Scheibe SF-25 Motorfalke horizontal stabilizer and other parts needed
Old December 8th 11, 09:33 PM posted to rec.aviation.soaring
Default Scheibe SF-25 Motorfalke horizontal stabilizer and other parts needed
Good idea on adding foam fairing for the gear legs.
As to the frankenscheibe comment this A/C is based on the SF-25, but was/is a much modified experimental with retract gear and reflex flaps and ailerons.
There is not much Scheibe there to franken anymore.
What I need is a tailplane that is not rotten.
Most of the other damage I have already repaired or have worked out the repair for.
As to the tailplane there is enough left to use as patterns if necessary.
I have given some thought to making the stabilizer like the KR-2 stabilizer, wood spars foam for contour covered with fiberglass.
I think that this might be heavier than the wood used in the original.
Does anyone have knowledge of where a wrecked scheibe motorglider might be?
I think all of them are very similar.
I am told that the attachment fittings are somewhat made to fit on an individual basis there being some differences in tolerances form ship to ship.
Best regards,
J.D. Barron
Slingsby T.61 MotorFalke R. Wubben Soaring 11 December 10th 17 07:38 PM
G-103 horizontal stabilizer airfoil section ? [email protected] Soaring 3 November 23rd 08 04:30 AM
Pik-20 Parts needed WAVEGURU Soaring 1 October 23rd 07 11:39 PM
WTB: 1-34 Horizontal Stabilizer Jeremy Zawodny Soaring 1 October 15th 04 05:12 AM
Parts Needed Jim Phoenix Soaring 0 September 17th 03 03:27 AM
