#41
You can stop playing with 10.7 as a source of the problem. I cannot recall an
aircraft navcom using 10.7 as the IF frequency. Jim "Paul Sengupta" shared these priceless pearls of wisdom: -Bear in mind that the radios involved may have different front -ends. It might just be a coincidence that your handheld and -panel radios are affected and nothing to do with the airframe. - -How about 127.00-10.7 (IF mixer) = 116.30 -116.30/2 = 58.15? -(i.e. mixing of the second harmonic of 58.15MHz) - -Ok, unlikely, just playing with numbers! - -Paul -G1YJY - -"Snowbird" wrote in message . com... - Update: I talked to a local DE who is also doing piles of - instrument instruction. She says she's flying in beaucoup - planes in that area, without the same problem. - Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
#42
I think we are chasing our tails here, folks. Snowbird says that she gets the interference on her handheld. Let's do the binary troubleshooting tree. Split the problem into two parts. It is either IN the aircraft or OUT of the aircraft that the problem is located. Depending on how often this problem occurs (once a week? once a day? once an hour?...) DRIVE the handheld out near the antenna farm and sit there and listen on one of the most affected frequencies. Does it still happen? Then with 99% probability, you've got a problem not of your own making. Does it not happen? Then you've got a problem in the aircraft. Let's settle THAT one and we can go from there. Or, rather than drive out and sit for hours in the wintertime, do you have any friends that live near the farm? Would they be willing to sit your handheld in their window and listen for a few days? All else at this point is conjecture. Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
#43
"Paul Sengupta" wrote in message . ..
http://www.leeselect.com/shopping/pricelist.asp?prid=41 Maybe you could borrow one to try on the handheld. It could work if the strong out of band signal is causing problems with the receiver front end, but if the intermod/harmonics/ whatever are external and fall in-band then it's not going to help. Paul, Thanks for the link! Yes, that looks like the correct kind of product, but my concern is it includes the nav radio frequencies. If Aaron is correct that the problem might be via the nav radios, we need a narrower freq. range. Best, Sydney |
#44
#45
On Wed, 05 Nov 2003 18:02:44 GMT, wrote:
On 5-Nov-2003, (Snowbird) wrote: OK, here is what I don't understand: We have this problem with the airplane's master switch turned OFF Can the receiver's RF amp generate intermod products when the power is switched OFF? Very, very unlikely. Those who propose this theory assume that an It can happen easily. For instance a ham had aa problem with Television Interference. His station was clean...a team did some snooping and found the culprit was an attic mounted prearmp hooked to an antenna. There was no power to the preamp and no cable to the preamp other than the TV antenna. The offender was causing problems over nearly a city block. interfering intermod is being generated within the antenna system or preamp of one radio and then being re-radiated out the antenna to another com antenna, where it interferes with reception on the second radio. What this theory fails to take into account is the large attenuation that the intermod When we had the 144 MHZ repeater here, I could walk out and wipe a screwdriver blade up and down a guy wire (still new and shiny wire) while the transmitter was active. It created enough hash to drowned out a 50 watt mobile less than 4 miles away. It only takes a few micro volts of signal to cause a problem. Roger Halstead (K8RI EN73 & ARRL Life Member) www.rogerhalstead.com N833R World's oldest Debonair? (S# CD-2) would be subject to in the propagation between antennas. The far more likely scenario is that the antenna farm is transmitting two (or more) very strong out-of band signals that cause intermodulation interference in your com receivers. My guess is that this problem exists for others as well, depending upon the band selectivity of the front ends of their radios. There is a relatively simple way you can test this theory. What you need is a 6 dB RF coaxial attenuator. These little buggers cost around $30 each, but maybe you can borrow one from your avionics shop. Put the attenuator between the antenna and receiver on your handheld. (You will, of course, have selected an attenuator with he proper RF connectors on it. Otherwise, you will need suitable adaptors.) Then fly to the location where the problem exists. I'll bet that with the attenuator you will no longer get the interference on the handheld, but you will probably be able to receive the TRACON signal. Assuming I'm right, here is what's going on: The 6 dB attenuator attenuates ALL signals going through it by 6 dB, including the strong out of band signals that are causing the intermods. However, the amplitude of the intermod that these signals cause is thereby attenuated by more like 18 dB, probably enough to make them too weak to cause problems. The TRACON signal is also attenuated by 6 dB, but it is probably strong enough to begin with so that you will still be able to receive it OK. One caution: do NOT transmit on the handheld when the attenuator is in place. Depending upon the TX output power of the handheld and the power rating of the attenuator, it (the attenuator) could be damaged. In any case, transmissions would be attenuated by 6 dB, which might make them to weak to be received by the ground station. |
#46
On Wed, 05 Nov 2003 11:10:29 -0800, Jim Weir wrote:
I think we are chasing our tails here, folks. Snowbird says that she gets the interference on her handheld. Let's do the binary troubleshooting tree. Split the problem into two parts. It is either IN the aircraft or OUT of the aircraft that the problem is located. Depending on how often this problem occurs (once a week? once a day? once an hour?...) DRIVE the handheld out near the antenna farm and sit there and listen on one of the most affected frequencies. As a suggestion, try a bigger antenna on the HT if it has the connector. Does it still happen? Then with 99% probability, you've got a problem not of your own making. HTs are notorious for running the front ends wide open so it could be the HT. Although out of all the HTs I've owned including commercial (Motorola), I've only had one that was bad on intermod. Given a strong enough signal any of them would intermod, or rather cross mod, but virtually any radio will do that. OTOH, I've had two out of 7 mobile rigs that had a problem. Course when all is totaled up I've run into as many commercial installations in the area that were either intermoding with each other, or transmitting spurs. (which ain't many after this many years) My biggest problem is a paging system about two miles from me that has a problem about once a year. Does it not happen? Then you've got a problem in the aircraft. Let's settle THAT one and we can go from there. Or, rather than drive out and sit for hours in the wintertime, do you have any friends that live near the farm? Would they be willing to sit your handheld in their window and listen for a few days? If possible stick an antenna out the window of a nearby home and then set one of those voice activated tape recorders next to it. Come back about the time you expect the batteries to go dead. It makes for a good check and doesn't require constant attention. All else at this point is conjecture. They are bad enough to find even using a systematic approach. :-)) Roger Halstead (K8RI EN73 & ARRL Life Member) www.rogerhalstead.com N833R World's oldest Debonair? (S# CD-2) Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
#47
Roger Halstead wrote in message . ..
On Wed, 05 Nov 2003 11:10:29 -0800, Jim Weir wrote: I think we are chasing our tails here, folks. Well, I'm not sure the decision tree is quite this binary from what folks are saying. If I drive to the antenna farm and get the interference, does it prove the problem is outside my plane, or just that the handheld is also more susceptible to it? If I drive to the antenna farm every day for a month and don't get the interference, does it prove the problem is in my plane, or that the interference is several things combined some of which aren't line-of-sight to my current ground location? This is not to say that I don't think it's worth at least a drive to the area, and a flight in someone else's plane with my handheld. But what I'd like to understand is this: How could my nav radios (or my handheld) be contributing to this problem when they are *powered off*? Could someone explain this to me please? I'm not an electronics wizard (obviously) but I do know a little bit and this just seems very "twilight zone". Thanks, Sydney |
#48
Can you hear this interference through the cabin speaker? Or perhaps
your using active noise-cancelling headsets? Snowbird wrote: OK, we're still having our RF interference problem and our avionics guy pleads 'stumped'. Meanwhile we're going nuts whenever we need to get radar vectors for the ILS at our local Class D or when we depart IFR to the SE. Here is what we know 1) the problem is intermittant. occurs both at night and during day. 2) when it does occur, the problem occurs in a specific area -- heading towards a local antenna farm 3) legitimate radio transmissions come through loud and clear 4) the interference isn't just random noise, but sometimes has voices in it (like a radio or TV show) 5) we have disconnected the ELT from its antenna (but left it turned off in the back seat of the plane) -- problem persists 6) marker beacons on, marker beacons off, nav radios different freqs, nav radios off, no effect 7) swapped our KMA 20 audio panel for a loaner KMA 20 no difference 8) we have tried turning off the airplane's entire electrical system and listening for interference on a handheld radio with its own "stick" antenna. Problem persists (!!!!) 9) we have tried different frequencies while experiencing the interference -- not exhaustively. here is a list (- means no interference + means interference) 124.00 - 124.20 - 124.52 - 125.00 - 126.00 + 126.50 + 126.50 mb on, mb off, nav 111.9, nav 110.8, nav off 126.50 handheld w/ alt off, airplane electrical system off 127.00 + 127.10 - 127.25 - 127.27 + 127.30 - 127.50 + 127.97 - 128.00 - 129.00 + 130.00 - 131.00 - 132.00 + (126.5 is the local tracon frequency where the interference is problematic for us, which is why I focused there. 127.0 might be the strongest interference) geographical location where interference seems strongest (there's an antenna there, and when we were directly over it interference stopped) 38 31 90 90 21 75 Can we figure out the frequency and maybe the station which is causing the problem from the above info? Ideas? Other tests? Things to check? Help! If we still get the problem with the plane's entire electrical system off and using a radio/antenna which is not connected to the plane, is there ANYTHING we can do or must we just grit our teeth and bear this? Plane's equipment: Sigtronics SCI-4 intercom KMA20 audio panel/mb King KI-170B nav/com TKM 170B nav/com Apollo 2001 IFR GPS King KN-75 glideslope receiver King KT-76 Transponder no ADF or DME THANKS! Sydney Grumman AA5B "Tigger" |
#49
: How could my nav radios (or my handheld) be contributing : to this problem when they are *powered off*? Did you ever build a "crystal" radio when you were a kid? It's an AM radio that receives stations and powers an earphone using only the energy received through the antenna. If there is enough RF energy in the air (say at an antenna farm), there is enough power being received by the antenna to make the powered off radio into an analog of the "crystal" radio. The powered off radio uses the received RF energy to become an oscillator (transmitter). : Could someone explain this to me please? I'm not an electronics : wizard (obviously) but I do know a little bit and this just seems : very "twilight zone". Does that help? -- Aaron Coolidge (N9376J) |
| Thread Tools | |
| Display Modes | |
