Water ballast rookie question
Old August 16th 11, 03:09 PM posted to rec.aviation.soaring
John Cochrane[_2_]
Default Water ballast rookie question
On Aug 13, 9:40*pm, Tom Nau wrote:
I fly an ASW-28. The under-surface of the wing has a nice little piece
of plastic that covers the dump valve and which is hinged by a piece
of cloth tape. When flying with water ballast my assumption is that
correct procedure is to leave the piece of plastic in place, but open
and hanging down from the cloth tape hinge. I am thinking that airflow
will keep the plastic closed and be more aerodynamic over the dump
valve but when dumping ballast it will open sufficiently to let the
ballast dump efficiently. Or should I simply remove the piece of
plastic entirely when carrying water ballast? *Thanks.
Tom
That's how they're supposed to work.
Tape them closed when flying dry so you don't rip them off. Don't
forget to take the tape off when you put on water ballast. (Add "check
dump covers" to your preflight)
When inevitably they fall off, replace with any flat piece of plastic.
I find that the clear plastic case that holds 3m vinyl electrical tape
which I use for wing tape works great, and I usually have a large
supply of that around.
There is a larger issue of tips and tricks for water ballast which
others have covered. Some additional points:
-It is important to adjust CG using the tail tank. It's hard enough to
thermal with water without a far forward cg
-The glider is designed to carry enough water for the strongest
conditions imaginable -- smoking ridge day, 1000k attempt at Ely, etc.
On most days you do not need or want full water. Half water is a good
place to start.
- Takeoff with water ballast is harder. Carefully brief your wing
runner that the wings must be level and balanced -- no force up or
down. He or she may have to slosh the water through the internal
baffles to get it level and balanced. There must be no up or down
pressure. Ask the wing runner to let go briefly to show you there is
no pressure if you're in doubt. The wing runner must then run like
crazy, without pushing up or down. This is a good time to use partial
spoilers for roll control. Needless to say all this gets more fun at
high altitude, hot, cross-downwind at a contest. Release early if you
drop a wing!
-Enjoy! I like flying with water. It's a big performance increase for
free.
John Cochrane
Old August 18th 11, 07:13 AM posted to rec.aviation.soaring
P9
Another water ballast question.
How well does a fully ballasted glider recover from a spin?
I practice spins every season, dry. The recovery is easy and
predictable. (SZD 55-1) I have never tried a spin with water. If I
accidently spin at low atlitude (1000 ft agl or lower) fully
ballasted, should I attempt to recover, or just bail?
Kerry
Old August 18th 11, 02:09 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
I practice spins every season, dry. *The recovery is easy and
predictable. *(SZD 55-1) *I have never tried a spin with water. *If I
Kerry
Hi Kerry,
Enjoyed flying with you at Air Sailing Sports. Good race again this
year and those AFA guys can no longer be ignored, can they?Your 55
holds a ton of water, I'd recommend you try spinning it with a half
load, then work up from there.................well maybe that's not
such a good idea because a partial load can shift to the outboard wing
tip and give a big lateral weight problem. I remember Carl Herold
telling me the 12 would tuck under to where the nose was more than
vertical when he spun her with a load of water.........Hmmm, maybe
don't spin it wet would be the best advice and if you spin it at 1000
agl, i'd do it with a BRS installed. Adding the BRS to my Genesis was
the best thing I have done lately, I feel much more secure now and
enjoy that comfortable seat (without chute).
Cheers,
JJ
Old August 18th 11, 03:05 PM posted to rec.aviation.soaring
mattm[_2_]
Kerry
Hi Kerry,
agl, i'd do it with *a BRS installed. Adding the BRS to my Genesis was
enjoy that comfortable seat (without *chute).
Cheers,
JJ
Don't forget the story of spin testing the Schweitzer 1-35. Since the
plane was to be certified by the FAA and it was the first Schweitzer
with water ballast, the FAA insisted on a spin test with one wing full
and the other dry. Needless to say it was a pretty exciting test...
The towpilot followed the plane down and reported the spin axis was
outboard in the wing. It took multiple kicks of the rudder to finally
break the spin.
The test pilot administered a few extra kicks after landing just for
good
measure!
Note also that some planes prohibit spins while loaded with ballast.
Make sure to consult your owner's manual carefully. Keep in mind
that the ballast will move outboard in your wings and increase your
rotational momentum. Also keep in mind the advice from a good
friend of mine who used to be a test pilot: "Don't spin!"
-- Matt
Old August 18th 11, 04:34 PM posted to rec.aviation.soaring
Mike the Strike
Kerry
Hi Kerry,
Cheers,
JJ
Don't forget the story of spin testing the Schweitzer 1-35. *Since the
and the other dry. *Needless to say it was a pretty exciting test...
outboard in the wing. *It took multiple kicks of the rudder to finally
break the spin.
good
measure!
Make sure to consult your owner's manual carefully. *Keep in mind
rotational momentum. *Also keep in mind the advice from a good
friend of mine who used to be a test pilot: *"Don't spin!"
-- Matt
Some years ago, I got kicked out of a boisterous and very turbulent
Arizona thermal flying my ASW-20 with close to full ballast. The yaw
string went sideways, then backwards and I literally fell out of the
sky, entering a strong incipient spin (perhaps half or three-quarters
of a turn). I fortunately did everything right and recovered quite
quickly, but lost nearly 800 feet of altitude in the process. It
caught my attention!
Ever since then, I have always thermalled more conservatively when
anywhere near the ground. I know of at least one incident of a modern
ship that stalled off tow and spun into the ground when fully
ballasted.
I also do not spin - ever!
Mike
Trying for a Diamond Goal tommorow - water ballast question Scott Alexander[_2_] Soaring 27 April 29th 10 09:28 PM
DUMB ROOKIE QUESTION Travis Beach Soaring 10 November 7th 06 07:28 PM
Who first used water ballast and when? John McCullagh Soaring 9 October 18th 06 09:36 AM
water ballast leak Robert Harvey Soaring 2 May 27th 05 03:49 PM
Std 102 water ballast plug Tom Dukerich Soaring 3 April 12th 05 05:10 PM
