that would supply charging power to my batteries. As much 100+ knot flying and outside temps in the 100+ that we have out here I could have a surplus and never need to charge my batteries ![]() How about it Bumper, Do I see a high tech Quiet Vent 6 out there? That's a silly idea, because it adds drag and would ruin the L/D; instead, connect the generator to the rudder pedals. The way I fan my rudder, that would run a radio, vario, GPS, ClearNav, transponder, MRX, and more. :^] -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl |
Software for glider pilots running on Ipad | nimbus | Soaring | 28 | December 10th 13 06:26 PM |
New software program for glider pilots | Matt Herron Jr. | Soaring | 9 | April 25th 10 10:14 PM |
Q: Apple MAC Book (pro) with Intel core 2 duo running Windows XP plus soaring software | Ruud | Soaring | 1 | October 31st 06 01:02 AM |
Glider Pilot Running for US President | mm | Soaring | 95 | March 5th 04 03:32 PM |
Hey OZ, NZ, SA, Argentina Was: Glider Pilot Running for US President | Vorsanger1 | Soaring | 1 | February 20th 04 03:11 AM |
