A careful reading of the US FAR's shows 91.309 is not the only
applicable rule addressing aero tow weak links. 91.9 require all aircraft to be operated in accordance with their Approved Flight Manuals (POH) - if one was published as part of the airworthiness documentation. JAR-22 gliders and most other modern glider have such AFM's which specify an aero tow weak link. Seen in this light, 91.309 is a historical accident which has become a "catch all" for gliders without an AFM specified weak link, (eg, Schweizers). Taken together, 91.309 and 91.9 mean that the AFM specified weak link it to be used at the glider end and a weak link at the tow plane end must be stronger than the glider end link but not more than 25% stronger. FAA FSDO inspectors I've discussed this with agree with this interpretation. AFAIK, no one in the US is actually operating in accordance with the above rules since they think it would be a hassle to be switching weak links for every glider. Fortunately, Tost makes hardware which makes it somewhat easier. It wouldn't surprise me to see an NPRM clarifying the above. Bill D On Jan 4, 6:11*pm, Markus Graeber wrote: I am in the process of writing up some regulations for aerotowing to standardize operations and ensure safe procedures for us here in Colombia. The civil aviation authorities don't know a thing about the intricacies of aerotowing so we are on our own with how we want to go about it. Hence the desire to implement something that resembles best bractices across the gliding world. I have been reviewing information/regulations from Germany, the US, the UK, Australia and New Zealand as well as manufacturer information and manuals. The result of this excercise so far has been that there are some considerable differences across countries even with such basic things as aerotow rope requirements. As far as a general guide is concerned I ran into the newly published book "Aerotowing Gliders" by John Marriot (http://www.amazon.com/ Aerotowing-Gliders-towing-gliders-emphasis/dp/1456775154/ref=sr_1_1? s=books&ie=UTF8&qid=1325720610&sr=1-1) which after a first quick read looks like a good basis for general operating procedures. As far as aerotow investigations and rope requirements are concerned I had, among other things, a good look at http://www.negevgliding.com/safety/a...d.html(http:// translate.google.com/translate?sl=de&tl=en&u=://www.dg-flugzeugbau.de %2Fsollbruchstelle-d.html&act=url)http://www.dg-flugzeugbau.de/flugzeu...d.html(http:// translate.google.com/translate?sl=de&tl=en&u=http://www.dg- flugzeugbau.de/flugzeugschlepp-d.html&act=url) In addition and since I have years of past aerotow experience in the US I looked again at the regulations in the FARs: ------------------------ FAR 91.309 * * Minimum Strength = 80 percent of the glider maximum certificated operating weight * * Maximum Strength = twice the maximum certificated operating weight Note: Maximum certificated operating weight can be found in the glider POH and may be the Maximum certificated gross weight at takeoff. If the towrope has a breaking strength more than twice the maximum certificated operating weight of the glider being towed, a safety link has to be installed at the point of attachment of the glider and the tow plane with the following breaking strength requirements. Safety Link (Weak Link) Requirements Safety link (Weak Link) at the glider end: * * Minimum Strength = 80 percent of the glider maximum certificated operating weight * * Maximum Strength = twice the maximum certificated operating weight Safety link (Weak Link) at the tow plane end: * * Strength Requirements = Greater, but not more than 25% greater than that of the safety link on the glider end, and not more than twice the maximum certificated operating weight of the glider ------------------------ My conclusions that have come out of this so far a Aerotow, especially of single seater light wing loading gliders, should only be done with a nose hook (and not a CG hook) to avoid the danger of the rapid onset of kiting that will not break your standard glider weak link but stall the tow plane (see UK tests described inhttp://www.negevgliding.com/safety/airtow.pdf). Weak links at both ends of the rope to protect the glider but also the tow plane in case the rope gets caught e.g. in a tree or power line after glider release when close to the ground (I ran into several accident reports where this happened, especially after a tow emergency at low altitude). Interestingly enough the UK requires a weak link at the tow plane end to protect the tow plane with an additional glider end weak link being optional while the Germans only explicitely require a glider end weak link according to the glider manual. I have a personal distaste for the US arangement of using ropes as weak links since it is not easy to tell which rope has which diameter/ is made of which material to then indirectly deduct the rope weak link/ aerotow rope strength (if no weak links are used). In addition, rope wear can quickly become an issue limiting weak link/rope strength. Coming originally from a winching background for me there is nothing simpler than teaching and checking the weak link color required for a specific glider, no second guessing, no hidden rope wear reducing the weak link/rope strength. Now to the recommended weak link strengths: The US idea of having a slightly stronger weak link on the tow plane end seems to be a sensible idea to have the weak link fail first on the glider end to protect the glider from getting entangled with the rope which could happen if it breaks on the tow plane end. However, the specific US weak link strength requirements do not make much sense and e.g. in the case of the Diamond DA-40 contravene what the aircraft manual permits (http://www.diamond-air.at/fileadmin/...sales_support/ DA40-180/Airplane_Flight_Manual/Supplements/60101e-o1-r1.pdf): DA-40 Manual states: Weak link of max. 899 lbf (400 daN) on tow plane end required, on glider side optional according to glider manual, 750 kg/1653 lb max glider weight on tow, tow rope min breaking load 2248 lbf (1000 daN) If I use the requirements of FAR 91.309 to determine weak link strengths I could use between 80% and 200% of max gross weight of the glider for the glider end but it would be limited to just below the strength of the tow plane end weak link. So if the DA-40 manual limits me to 899 lbf (400 daN) on the tow plane end my glider weak link has to be less than that, best case 898 lbf (399 daN). The best I can do now for max gross weight is a minimum of 80% of the glider's max gross weight for the glider end weak link which would get me at the most 1122.5 lbs/509 kg for the glider. In short the FARs would not allow me to tow any modern 2 seater with a DA-40 even though the DA-40 manual explicitely allows for up to 1653 lb/750 kg gliders. Now considering the UK tests mentioned earlier it seems to me like a really bad idea to use a tow rope with no weak links approaching twice the max gross weight as allowed by the FARs. Research done in Germany suggests (see above links to documents on the DG website) that weak links of no more than 661 lbf/300 daN are necessary on the glider end even though most glider handbooks specify the same weak link strength for aerotow as for winch launching (which involves much higher forces). So the quick summary of my take so far on all this with regards to aerotow ropes is: - Minimum aerotow rope breaking load of 2248 lbf (1000 daN) - General purpose length of aerotow rope for standard daily ops of 50m/ 165 feet - Use of 2 weak links, one on the glider end, one on the tow plane end - Weak links with the Tost reserve setup, 899 lbf (400 daN) on the tow plane end, 661 lbf/300 daN on the glider end Looking forward to comments, suggestions, experiences etc. Thanks in advance, Markus Graeber Aeroclub de Colombia Gliding Colombia/Vuelo a Vela Colombia |
FAA regulations - W&B | Arne | Piloting | 13 | March 15th 05 01:50 AM |
Jim Weir - aviation headset specifications | Rick Pellicciotti | Home Built | 2 | October 4th 04 07:34 PM |
Aerotow rope drogue chute? | John Galloway | Soaring | 18 | December 11th 03 05:37 AM |
Connecting Rod Specifications | Cambridge_Flyer | Home Built | 4 | November 18th 03 11:54 AM |
Huntair Pathfinder 2 specifications | Nigel Hodgson | General Aviation | 1 | October 16th 03 04:32 AM |
