On Aug 29, 2:56*pm, wrote:
On Aug 25, 1:37*pm, johngalloway wrote: On Aug 25, 4:31*am, Tim Taylor wrote: On Aug 24, 9:09*pm, jim wynhoff wrote: On Aug 21, 7:35*pm, Tim Taylor wrote: Are there any working designs for an air extractor for the Ventus 2? Tim, * Sisu1A *on RAS makes extractors for the ASW20 (some models), and has made one (or more) for his SZD. In both of those cases, the extractor replaces an access panel or hatch that happens to be in a position that is 'good enough'. *I made a simple 'Mandl Extracor' for my Speed Astirhttp://griderpirate.smugmug.com/Airplanes/Glider-stuff/3702283_Rsct24... and it does increase cockpit comfort significantly. Does the Ventus have a conveniently placed access hatch, or will there be cutting involved? Cheers, Jim Jim, There will be cutting involved and most Schempp-Hirth's are Standard Airworthiness. *I am looking at something similar to the Jonker's design for my Ventus 2 to improve the airflow and cooling in the cockpit. Tim http://www.easternsailplane.com/east...ternSailplane/... Couldn't fit that legally in Europe nowadays John Galloway- Hide quoted text - - Show quoted text - I would appear that you are not up to date with respect to ongoing developments. EASA approval is very close for Schleicher gliders that this vent was originally designed for. UH- Hide quoted text - - Show quoted text - I had the Eastern Sailplanes vent installed in my ASW27 and i have little doubt that it is the single most cost-effective performance improvement expense imaginable. I highly recommend it. Sven Olivier |
On Aug 29, 1:45*pm, Sven wrote:
I had the Eastern Sailplanes vent installed in my ASW27 and i have little doubt that it is the single most cost-effective performance improvement expense imaginable. I highly recommend it. Sven Olivier- Hide quoted text - - Show quoted text - What performance gain did you see? Is the US handicap guru, or contest committee, considering adding extractors to the list of mods that require a contest handicap change? Andy |
FS Ventus 2cx 15/18 | SAM AND LEIGH ZIMMERMAN | Soaring | 0 | April 29th 08 02:10 PM |
FS: Ventus C | James Hamilton | Soaring | 0 | September 13th 06 09:18 PM |
FS: Ventus C 17.6 | John Shelton | Soaring | 0 | November 16th 04 12:55 AM |
FS: Ventus C 17.6 | John Shelton | Soaring | 2 | November 16th 04 12:53 AM |
FS Ventus C 17.6 | John Shelton | Soaring | 0 | August 18th 04 03:39 PM |
