On Wed, 13 Jul 2011 06:23:51 +0000, Max Kellermann wrote:
Ben C wrote: I am looking at replacing my L-nav with either an LX1606 or Borgelt B500 (B800 if released). It will be used with a PNA running XCSoar for glide calculations. I would appreciate peoples opinions on the various merits (or otherwise) of these two instruments. On LX/Borgelt: we have drivers for these, too. I use a Borgelt B500 with Xcsoar on an HP hx4700. It is fully supported, zig-zag wind, outside air temp display, etc. There were some bugs, but I reported them and the Xscoar team fixed them :-) Borgelt cannot do bidirectional communication; things like MacCready settings are copied from Borgelt to XCSoar but not the other way round. I think this is a "feature". The B500 is designed to be a fully functional unit, with its own (high quality) GPS, final glide computer, way point database and user interface. So it makes sense to put the MacCready, ballast and bugs settings directly into the B500. The PDA adds functionality, but you have lots to fall back on if the PDA fails in flight. And: the Borgelt B50 rounds the barometric altitude to 100ft accuracy, which is of course unacceptable and unusable. I have not actually noticed this as a problem, I am not sure what I am missing out on. The B500 has a "stereo vario" function and Xcsoar a "thermal assist" display, both to help centre on thermals. Neither work for me, but most of our flying is mountain flying and I guess our thermals are a bit buggy! I have a Borgelt PSU/switching card. In hindsight I would not bother buying this again. I ended up using another power supply unit for the PDA - because it came attached to the cable. The card was very tricky to mount on the panel and most of switching functions are redundant. Next plan is a card that talks USB to an Android PDA/Tablet/Phone and serial to Flarm, Volkslogger and B500 (all at the same time), but to be future proof it should be able to talk USB to other slave devices too. One comment about Borgelt, the software is a little quirky and the hardware is no where as sturdy as the Zander I had before. But the support is good (e-mails and even Skype conversations with Mike). If you are local to Oz, this must add a few points in favour of Borgelt. Ian |
I had not thought bi-directional communication was an issue until I
started thinking about the auto-macready function in XCSoar. Bi- directional communication would make using it seamless and less workload (I think). Otherwise the stand-alone capability of the Borgelt is an attraction in the case of a PDA failure. A 302 would be stand-alone capable if linked to a 303 but I'm not sure I'd want a 303 on the panel (duplication of the PDA). I don't think the LX1606 has any final glide capability (at least not to display it). Regards, Ben On Jul 15, 6:28*am, Ian wrote: On Wed, 13 Jul 2011 06:23:51 +0000, Max Kellermann wrote: Ben C wrote: I am looking at replacing my L-nav with either an LX1606 or Borgelt B500 (B800 if released). *It will be used with a PNA running XCSoar for glide calculations. *I would appreciate peoples opinions on the various merits (or otherwise) of these two instruments. On LX/Borgelt: we have drivers for these, too. I use a Borgelt B500 with Xcsoar on an HP hx4700. It is fully supported, zig-zag wind, outside air temp display, etc. There were some bugs, but I reported them and the Xscoar team fixed them :-) Borgelt cannot do bidirectional communication; things like MacCready settings are copied from Borgelt to XCSoar but not the other way round. I think this is a "feature". The B500 is designed to be a fully functional unit, with its own (high quality) GPS, final glide computer, way point database and user interface. So it makes sense to put the MacCready, ballast and bugs settings directly into the B500. The PDA adds functionality, but you have lots to fall back on if the PDA fails in flight. And: the Borgelt B50 rounds the barometric altitude to 100ft accuracy, which is of course unacceptable and unusable. I have not actually noticed this as a problem, I am not sure what I am missing out on. The B500 has a "stereo vario" function and Xcsoar a "thermal assist" display, both to help centre on thermals. Neither work for me, but most of our flying is mountain flying and I guess our thermals are a bit buggy! I have a Borgelt PSU/switching card. In hindsight I would not bother buying this again. I ended up using another power supply unit for the PDA - because it came attached to the cable. The card was very tricky to mount on the panel and most of switching functions are redundant. Next plan is a card that talks USB to an Android PDA/Tablet/Phone and serial to Flarm, Volkslogger and B500 (all at the same time), but to be *future proof it should be able to talk USB to other slave devices too. One comment about Borgelt, the software is a little quirky and the hardware is no where as sturdy as the Zander I had before. But the support is good (e-mails and even Skype conversations with Mike). If you are local to Oz, this must add a few points in favour of Borgelt. Ian |
Used Borgelt B40 Vario. | [email protected] | Soaring | 0 | September 21st 08 05:53 PM |
Wanted: Borgelt B40 Vario | [email protected] | Soaring | 4 | September 16th 08 03:07 AM |
Borgelt B500 | Guy Corbett | Soaring | 4 | June 20th 07 05:17 PM |
Flight Computer: Borgelt B500 or LX1600? | Ian | Soaring | 7 | January 1st 07 11:18 PM |
New Borgelt Vario! | [email protected] | Soaring | 2 | June 10th 05 03:45 PM |
